Bend ABS or PVC pipe? (snorkel) - Page 2 - Polaris RZR Forum - RZR Forums.net
This is a discussion on Bend ABS or PVC pipe? (snorkel) within the General RZR Discussion forums, part of the General RZR category; I bend pvc pipe all the time for saltwater tanks.. You can use a torch or heat gun.. Just keep it moving. ABS plastic can ...
Old March 11th, 2011, 09:06 PM   #16
8ball_99's Avatar
My RZR: 2013 Black RZR4 XP LE
Member #7209
View 8ball_99's Photo Gallery(0)
Re: Bend ABS or PVC pipe? (snorkel)
I bend pvc pipe all the time for saltwater tanks.. You can use a torch or heat gun.. Just keep it moving. ABS plastic can be heated and bent easily.. Yes its not rated for as high temps as pvc, But thats good in this case cause that just means it will bend with less heat... Go slow keep the heat source moving. Use a wet rag or compressed air to cool the pipe down to hold its shape.. If you use a heat gun blow hot air in the pipe and heat the outside.
Isn't is it a bit unnerving that doctors call what they do "practice"?
Why do we drive on the parkway and park in the driveway?
Problem with political Jokes is,, they get elected..
8ball_99 is offline   Reply With Quote
abs or pvc for snorkel
bend abs pipe
bend pvc pipe with truck exhaust
bending abs pipe
bending abs plastic with heat gun
bending abs with heat gun
can 3 inch abs pipe be heated and bent
can abs pipe be heated and bent
forming abs pipe
heat bending abs pipe
how to bend abs pipe
how to bend poly pipe
rzr abs pipe snorkel
shaping abs pipe
snorkel
Anyone design their cage with Bend Tech Pro Gundog Roll Cages and Safety Equipment 11 August 21st, 2016 06:05 PM
How do you bend Lexan? MossLager General RZR Discussion 8 May 20th, 2010 05:20 AM
Big Bend flyin7 Local Rides and Events 0 July 26th, 2009 10:05 PM
New air intake plus snorkel & exhaust snorkel THNKTWCE Projects and How-To 11 May 4th, 2009 01:02 PM
Sandfest July 8-13th in Coos Bay/North Bend Gypsy Local Rides and Events 4 August 8th, 2008 08:58 AM
