Plow winch cable breaking - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old December 19th, 2010, 10:14 AM Thread Starter
partyboy424's Avatar
Member #20640
View partyboy424's Photo Gallery(0)
Hi,
I usually like to work on the side of caution. I've read multiple different threads on winch cables breaking/fraying and the synthetic stuff constantly breaking. I got the Warn 3500 for my new Rzr and the Glacier 2 Plow setup. This came with the synthetic rope. I've never had a winch before... but this synthetic stuff just looks extremely weak, especially for the amount of use it will get from plowing.
So I did some searching online and found this Neiko #51005A 2" X 20' Tow Strap
It's 20ft long and is rated for 10,000 pounds, about 10$ on the site at the time. I cut this roughly in half, maybe a little shorter and threaded this onto the winch by just unspooling the synthetic stuff all of the way out and taping this onto it. Like snaking a wire. Here's some pics. I doubt this will be breaking. Also, The hooks have those snaps so it will stay connected to the plow if there's too much slack in the line. I then wrapped up the remaining synth line and tucked it in up under the hood storage. which you can kind of see in the pics (camera phone)
ID:	23493   Click image for larger version
partyboy424 is offline
post #2 of 12 Old December 19th, 2010, 01:11 PM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Re: Plow winch cable breaking
Party...I used a syn rope for lots of plowing for two winters, no problems except for once when I wasn't paying attention and hit the wrong button.....broke the rope. You just tie it back onto the plow if it breaks.
You'll have to make sure that your cord doesn't get all wound up by accident, or pulled out and tangled into the front tires.
FunRide is offline
post #3 of 12 Old December 19th, 2010, 01:23 PM
HIGHOCTANE's Avatar
Member #16360
I think I would hook the strap to the end of the winch rope(take the hook off)...should be enough room on the drum for no more than you would need for raising and lowering a plow right?
HIGHOCTANE is offline
post #4 of 12 Old December 19th, 2010, 02:20 PM Thread Starter
Member #20640
Yes there looked like there'd be enough room to just connect to the end of the line. But winches make the most power with as few wraps around the drum as possible. I know it's not much, but anything to extend the life of my toys I try to do. Figure this way there will be less strain on the winch motor in the long run.
post #5 of 12 Old December 19th, 2010, 02:25 PM
HIGHOCTANE's Avatar
Member #16360
True...but is raising and lowering a plow that much of a strain on the winch? I just wouldn't want a bird's nest of rope that is still hooked to the winch laying in my storage compartment.
post #6 of 12 Old December 19th, 2010, 03:51 PM
Waistdeep's Avatar
My RZR: 2011 RZR Camo
Member #18687
View Waistdeep's Photo Gallery(0)
I think that is a great idea, thanks for sharing.
Waistdeep is offline
post #7 of 12 Old December 19th, 2010, 03:56 PM
HIGHOCTANE's Avatar
Member #16360
BTW...I could see how my post might sound negative..wasn't meant to be. Thanks for sharing your idea.
post #8 of 12 Old December 19th, 2010, 04:27 PM Thread Starter
Member #20640
No problem Highoctane, it never hurts to take others advice. I just saw so many other threads about this problem even across a lot of the other atv boards that I figured someone might be looking for a quick write up for a cheap and relatively long term solution. I have the bundle of extra line tied up under the hood so I'm not worried about it coming undone and wrapping around anything. Also I'm constantly checking over all of my parts for loose bolts and cracks that I'll be checking it often enough in case something did manage to go wrong.
post #9 of 12 Old December 19th, 2010, 05:56 PM
Tiorum3's Avatar
First Name: Al
Member #10509
I'm about to start running a plow and was worried about this. Thanks for the idea!
http://i265.photobucket.com/albums/ii202/Tiorum3/Allegheny%20off%20road/aor-stickerjpeg_zps3be9880e.png
see our website for more product details at: www.alleghenyoffroad.com
Tiorum3 is offline
post #10 of 12 Old December 19th, 2010, 08:30 PM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Nah, doesn't sound negative at all. Just giving him an idea.
FunRide is offline
post #11 of 12 Old December 19th, 2010, 08:55 PM
guy48065's Avatar
Member #309
Feedback Score: 16 reviews
Great idea...wish I'd thought of it.
guy48065 is offline
post #12 of 12 Old December 19th, 2010, 09:02 PM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Need to find a good way to manage the cable if you take the proposed route....Maybe zip-tie it up real tight and keep an eye on it. Last time I tried to do something similar in a particularly muddy area (to have rope at the ready for impending burial) the rope was a nightmare to manage and got all wrapped into the front drive. Something to consider anyway.
FunRide is offline
Winch Solenoid Breaking Firewall IceCactus General RZR Discussion 7 November 21st, 2010 09:43 PM
winch cable 08 redrzr General RZR Discussion 6 March 4th, 2010 07:41 AM
Winch cable rubbing Tlake Forum Help, Questions and Info 5 October 22nd, 2009 05:59 PM
Wtb plow and plow mount and winch Ballzout Want to Buy 0 August 16th, 2009 08:04 PM
winch cable bajarzr General RZR Discussion 1 March 3rd, 2009 06:29 PM
