Do you plow with the RZR? Damage it at all? - Polaris RZR Forum - RZR Forums.net
This is a discussion on Do you plow with the RZR? Damage it at all? within the General RZR Discussion forums, part of the General RZR category; I thought we might do a poll as to who plows and whether they have done any damage to the plow. This isnt meant to ...
View Poll Results: Did you do any damage to the plow?
Yes I did. 18 20.93%
No I didn't. 52 60.47%
I did but it wasn't setup properly first. 4 4.65%
I didn't but I setup everything myself beforehand. 12 13.95%
Voters: 86. You may not vote on this poll
Old February 3rd, 2011, 01:26 PM   #1
Tiorum3's Avatar
First Name: Al
Member #10509
I thought we might do a poll as to who plows and whether they have done any damage to the plow. This isnt meant to be a b*tch session about a particular manufacturer but to try and figure out a good set up which works.
I have definitely damaged mine. I did it because the spring tensioners weren't tightened enough. You need to make sure you have them pretty darn tight. Anybody have some other tips or tricks?
http://i265.photobucket.com/albums/ii202/Tiorum3/Allegheny%20off%20road/aor-stickerjpeg_zps3be9880e.png
see our website for more product details at: www.alleghenyoffroad.com
Tiorum3 is offline   Reply With Quote
Old February 3rd, 2011, 02:05 PM   #2
Bernie_II's Avatar
First Name: Brian
My RZR: 08' RZR
Member #20012
View Bernie_II's Photo Gallery(0)
Re: Do you plow with the RZR? Damage it at all?
There seems to be a lot of snow plow conversations today...must have something to do with the big storm that hit the country yesterday.
I haven't had any real damage in the 4 seasons that I've been plowing with my RZR and a Polaris Glacier 2 plow until yesterday. I was pushing through some large drifts, probably driving too fast, when I caught a new pot hole. The right corner of the plow got caught in such a way that even though the springs released it hung up awkwardly and did some real damage. The right side of the mount snapped under the winch and the right side of the plow quick release got bent pretty good. At least it gave me a good excuse to pull out the torch and welder!
I can't fault the glacier plow setup, when it snapped yesterday it definitely broke the two weak points in the connection. But from what I can tell it didn't bend the frame at all and the connection points that broke were fairly easy to repair.
My advice to avoid that particular situation is to just slow down. I was so excited yesterday that I was able to push through 3 and 4 foot drifts with the RZR that I just started going faster and faster until I broke the plow. On top of that I had my wife out taking pictures so I had to "show off" a little. With my wife watching and listening to a little AC/DC on the stereo I tend to drive faster than I should.
Here's what I would recommend for the Glacier 2 setup:
For standard RZR owners I'd suggest a lift to get the front end off the ground a little more
A 2nd battery setup or possibly a stronger alternator may be needed if you're going to do a lot of plowing
I'd replace the plow springs with something a little stronger
Get a good winch (Polaris or Warn) with good control that you can easily use while driving
Good tires - traction is everything
Lights - if you do a lot of night plowing put some floods up high
Bernie_II is offline   Reply With Quote
Old February 3rd, 2011, 02:10 PM   #3
Banned
itsruf's Avatar
First Name: Mark -
Member #16159
I want to see plow videos. We need a contest where anyone who can prove a RZR can actually plows snow wins something.
itsruf is offline   Reply With Quote
Old February 3rd, 2011, 02:21 PM   #4
ridgerunner's Avatar
First Name: Terry
My RZR: Standard
Member #5561
View ridgerunner's Photo Gallery(0)
I use to plow with an atv. When I bought the RZR last spring I decided to not put a plow on it. Instead I bought a used plow set up for my old 90'
F-150. It cost me $800 installed. Better use for the money spent IMO. It plows better than any RZR could dream. Yesterday I found out where my neighbors sleice pipe ended, had to get pulled out.
ridgerunner is offline   Reply With Quote
Old February 3rd, 2011, 05:01 PM   #5
Banned
itsruf's Avatar
First Name: Mark -
Member #16159
Question..
Are you able to drop the blade, via the hydraulics, lift the front end and front tire, at least a little, and back out of that.
When I'm plowing with a tractor, you can use the loader bucket to get you out of a lot of "sticky situations".
Ya, when you plow with anything you have to push that snow out somewhere and duh, there are holes, ditches, voids, etc. Plowing aint easy. Every drive is different, tons of scenarios.
Old February 3rd, 2011, 05:31 PM   #6
BatRazor
BatRazor's Avatar
First Name: Tim
My RZR: Gen 1 Red
Member #1516
View BatRazor's Photo Gallery(0)
I run the Polaris set up. Haven't had any trouble
with it. Money well spent. One thing I did was
I bought the Polaris shifter knob that has a button
on the front of it. It powers the winch. This way it's
easy to run the winch.
BatRazor is offline   Reply With Quote
Old February 3rd, 2011, 06:22 PM   #7
clemzexp6969's Avatar
First Name: Adam
My RZR: 2008 RZR
Member #14853
View clemzexp6969's Photo Gallery(0)
ive got a custom plow setup and this snow storm with 17 inches was the death of it. its a cycle country blade which held up, but the plow brackets we made just werent strong enough and are bent all to heck. the snow froze overnight which caused more damage to the plow. my buddy has a glacier 2 setup and he manaaged to hit a rock because you coulnt see anything and bent his as well. we will both be beefing these things up and i will post before and after pics of both. theupper bumper brackets also bent from taking some of the force of the plow so we will have to address that as well.
clemzexp6969 is offline   Reply With Quote
Old February 3rd, 2011, 06:49 PM   #8
Tiorum3's Avatar
First Name: Al
Member #10509
That sounds like a great idea. I didnt even know they made that. Its kind of a pain to have it dangling off the T bar.
I think it also depends on how big a job you are trying to tackle. A "regular" driveway or a short driveway would be easy on the plow, I think its the bigger driveways that I think it can get overwhelmed by. More specifically, I think its when you get a lot of snow- over a foot or more, its time to have to call a plow service.
I have about the worse case scenario- a quarter mile long driveway, a good size parking area, and in front of the house parking. A large job indeed.
Old February 4th, 2011, 04:41 AM   #9
thewyseone's Avatar
First Name: chris
My RZR: 2009 rzr neuclear sunset edition
Member #8098
View thewyseone's Photo Gallery(0) Send a message via Yahoo to thewyseone
i use to plow with a 94 polaris sport 2X4,needless to say it wouldnt plow anything remotly heavy which was fine as we had a freind who would plow.
then in 97 i bought a kawasaki prarie 4X4,it plowed better and used it till 2009.i had a good bit of plowing to do with it for home and the buisness,never damaged the machine.damage to the plow was replacing the a-frame once,the plow blade once and bought new springs.the plow was a cycle country.
in 2009 i had to trade in the kaw on my rzr and was going to buy a plow for it but my dad was like dont tear up you machine,i'll put one on my sportsman 850 XP.so i agreed,wish i hadnt.had to put chains on the 850 to plow,just on rear so no i get better traction but now it dont turn.
last winter i mostly used a case 1840 for plowing,its for where i work but i live next door but its been at another location since fall.i really need to stack some snow now.
as long as its installed properly and all bolts are tight it shouldnt cause any damage to the machine,unless your ramming into snowbanks at break-neck speeds!
2009 neuclear sunset orange LE,looney tuned duals,two brothers juice box,UMP air cleaner,racer tech 2 inch lift,2 inch wheel spacers,utv crap 60 amp alternator kit,EPI clutch,factory utv doors,jensen radio,pyle 600w amp,tantrum tubbies and billet bling.
thewyseone is offline   Reply With Quote
Old February 4th, 2011, 05:45 AM   #10
Devil Dog's Avatar
First Name: Devil
My RZR: RZR 800
Member #17708
View Devil Dog's Photo Gallery(0)
Question..
The pistons on plow blades for most pick up trucks power up/right/left but dont power down.......its just gravity from the weight of the blade that brings it down.
Therefor you cant use the blade to lift yourself outta that situation like you can on a bucket for a tractor or back hoe or loader which most of them have power on every movement.
GOD BLESS AMERICA
Devil Dog is offline   Reply With Quote
Old February 4th, 2011, 05:46 AM   #11
First Name: Terry
My RZR: Standard
Member #5561
Question..
No, it's pretty much gravity going down- no down pressure like a tractor. The truck sat on the frame in the pic after dropping into the ditch, couldn't go forward or backwards. Now I know where not to go next time. Yes there is a learning curve while plowing somewhere new. I carry a come along with extra wire rope in my tool box in the truck. The problem was that the truck was twisted somewhat and I couldn't get into my box, it wouldn't open!
Old February 4th, 2011, 06:58 AM   #12
rky60's Avatar
My RZR: 2010 Orange RZR S
Member #14234
View rky60's Photo Gallery(2)
My first winter ever using a plow, got the Glacier II setup. So far the RZRS/Plow combo have worked flawlessly, not a single complaint. It's just been awesome in the snow all around.
I pushed clear a months worth of several snow events that built up to about 15" in my father-in-laws yard the other day, mostly refrozen harder snow. He hopped in to try it out, then afterwards I went home and put better security on the shed. I got the feeling he'd be breaking and entering later that night
rky60 is offline   Reply With Quote
Old February 4th, 2011, 10:50 AM   #13
Smoke14's Avatar
My RZR: 11 RZR LE
Member #18119
View Smoke14's Photo Gallery(0)
I purchased the Motoalliance plow setup for my 11 RZR LE. Install was good, also got the winch with synthetic cable. One thing to watch is wear on synthetic cable, I ended up buying a 15' tow strap and cutting it to make 2 lift straps and that is what I use now for the plow.
The only damage I have encountered was when I first used the plow. Finished my small driveway and decided to drive down half a block around corner and come back to do front of road. As I was going (around 20 mph), the lift hook snapped off and dropped the plow. Come to find out it was not welded on both sides of hook block, just one. So make sure to inspect your setup regularly, check tightness, spring tension, cutting edge, etc...
Smoke14 is offline   Reply With Quote
Old February 4th, 2011, 10:57 AM   #14
Feedback Score: 16 reviews
guy48065's Avatar
Member #309
This is my 2nd year using a 2" web strap wrapped on the winch to lift the blade. So far no sign of wear to the strap. BUT a couple weeks ago I ripped the stitching right out of the D-ring end. Tied it in a knot & it's still going strong all through the recent "snowmageddon". Damn that's a LOT of weight the winch has to lift.
guy48065 is offline   Reply With Quote
Old February 4th, 2011, 03:16 PM   #15
Tiorum3's Avatar
First Name: Al
Member #10509
I like the idea of a tow strap as a replacement of the cable, but if I need to use it to winch myself I'll need more than 15 feet. I bought the moose winch cushion which helps on the wear on the synthetic rope. Seems to help as I have gone too high by accident a couple of times. I recommend one to anyone using synthetic rope or a cable.
can polaris razors plow snow
can u put a snoe plow on a rzr 1000
can you put a plow on a polaris rzr
can you put a plow on a polaris rzr 800
can you put a plow on a polaris rzr 900
can you put a plow on a razor
can you put a plow on a rzr
can you put a snow plow on a razor
can you puta snow plow on a polaris sportsman?e
does. a lift damage. a polaris rzr
how come no one puts a plow on a rzr
plowing with a rzr 1000
polaris rzr plow down pressure
polaris rzr snow plow
rzr plowing snow
Glacier II Plow remote plow angle changer diamondwash Projects and How-To 3 February 21st, 2011 08:23 AM
Glacier II plow mods for 72 inch plow brads rzrs General RZR Discussion 15 December 15th, 2010 07:11 AM
snow plow damage sherrayrzr Member Introductions 18 January 17th, 2010 01:56 PM
Possible engine damage??? jaydog General RZR Discussion 20 January 13th, 2010 11:46 AM
Wtb plow and plow mount and winch Ballzout Want to Buy 0 August 16th, 2009 09:04 PM
