problem with 4wd -help
This is a discussion on problem with 4wd -help within the General RZR Discussion forums, part of the General RZR category; while riding yesterday i switched on the 4wd , the power light came on and the icon came on. then about 2 miles later when ...
Old August 24th, 2008, 01:34 PM
cwbonn's Avatar
ironhawkeye
My RZR: 2008
Member #3069
View cwbonn's Photo Gallery(0)
while riding yesterday i switched on the 4wd , the power light came on and the icon came on. then about 2 miles later when i needed it i noticed no front drive and the icon off but the 4wd switch still lit up so i checked the fuses, none blown, does anybody know what next to check, thanks for any help.
Old August 24th, 2008, 06:02 PM
TxHighroller's Avatar
My RZR: Gen 1
Member #2757
View TxHighroller's Photo Gallery(0)
Re: problem with 4wd -help
Check the fluid in the diff. If it is milky, the rollers may have rusted from the water in the diff. I had this happen to mine. Changing the fluid didn't do anything for mine. I opened the diff., removed the plastic cage and sanded all of the rollers. Runs good as new now. I check the front diff. after every water ride.
Old August 24th, 2008, 07:27 PM
jerrzr's Avatar
Member #1635
View jerrzr's Photo Gallery(0)
Since your 4wd icon went off, I'm thinking that you didn't have enough voltage at the diff. Check the voltage or you can try turning off your lights and accessories reving the motor to get the stator to charge because the charging system seems to have a hard time keeping up.
Old August 24th, 2008, 08:17 PM
angry rzr's Avatar
First Name: tony
My RZR: 2009 rzr
Member #3762
View angry rzr's Photo Gallery(0)
Old August 24th, 2008, 08:20 PM
angry rzr's Avatar
First Name: tony
My RZR: 2009 rzr
Member #3762
Mine is in the shop waiting to be serviced. My 4wd light stays on but it isn't engaged. When it is engaged it will slip and go back into 2wd. I took my RZR in once before for the same reason and was told everything was fine. I'm not taking that reason again. I know something is wrong!
Old August 25th, 2008, 05:13 AM
jerrzr's Avatar
Member #1635
If your problem turns out to be the front roll cage assembly, dont let them put the cheap plastic one back in. Go with the billet roll cage from Dragonfire. Its a high quality part that I feel wont let you down. Every time I break something, I never go back with the same part if I can help it. I broke an axle and went with gorrillas. I broke the plastic roll cage and went with the billet df. Just this weekend my buddy broke a tie rod and I was shocked to see how cheap it was; thin hollow tube steal. I'm not going to wait untill I break one Im already looking to see whats available as far as tie rods go, if any ideas somebody let me know
Old August 25th, 2008, 05:27 AM
stroker0836's Avatar
First Name: tom
My RZR: the green one
Member #2742
View stroker0836's Photo Gallery(0)
check with team products for front end parts, they have much more than just clutches.
  #8
Old August 25th, 2008, 10:04 AM
megadesertdiesel's Avatar
Feedback Score: 18 reviews
My RZR: None
Member #597
i just sleeved (cut stock in half and added 8") my stock tie rods with 1/2" schedule 40 pipe last week and since then i have raced and rolled the car. no more broken tie rods and a cheap fix. this is with my +8" suspension, lots more leverage than stock.
  #9
Old August 25th, 2008, 01:01 PM
cwbonn's Avatar
ironhawkeye
My RZR: 2008
Member #3069
i want to thank you for the ideas, the diagnostic mode indicated no current to the AWDcoil, then tested hub coil that showed no resistance at all 00.00 Ohms should be 24Ohms. its at the dealer now should be under warr.
  #10
Old August 25th, 2008, 03:49 PM
deanrowski's Avatar
Dr. RZR
First Name: dean
My RZR: 08 grn gen 2
Member #2036
View deanrowski's Photo Gallery(0)
Mine was doin the same! I read a post about taking apart the connection below the solenoid about 2" across and 3/4 thick and cleaning the terminals then filling it up with dielectric grease!! Problem solved has been working perfect ever since!! The connector is sitting kinda upside down and all the dirt and crap was going right in so I also cut the zip tie and moved it around!! If you take it apart you will see that it's full of dirt!! Also helps if your not getting the proper Icon showing up for gear selection!!
2008 polaris ranger 4wd coil problem
4wd cage for polaris rzr
arctic cat 4wd cage assembly
awd problem solved
polaris rzr 4wd coil
polaris rzr 4wd problems
polaris rzr four wheel drive problems
polaris rzr problems getting it into 4wd low
problems polaris 4wd
rzr no power to lights accessory 4wd
rzr s 4wd problem
rzr s 4wd support
HID problem X_Da_C Lighting, Stereo and Electrical 23 September 18th, 2008 10:47 PM
Anybody Have This Same Problem??? r6realtor General RZR Discussion 3 September 18th, 2008 10:06 AM
Rzr S Problem..... simadownow6988 General RZR Discussion 3 September 8th, 2008 03:04 PM
First problem with RZR USMCSKI General RZR Discussion 7 June 3rd, 2008 04:21 PM
Anyone else have this problem? ms_jetset General RZR Discussion 12 May 30th, 2008 02:14 PM
