This is a discussion on Who is using the DF air filter system? within the General RZR Discussion forums, part of the General RZR category; Does the DF use the stock boot to the throttle body?...
#31
Re: Who is using the DF air filter system?
| Sponsored Links | ||
#32
Yea I Want To See The Hook Up
Polaris RZR - build date - 6-15-2007 - Black ITP True Beadlock Wheels with Polished Rings.26"- 6x9x14 front, 6x11x14 Maxxis Bighorn Tires rear, 1.5” adapters - total width in rear of 63" |
#33
yes it uses the stock boot, But here is the kicker. WHEN MOUNTED TO THE STOCK LOCATION (frame) the boot lets dirt by, because it creates a pivot point from frame to motor. Everytime you give it gas the engine/tranny assembly rocks back and forth from the engine tourqe. Our system Mounts to the engine tranny assembly so it moves with the assembly every time you give it gas, thus taking out the pivot point. That and the Filter is about 4 times as big as the stock filter
#34
Yes it does use the stock boot. But because the canister is bolted to the transmission its virtually impossible for it to come off because the distance between the canister and throttle body cannot increase, if you see what I mean. I think the cyclone also goes more into the boot itself. As good as the filter and cyclone itself is, it's also the mount that makes it such a rock solid solution to all of the weak points in the stock setup.
#35
That whole engine rocking and pulling the boot apart deal is BS...If you have the back off of your machine and give the thing some hard gas you'll see the engine rotates towards the air box , pushing the boot on tighter...The people that have had problems with boots popping off is because with every new toy or race machine you have to go over it every now and then and check to see whats tight and lose.. Our boot clamps on both our new RZR's were lose enough to move with your fingers new...
#36
I also noticed the DF (BTI) aircleaner aluminum housing fits snugger and seems to go further into the stock rubber boot. The aircleaner even has a notch (cut out) to accomodate what looks like an air sensor near the end of the stock rubber boot; this alows the boot to be pushed further on to the airclear housing. The mount is also rock solid.
#37
Its not BS, it doesnt matter which way the engine flexes, either toward the airbox or away from it either way it creates a tiny gap for dust to be sucked in.
#38
Hey, just got mine yesterday. Very impressed with the quality. Went to install it, noticed I'm missing the crankcase filter. When't ahead and installed anyway. Started it up. Sounds quiet. I have the snorkle version. By the way, can someone tell what kind of filter this is, I hopefully I can pick up one. Want to ride to tomorrow. Thanks in advance. I too got tired of waiting on Polaris, didnt want to take a chance on messing the motor up. Cause Polaris parts are high. Mine only has 5 hrs on it ( in the yard).
#40
It's a tight fit I recall, at first I thought it wasn't going to fit, but just wiggle and wiggle and she'll slip into place.
#41
Bump
Georgia4x4 does the bobcat filter have 3" intake & outlet? What did you use to connect it to the throttle body? I was planning on using the stock boot but I struck out with the Baldwin filter pictured above--it's discontinued and they haven't updated their website in a year
![]() My runner-up Donaldson G070017 is longer than stock so I may have to replace the boot, too. --This is all assuming I don't give up this time-consuming search and just buy the UMP & get on with life.
_______________________________ Why buy the cow? Romeo, MI |
#42
The filter can outlet is 1/4" larger than the Throttle body. The Air inlet to the Can is 3"..I spent several hrs at a Auto parts place measuring Radiator hose's. I did find one the fits the throttle body and steps up to the air box, with the correct bend. I used 3" hose from the can to the EHS secondary box..
#43
Been there, done just that! Good idea!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| MCX Turbo System compared to Aerocharger System | jaywebguy | Forced Induction | 65 | June 26th, 2009 08:02 AM |
| Ssv system | RZR-SHREDER | Lighting, Stereo and Electrical | 3 | January 13th, 2009 06:02 AM |
| 09 air system | Gerry Roach | Engine and Drivetrain | 4 | December 2nd, 2008 06:11 PM |
| AFE intake system | moneypit | RZR's and Parts | 3 | August 10th, 2008 02:01 PM |
