Rear axle seal - Polaris RZR Forum - RZR Forums.net
post #1 of 28 Old August 15th, 2008, 10:34 PM Thread Starter
RAISING HELL ON THE TRAIL
hellrazor's Avatar
First Name: Greg
My RZR: 2014 RZR
Member #853
Feedback Score: 12 reviews
View hellrazor's Photo Gallery(0)
Rear axle seal
My rear axle seal on the passenger side started leaking like every other one out there so I pulled the axle out to see if it may have been a simple fix like dirt or seal replacement. The seal is pressed in prety good so Im not going to try to remove it until I get another one on hand to replace it incase I damage it.The seal looked fine with no tears but I noticed a circular spring shaped like a ring the same diameter as the seal that was just hanging around the seal.It looked like the spring went into the seal to keep pressure on the axle as it turns to get a tighter fit I guess.Does anyone know what Im talking about and if I am correct then how do you get that spring back into the seal. Plaease give me a fix I have a big ridding trip comeing up in two weeks.
hellrazor is offline
post #2 of 28 Old August 16th, 2008, 06:19 AM
hoodlum's Avatar
Member #660
View hoodlum's Photo Gallery(0)
Re: Rear axle seal
The spring does go in the seal, but if it's out, it won't stay in if you put it back....Get a new one...They are only like 5 bucks if I remember correctly......
Hoodlum
2 1989 Honda pilots
2008 Polaris rzr
hoodlum is offline
post #3 of 28 Old August 16th, 2008, 07:54 AM Thread Starter
hellrazor's Avatar
First Name: Greg
My RZR: 2014 RZR
Member #853
Re: Rear axle seal
Hoodlum
Thanks hoodlum I can spair the $5.00
post #4 of 28 Old August 16th, 2008, 08:57 AM
wheeler34man's Avatar
My RZR: 2007
Member #269
View wheeler34man's Photo Gallery(0)
Re: Rear axle seal
Any way you can get a picture? I got a leaky seal too. Can you Let us know how it much of a pain it is replacing the seal? Thank you!
wheeler34man is offline
post #5 of 28 Old August 16th, 2008, 09:10 AM Thread Starter
hellrazor's Avatar
First Name: Greg
My RZR: 2014 RZR
Member #853
Re: Rear axle seal
I have not replaced it yet but when I do I will try to put up picks.
post #6 of 28 Old August 16th, 2008, 07:00 PM
Grumpy Rider
Grumpy Rider's Avatar
Member #750
View Grumpy Rider's Photo Gallery(0)
Re: Rear axle seal
I replaced my seal. It was an easy job, took maybe 45 minutes the first time. I'm pretty confident I could do it faster now that I have done one. Be sure to replace with the orange color seal when you do replace them. The black ones tend to be the ones with the leaking issues. It is my understanding that Polaris changed the compound of the rubber seal with the orange ones.
Grumpy Rider is offline
post #7 of 28 Old August 16th, 2008, 07:41 PM Thread Starter
hellrazor's Avatar
First Name: Greg
My RZR: 2014 RZR
Member #853
Re: Rear axle seal
Thanks for the info.
post #8 of 28 Old August 17th, 2008, 08:59 AM
My RZR: 2007
Member #269
Re: Rear axle seal
So obviously you pull the axle off and can you explain a little about how you got the old seal out and how you put the new one in? I assume it's a press fit. I'm not near my machine so I can't look. Any help you can provide would be way cool! Thanks!
post #9 of 28 Old August 17th, 2008, 10:18 AM
Grumpy Rider
Member #750
Re: Rear axle seal
They say you use a seal puller for the seal removal. I used a small claw hammer and it flipped right out. (Be sure you insert into the inner circle, the area where the axle would insert and not the area where the seal mates with the metal edge of the diff.) Popping the new one back in was easy to. I centered it up as best I could by hand and then tapped it lightly with a wooden mallet. Then re-install your axle.
post #10 of 28 Old August 17th, 2008, 11:17 AM
My RZR: 2007
Member #269
Re: Rear axle seal
Thank you very much!
post #11 of 28 Old August 18th, 2008, 05:16 AM
My RZR: 2007
Member #269
Re: Rear axle seal
Ok I looked at my machine yesterday and I got a couple questions for ya. How the heck did you get a hammer into the seal to pull it out? The inner shaft and it's splines are right there. Didn't you booger up the shaft when you popped the seal out?
post #12 of 28 Old August 18th, 2008, 11:56 AM
RedMan's Avatar
Member #276
View RedMan's Photo Gallery(0)
Re: Rear axle seal
My local dealer says he has sold over 100 rear seals for the RZR.
He actually asked me if I needed one yet.
Sounds like yet another problem.
RedMan is offline
post #13 of 28 Old August 19th, 2008, 04:54 AM
hoodlum's Avatar
Member #660
Re: Rear axle seal
The splined shaft is on the cv joint, and comes out with the axle.....Another way of removing is to drill a small hole in the part of the seal that has the metal ring in it, put a small sheetmetal screw in there, and it gives you something to grab on too with the hammer claws....
Hoodlum
2 1989 Honda pilots
2008 Polaris rzr
hoodlum is offline
post #14 of 28 Old February 20th, 2010, 05:30 PM
cookie3348's Avatar
First Name: David
My RZR: 09 le stleath black
Member #11321
View cookie3348's Photo Gallery(0)
Re: Rear axle seal
Recently installed 3" extreme lift kit on 09 LE RZR. Left rear boot on axle started leaking took to dealership and replaced boot. dealership said problem was in the boot. After another ride same boot started leaking again. Again replaced boot because dealership said that was the problem. Once again the boot started to leak. Talked with dealership & replaced rear axles with gorillas. Went on trail ride (semi-rough) and ripped both boots on rear. Is this a differential problem and not an axle problem?
cookie3348 is offline
post #15 of 28 Old August 23rd, 2013, 06:44 PM
wamorim's Avatar
Member #8400
View wamorim's Photo Gallery(0)
Re: Rear axle seal
Anyone have some good pictures or video of removing the rear seal. I have been trying for the last hour. I know it should be simple but I just can't get it out. Anyone have a part number or know where to find a seal puller
wamorim is offline
NEED RIGHT REAR INNER CV or Complete rear axle rzrgrl Want to Buy 5 February 16th, 2009 08:05 PM
right rear seal leaking 06vegas Engine and Drivetrain 9 January 2nd, 2009 08:03 PM
need rear axle rzrmiami69 Want to Buy 2 December 21st, 2008 06:50 PM
rear left axle futuredenied Want to Buy 4 November 13th, 2008 07:05 PM
Rear Axle Troubles jpmill Engine and Drivetrain 1 July 10th, 2008 11:33 AM
