OIL Change? 2011 RZR - Polaris RZR Forum - RZR Forums.net
post #1 of 17 Old May 24th, 2011, 10:44 AM Thread Starter
2011 RZR 800's Avatar
First Name: Kerry
My RZR: 2011 800 RZR 50
Member #23427
Wrench OIL Change? 2011 RZR
i have a 2011 RZR with 77 miles on it.is now a good time to change oil and what else should i do?i have adjusted throttle cable at 75 miles and changed plugs while i had bed off to adjust throttle,i put E3's in for the plugs just my personal choice.
2011 RZR 800 is offline
post #2 of 17 Old May 24th, 2011, 10:47 AM
iggys6's Avatar
First Name: Ethan
My RZR: 2008 RZR 800 2nd Gen
Member #24294
View iggys6's Photo Gallery(0)
Re: OIL Change? 2011 RZR
I change mine every 100 Miles and it has 950 miles on it, I also have a 2008 2nd Gen so if mine holds up I bet yours will 2x more
iggys6 is offline
post #3 of 17 Old May 24th, 2011, 10:54 AM Thread Starter
First Name: Kerry
Member #23427
thanks for the reply.it's the first oil change and wasn't sure when was a good time for the first.using polaris oil till factory warranty runs out then go to royal purple for everything i can after that.
post #4 of 17 Old May 24th, 2011, 10:56 AM
iggys6's Avatar
First Name: Ethan
Member #24294
Yeah make sure to just get the oils and everything you need before the warranty runs out. Its also good to have some in hand just in case a problem occurs! Also if you don't want to spend the $11.99 or so for the oil filter there are some threads that say what other oil filter type works and most of the brands are the exact same, just without the polaris logo.
iggys6 is offline
post #5 of 17 Old May 24th, 2011, 11:01 AM
Bobby.Digital's Avatar
First Name: Bobby
My RZR: 2011 900xp LE
Member #24519
View Bobby.Digital's Photo Gallery(0)
Do you know what the model # is for the E3 spark plug? I was looking everywhere for it yesterday and can't seem to find it. I have the 2011 900, is that what you have?
Bobby.Digital is offline
post #6 of 17 Old May 24th, 2011, 11:08 AM Thread Starter
First Name: Kerry
Member #23427
go to E3sparkplugs.com and you can cross reference it there.mine is the 800.the champion #is RC7YC3 the E3 # is E3.64.
post #7 of 17 Old June 5th, 2011, 11:53 AM
Banned
hypa's Avatar
Member #26401
View hypa's Photo Gallery(0)
For those of us who don't have weekend access to the ps-4 oil the 2011 manual says to use, can we sub for Synthetic 0-40?
regarding the filter, I did a K&N cross reference, and the K&N pt# is HP-1010.
Any recommendations on the oil?
cheers.
hypa is offline
post #8 of 17 Old June 7th, 2011, 07:52 PM
GJRonK's Avatar
First Name: Ron
My RZR: 2011 800 EPS Graphite
Member #24461
View GJRonK's Photo Gallery(0)
cheers.
Many of us use Amsoil 10-40 small engine oil which is a synthetic designed for ATV's.
AMSOIL Formula 4-Stroke® 0W-40 Synthetic Motor Oil
GJRonK
GJRonK is offline
post #9 of 17 Old June 8th, 2011, 07:39 AM
tarp819's Avatar
Member #23828
View tarp819's Photo Gallery(0)
Hey guys quick question on the oil...When is a good time to change tran oils and diff. oils??
thanks you can pm or reply here thanks
i bought mine new and change motor oil at 25 hours like suggested. but all other is still in there.
tarp819 is offline
post #10 of 17 Old June 8th, 2011, 07:57 AM
Rzr spy
grant22's Avatar
First Name: Grant
My RZR: Currently Rzr Free
Member #1714
View grant22's Photo Gallery(0)
I don't remember what the book says, but here's what I do cuz of our dusty conditions in AZ:
First 25 hours: Repl all fluids and oil filter (break in)
Every 25 hours: Repl Motor oil (oil only)
Every 50 hours: Repl Oil filter (in addition to the oil)
Every 100 Hours: Repl ALL fluids and spark plugs
Basically, my oil gets repl every 25 hours. My Oil filter gets repl every OTHER oil change.
My plan/schedule is somewhat in line with the book, but my plan is a little more aggressive or conservative.
grant22 is offline
post #11 of 17 Old June 8th, 2011, 08:05 AM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Ethan, Every 100 miles you change the oil? I'd be changing my oil every weekend at that rate. With a clean air filter and a good oil filter you should be able to triple that easily. To each his own maintenance intervals...
For those asking about transmission fluids, your manual has the breakdown of what's needed and when. Should read it to get a better idea. As they say
FunRide is offline
post #12 of 17 Old June 8th, 2011, 08:13 AM
tarp819's Avatar
Member #23828
i dont have a manual or i would have read it. Does the transmission have two differnt oils? I just think i got a little water in mine this weekend bc it was puking out milky stuff sunday and figured i need to change the transmission oils. REalizing that i didnt wanna drain the wrong one is really where iwas going with my questions. Cause i just purchased a new one and just learning
about them
tarp819 is offline
post #13 of 17 Old June 8th, 2011, 08:18 AM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
about them
Yeah, sounds like a change is necessary for sure. You should download the real shop manual from here. Cliff has a link off his signature. Need to find you a link for that...
If you want to do the work now, just call a local dealer and tell them you need all the transmission fluids. Go with the Polaris stuff until you figure out less expensive alternatives if that's the route you want to take. Engine oil is different, but I'd stick to the specific Polaris oils for everything else. JMO.
Edit: Here's a direct link to the actual shop manuals from Tuf-Skin's signature: http://www.4shared.com/dir/28834101/...0/sharing.html
FunRide is offline
post #14 of 17 Old June 8th, 2011, 08:54 AM
tarp819's Avatar
Member #23828
ok thanks man!
tarp819 is offline
post #15 of 17 Old July 6th, 2011, 01:11 PM
grubdog's Avatar
Member #21108
View grubdog's Photo Gallery(0)
Will thay work on the 800s
grubdog is offline
Should I change my oil? CraigTard RZR XP 900 15 January 12th, 2012 03:34 PM
Front A-Arm Change 2/8/2011.. HIGHOCTANE RZR XP 900 8 October 13th, 2011 08:18 AM
First XP 900 oil change HAWK RZR XP 900 7 May 13th, 2011 07:31 PM
oil change 2011 rzrs bubbys toy RZR-S Specific Discussion 15 April 21st, 2011 07:21 AM
someone missed the BIG change for 2011 RZR' daranello General RZR Discussion 16 February 21st, 2011 06:55 AM
