Hello, I installed a Terra 45 on my rzr and installed a toggle switch instead of keyed power for the supply/control wire to the remote and rocker switch. Should I put a fuse where this wire connects to power and how many amps should it be? It looks like small 18 ga or thereabouts so shouldn't take much to cook it if something went wrong.
The control wire wouldn't require anything more than a 5 amp fuse and even that will be slightly overkill. Energizing the coil on the solenoid will draw next to nothing.
