Super ATV rear bumper BIG issue - Polaris RZR Forum - RZR Forums.net
 3Likes
  • 1 Post By CincyRZR
  • 1 Post By bbyers
  • 1 Post By filthyredneck
post #1 of 12 Old May 18th, 2017, 08:27 PM Thread Starter
CincyRZR's Avatar
Member #163673
View CincyRZR's Photo Gallery(0)
Went to install a new super atv rear bumper on my 2017 XP 1000 and ran into a major issue.
I removed the radius bolts and mounting plate. Cut the heat shield and drilled the frame just like instructions said.
Then went to install lower bumper and found that the supplied bolts M10's are smaller diameter than what the stock radius arm bolts are. My stock bolts won't fit thru the bumper holes or the spacers. Of course the supplied M10s have to much slop in the radius are sleeves.
My suspicion is super atv doesn't know the radius arms on the reflex blue 2017.5 are the same size as Click image for larger version
ID:	425017the larger turbos. And this larger mounting bolts.
I really don't want to drill the bumper, the spacers and go find longer stock diameter bolts.
Or am I missing something?? Can bolts that don't fill the sleeves be used?? Doesn't seem right.
Pic shows my stock diameter bolt not fitting thru bumper. Other pic shows diameter of largest supplied bolt and slop in sleeve.
CincyRZR is online now
post #2 of 12 Old May 18th, 2017, 08:46 PM
I Like It Dirty!
filthyredneck's Avatar
First Name: Justin
My RZR: 2015 RZR 1K HLE
Member #46044
View filthyredneck's Photo Gallery(0)
Re: Super ATV rear bumper BIG issue
I think they just aren't aware the bolts have been upgraded to M12 on the newer machines. I think you're limited to either drilling the holes out in the bumper plate, or finding/fabricating a sleeve for the M10s they sent you.
Sent from my SM-G920V using Tapatalk
11' Renegade 800 XXC
15' RZR 1000 HLE
Get Filthy OR Go Home!
filthyredneck is online now
post #3 of 12 Old May 18th, 2017, 09:17 PM
warrenhdavis's Avatar
Member #99161
View warrenhdavis's Photo Gallery(0)
I just drilled out my bumper to fit the new bigger 12mm hole bolts. Good luck holding the nuts on the inside now that they are bigger too. I gave up and still have not mounted my rear bumper on my 2017 XP Turbo
warrenhdavis is offline
post #4 of 12 Old May 18th, 2017, 09:19 PM
bbyers's Avatar
Member #175225
View bbyers's Photo Gallery(0)
same thing happened to me when i installed my hitch on my 17 turbo. I ended up just drilling out the hitch.
1999 Bombardier DS650, 2017 XPt4, 2016 570 SP Ace
bbyers is offline
post #5 of 12 Old May 19th, 2017, 04:56 AM Thread Starter
CincyRZR's Avatar
Member #163673
Thanks all. Confirmed my suspicion. Guess I'll drill the parts out and find the longer M12 bolts. I bolted it back up stock to ride this weekend and yeah it was a pita to tight those back up. Just a really frustrating waste of 4 hours. Super atv should be much better than that!
generaljls likes this.
post #6 of 12 Old May 19th, 2017, 05:02 AM
cyclereckr's Avatar
First Name: Greg
My RZR: 2011 900XP, 2013 RZR4 800LE,
Member #25862
View cyclereckr's Photo Gallery(0)
I bet Super ATV will make it right if you contact them !
cyclereckr is offline
post #7 of 12 Old May 19th, 2017, 05:27 AM
bbyers's Avatar
Member #175225
LOL!!! those bottom two nuts SUCK! I ended up getting my little boy to help, little hands and arms helped a lot.
CincyRZR likes this.
bbyers is offline
post #8 of 12 Old May 19th, 2017, 06:34 AM
I Like It Dirty!
First Name: Justin
Member #46044
Hold backup on what nuts? I welded these 1" long threaded inserts in and don't have to fight that battle anymore.
15' RZR 1000 HLE
post #9 of 12 Old May 19th, 2017, 01:46 PM
Sunden's Avatar
First Name: Dennis
My RZR: 2016 RZR XP 4 Turbo
Member #67643
View Sunden's Photo Gallery(0)
That's what Polaris should have done in the first place. Where did you get those?
2016 RZR XP 4 Turbo
2015 RZR 1000 XP 4 Sold!
2013 RZR 900 XP 4 Sold!
Sunden is offline
post #10 of 12 Old May 19th, 2017, 01:57 PM
I Like It Dirty!
First Name: Justin
Member #46044
HESS Motorsports. They offer both the M10 & M12. The 10s cost about $75 after shipping, but well worth it
15' RZR 1000 HLE
post #11 of 12 Old May 19th, 2017, 02:18 PM
Sunden's Avatar
First Name: Dennis
Member #67643
Thanks for the info.
2016 RZR XP 4 Turbo
Sunden is offline
post #12 of 12 Old May 19th, 2017, 04:22 PM
I Like It Dirty!
First Name: Justin
Member #46044
No prob bud
15' RZR 1000 HLE
Anyone gone from toy hauler to RV and regretted it? orangecrush Tow Rigs, Trailers and Camping 131 May 4th, 2017 10:11 AM
SuperATV rear bumper issues. Lobo RZR XP 1000 21 April 4th, 2017 10:46 AM
Super atv rear window Buckeye Fan Super ATV 3 December 5th, 2016 06:58 AM
anyone with super atv front bumper white ? popo2012 RZR S 900 0 October 27th, 2016 06:27 AM
