toe in adjustment - Polaris RZR Forum - RZR Forums.net
toe in adjustment
This is a discussion on toe in adjustment within the General RZR Discussion forums, part of the General RZR category; Hello; I hit a rock with my right front tire this weekend and knocked the right front toe out, you can see it with your ...
Old June 19th, 2011, 02:47 PM   #1
kenner's Avatar
Member #26922
View kenner's Photo Gallery(0)
toe in adjustment
Hello;
I hit a rock with my right front tire this weekend and knocked the right front toe out, you can see it with your eye and the steering wheel is now off, what is the toe out on this 2011 RZR, I know there is some toe out but not sure of how much.
kenner
kenner is offline   Reply With Quote
Old June 19th, 2011, 03:10 PM   #2
sunnyside360's Avatar
My RZR: 2011 Orange Madness with EPS
Member #23630
View sunnyside360's Photo Gallery(0)
Re: toe in adjustment
I'd check the right & left tie rods and suspension arms for damage first (bent?). I did something similar a few months ago and found a bent tie rod. Wound up having to replace the entire rack & pinion assembly which included the tie rods.
sunnyside360 is offline   Reply With Quote
Old June 19th, 2011, 07:52 PM   #3
kenner's Avatar
Member #26922
Checked over the fr. end and did not notice anything bent, should be able to just reset toe.
kenner
Old June 19th, 2011, 09:53 PM   #4
GJRonK's Avatar
First Name: Ron
My RZR: 2011 800 EPS Graphite
Member #24461
View GJRonK's Photo Gallery(0)
I have described here what you can do:
http://www.rzrforums.net/general-rzr...ent-story.html
GJRonK
GJRonK is offline   Reply With Quote
Old June 20th, 2011, 03:11 AM   #5
smitty's Avatar
First Name: Mick
My RZR: 2009 LE
Member #10320
View smitty's Photo Gallery(0) Send a message via Skype™ to smitty
Hi, If you have or can borrow a laser measure, it's a lot easier to measure between your wheels and or tyres while doing the tie rod adjustment.For the record, I have mine toed out between tyre walls at 2mm.Steers light and well on the flat track:
Hope this helps
Cheers Mick
smitty is offline   Reply With Quote
Old June 20th, 2011, 07:11 AM   #6
Member #23630
I like the idea of using a laser measure.
Old June 20th, 2011, 08:30 AM   #7
GJRonK's Avatar
First Name: Ron
Member #24461
Hope this helps
Cheers Mick
Good idea. But it should only be toed out south of the equator, Mate, toed in north.
GJRonK
Old June 20th, 2011, 03:25 PM   #8
smitty's Avatar
First Name: Mick
My RZR: 2009 LE
Member #10320
GJRonK[/QUOTE]
It's ok GJronk, I only do clockwise circuits, you know, the same way our water goes down the plug hole So toe outs perfect
Cheers Mate
Mick
Old June 20th, 2011, 07:29 PM   #9
srt20's Avatar
My RZR: 2015 RZR 4 900 Red
Member #23480
View srt20's Photo Gallery(0)
Why do you want it toed in?
2015 900 4 SSV Works door pods and glovebox sub, UTV headquarters roof, 30" curved led bar, Mudbusters flares
Sold
2011 Boardwalk Blue and White LE 26" Bighorns on 14" SIXr wheels, 1.5" spacers, 58" wide, Racertech lift, front and rear bumpers,tunes by SSV Works, LTR 450 shocks
srt20 is online now   Reply With Quote
Old June 20th, 2011, 07:42 PM   #10
GJRonK's Avatar
First Name: Ron
Member #24461
Who are you asking?
GJRonK
Old June 20th, 2011, 07:47 PM   #11
smitty's Avatar
First Name: Mick
My RZR: 2009 LE
Member #10320
Yep,I don't get it either
Mick
Old June 20th, 2011, 07:56 PM   #12
srt20's Avatar
Member #23480
Im just asking whoever, why would a person want the front tires toed in? I thought toed out is what its supposed to be.
Sold
Old June 20th, 2011, 08:29 PM   #13
GJRonK's Avatar
First Name: Ron
Member #24461
Could you be suggesting that a company that has had so many poor engineering flubs and poor preparation of product to be delivered including often sending out new units toed out 1", really knows what is the best alignment?
I toe in my car (which gets 70,000 miles on tires), toe in my Yamaha Grizzly (which will get 12,000 miles on Bighorns), and live north of the equator. I don't know, anyway, that a slight toe out or in matters much. The RZR is always bouncing, turning, tilting, accellerating, braking, and has varied weights on it, so the toe is probably rarely the same when in use anyway.
I really suspect it's arbitrary as my toe is only about 1/16th to 1/8th of an inch and runs straight as an arrow in dirt or on pavement at 50 mph.
GJRonK
Old June 20th, 2011, 09:27 PM   #14
smitty's Avatar
First Name: Mick
My RZR: 2009 LE
Member #10320
GJRonK
I think there is no real comparison from a street car to the RZR. I agree that it not as critical on the RZR, but through a bit of fooling around with front end suspension and steering for our style of racing,a little toe out seems to turn better than toe in.Such is it too with the V8 touring cars here,although a lot more critical.For general trail riding,I would say it has very little bearing also, but should be within cooee..not an inch out.All should be checked from new, and on a regular basis, as with a basic maintainence schedule.It does blow me away how the dealers do not go through this stuff on pre delivery,just plain lazy I would say...happens under the equator too!
Old June 20th, 2011, 09:50 PM   #15
ADKrzrlvr's Avatar
First Name: Frank
My RZR: 2016 1KS
Member #18783
View ADKrzrlvr's Photo Gallery(0)
I have experimented with both and I found toe in does well on the berms and tight trails but toed out seems to be better for my all around riding, jumping and high speed hard pack. If you look at the rzr logo at the top of the forum the rzr they show has uneven toeing...seems like the drivers side is toed out more just like my rzr from the factory.
ADKrzrlvr is offline   Reply With Quote
adjustin the toe on a polaris rzr
bumped rear wheel now rear wheel is toe out
how to adjust toe in on polaris ranger 500
how to adjust toe on rzr
how to adjust.toe on 800 rzr
how to set the toein on an polaris 570 side by side
how to set toe on rzr
polaris rzr 800 toe in
polaris rzr toe in adjustment
polaris rzr tow adjustmens
rzr 1000 front toe adjustment
rzr 800 front toe in toe out adjustment
rzr toe adjustment
rzr toe in
rzr wheel toe adjustment
TPS Adjustment....or Throttle Cable Adjustment bizness RZR-S Specific Discussion 5 January 19th, 2012 06:15 PM
Help with BOV adjustment milosusa Forced Induction 9 November 14th, 2010 06:25 AM
Tie Rod Adjustment Larrymay General RZR Discussion 1 September 23rd, 2009 03:31 PM
Tie rod adjustment Danny RZR-S Specific Discussion 6 December 23rd, 2008 11:57 AM
Help!! Tie rod adjustment on RZR-S mdebone1 Engine and Drivetrain 6 December 10th, 2008 09:49 AM
