2008 rzr not running right, no power... help - Polaris RZR Forum - RZR Forums.net
This is a discussion on 2008 rzr not running right, no power... help within the General RZR Discussion forums, part of the General RZR category; I just bought a 2008 rzr. The guy installed new fuel pump and some rzr s exhaust. Now the rzr will start and idle fine. ...
Old March 18th, 2011, 03:05 AM   #1
countryboy97's Avatar
Member #7648
View countryboy97's Photo Gallery(0)
I just bought a 2008 rzr. The guy installed new fuel pump and some rzr s exhaust. Now the rzr will start and idle fine. But when u drive it slow its fine, push the gas to make it go it pops and cuts out and acts like it cant rev and only goes about 35. At idle in park u can mash the gas and it will rev to 5000 rpms but it doesnt get there quick at all, it slowly climbs there.... Anyone had this problem???? I didnt know if u all thought it would be a fuel issue with not enough fuel pressure or an injector problem... Or maybe a cdi problem... Please help with ideas...
countryboy97 is offline   Reply With Quote
Old March 18th, 2011, 03:20 AM   #2
Purn1973's Avatar
First Name: Shane
My RZR: '09 RZR S
Member #7340
View Purn1973's Photo Gallery(1) Send a message via Yahoo to Purn1973 Send a message via Skype™ to Purn1973
Re: 2008 rzr not running right, no power... help
Does it have an aftermarket ECU? If so, unplug it and try it with just the stocker, also recommend checking the fuel pressure.
Purn1973 is offline   Reply With Quote
Old March 18th, 2011, 03:32 AM   #3
Member #7648
it is all stock other than exhaust and it is off a rzr... I am gonna check the voltage, i also read on here that low voltage can make it run bad so I am gonna check it in the morning.... I just hope nothing in motor causing power lose and popping
Old March 18th, 2011, 05:43 AM   #4
Feedback Score: 26 reviews
MotoXXX's Avatar
First Name: Jeff
Member #4542
Injectors are not a likely suspect, pretty trouble free. Do check your voltage and your fuel pressure. Fuel pressure should be 39 PSI.
MotoXXX is offline   Reply With Quote
Old March 18th, 2011, 07:29 AM   #5
SCFDRookie's Avatar
Member #11528
View SCFDRookie's Photo Gallery(0)
I'm having the same problem. I have a snorkel kit and almost close off all the intake and it runs fine. Not sure what that means.
SCFDRookie is offline   Reply With Quote
Old March 18th, 2011, 12:21 PM   #6
Member #7648
Thats about what mine was doing... My rzr also had a snorkel kit when I bought and I took it off and it is still running like that.... I have changed the plugs and they where like a brown burnt color if that helps any.... Like I said it will start and idle fine but no mid to top power at all. I am gonna start checking fuel pressure and voltage tomorrow... Someone had also mentioned that reflashing the computer may also take care of it, any truth to that????
Old March 18th, 2011, 12:27 PM   #7
Mad Scientist
martymoe's Avatar
First Name: Marty
My RZR: 08 RZR 800 & 12 RZR XP
Member #385
View martymoe's Photo Gallery(7) Send a message via MSN to martymoe Send a message via Yahoo to martymoe
if the fuel pressure is good, put a voltmeter on the output of the tps, make sure it goes through the range smoothly.
2008 RZR 800 (built apr 27 07)
2012 RZR XP 900 (built apr 21 12)
2000 Banshee
(4) 2000 Scramblers
(4) 2002 Blasters
20?? Eaton Rascal 40
martymoe is offline   Reply With Quote
Old March 18th, 2011, 01:36 PM   #8
Purn1973's Avatar
First Name: Shane
My RZR: '09 RZR S
Member #7340
Brown burnt color of plugs sounds like she is running lean. Check the fuel pressure...
Old March 19th, 2011, 01:12 PM   #9
Member #7648
ok, thanks everyone for the replies... I done a little checking this morning. Fuel pressure is at 40 when I turn key on on goes down to about 38.5 when running... Voltage is also good and charging good.... Pull injectors and one was dirty but not to bad. I cleaned them and reinstalled.... Pulled throttle body and it was dirty with black film... I cleaned it out with throttle body cleaner... I pulled sensor on top of rubber boot before throttle body and it was almost melted???? I cleaned it off but inner cover on sensor is gone... All it had was a few prongs and a little needle type thing hanging there.... Is this right or is it bad... Is it supposed to have a cover of some sort over needle??? anyways put it all back together, it is reving a little better but still popping through air cleaner and still no top end power???? Maybe a bad sensor on boot or maybe motor problems, any ideas???
Old March 19th, 2011, 01:40 PM   #10
Member #7648
also on code that is popping up is 25, which is invalid gear or something, but everyone on here says no big deal.... So no bad codes either...
Old March 19th, 2011, 05:16 PM   #11
Johnpeq's Avatar
Member #1490
View Johnpeq's Photo Gallery(0)
It sounds like your sensor is shot. I'm having a brain disconnect asto what it is call but it is between thw air filter and the throttle body. It gets fouled and sends bad readings to the ECU. I clean mine frequentlly when these symmptoms occur. It sounds like yours is beyond cleaning,
John
Johnpeq is offline   Reply With Quote
Old March 19th, 2011, 09:36 PM   #12
Mad Scientist
martymoe's Avatar
First Name: Marty
Member #385
its called a t-bap (temp barometric air pressure)
it is definately bad, but wont necessarily make it run bad it comes more into effect at high alt and really cold weather. ive tested it and it does very little for timing. you're popping back through the throttle body, thats why the t-bap is destroyed.
find out why it's popping back throught the throttle body, that is the root of the problem. btw, tps has a huge effect on timing, if it's messed up it will cause you to pop through the intake.
2000 Banshee
(4) 2000 Scramblers
(4) 2002 Blasters
Old March 20th, 2011, 11:44 AM   #13
Member #7648
Thanks for the help... Is the TPS the part that is melted on mine on that boot that goes from air box into throttle body???? or is it the throttle position sensor??? I probably need to check voltage on it and adjust like in forums....
Old March 20th, 2011, 02:50 PM   #14
Johnpeq's Avatar
Member #1490
When my sensor went bad I was seriously running rich, I fouled 2 sets of plugs. When it is bad it will give off a bad reading of altitude,
John
Old March 24th, 2011, 07:26 AM   #15
SCFDRookie's Avatar
Member #11528
Any news? Please let me know if you have found anything out....
09 rzr runs rough no power
2008 polaris 700 ranger no power
2008 polaris ranger 700 efi running issues
2008 polaris ranger no power
2008 polaris rzr 800 running rough
2010 rzr s not running right
700 polaris ranger xp not running right
polaris rzr 800 not running right
polaris rzr no power
rzr 700 no power rough idle
rzr 800 intake boot came off no power
rzr 800 no power
rzr 800 no.power
rzr popping through intake
Winch power leads and 1314 Sure Power tachdriver General RZR Discussion 4 November 22nd, 2010 02:49 AM
Anyone running E85? Farmtruck Engine and Drivetrain 0 May 25th, 2010 07:31 AM
Power Comander v for 2008 cowkicker84 Lighting, Stereo and Electrical 21 February 22nd, 2010 08:56 PM
2009 new S motor in 2008 rzr loss power rzrdog Forum Help, Questions and Info 6 February 1st, 2010 08:19 AM
Run a Power Commander V in a 2008? shoehound Engine and Drivetrain 1 September 8th, 2009 07:53 PM
