What oil do you guys like? - Polaris RZR Forum - RZR Forums.net
 8Likes
post #1 of 25 Old March 20th, 2017, 06:50 PM Thread Starter
JRush311's Avatar
Member #183209
View JRush311's Photo Gallery(0)
2016 900s here purchased used(barely) I have 240 miles on it and began researching oil changes.
It seems Polaris brand oil may be somewhat inferior.
What do you guys recommend ?
I was wanting to ride Saturday but now I'm wanting to check and replace engine oil trans oil and front diff oil , anything else ?
JRush311 is offline
post #2 of 25 Old March 20th, 2017, 07:18 PM
Diamond K's Avatar
My RZR: 2013 900 XP4 LE
Member #71671
View Diamond K's Photo Gallery(19)
Re: What oil do you guys like?
My 2013 XP4 has 3400 miles and has only been serviced by my local dealer using Polaris oil.
That is what I will continue to use.
Diplomacy is the art of making a point without making an enemy.
Diamond K is offline
post #3 of 25 Old March 20th, 2017, 07:27 PM
gmiller0737's Avatar
First Name: Gordon
My RZR: 2012 RZR 570
Member #47617
View gmiller0737's Photo Gallery(0)
2900 on Mine (I do My Own Servicing) I have used Polaris Stuff from Day 1 No Problems so far & no reason To Switch
gmiller0737 is offline
post #4 of 25 Old March 21st, 2017, 05:28 AM
roadiestar's Avatar
First Name: Tom
My RZR: 2017 xp1000 white lightning
Member #2518
View roadiestar's Photo Gallery(0)
http://www.rzrforums.net/attachment....1&d=1490099272
roadiestar is offline
post #5 of 25 Old March 21st, 2017, 07:29 AM
ItchinToRide's Avatar
My RZR: 2013 800LE 50"
Member #8600
View ItchinToRide's Photo Gallery(0)
There's nothing wrong with Polaris oils.
However, the best oil is clean oil of the correct type and viscosity.
ItchinToRide is offline
post #6 of 25 Old March 21st, 2017, 08:38 AM
oldtotegoat's Avatar
My RZR: 2013 RZR 800 LE Blue Fire or is it VooDoo Blue?
Member #56641
View oldtotegoat's Photo Gallery(0)
Engine Mobil1 5w-50 or whatever brand you like.
oldtotegoat is offline
post #7 of 25 Old March 21st, 2017, 09:01 AM
Smith's Avatar
My RZR: 2016 RZR 900 4
Member #18920
View Smith's Photo Gallery(11)
Polaris Oils in all 3 RZR's I've owned and never any issues. There are a lot of people that assume Polaris oil is "inferior", but Polaris must test their oil when validating products. I assume if it holds up during Polaris testing it will easily handle the way I use my RZR. Why guess with other fluids, when you can get Polaris oil at the dealer or just order on Amazon and have it deliver in 2 days.
gmiller0737 likes this.
Smith is offline
post #8 of 25 Old March 21st, 2017, 12:46 PM
rockymountainranger's Avatar
Member #84951
View rockymountainranger's Photo Gallery(1)
Amsoil
rockymountainranger is offline
post #9 of 25 Old March 21st, 2017, 01:11 PM
calebowings195's Avatar
Member #188729
View calebowings195's Photo Gallery(0)
I've been running mobile 1 15w50 synthetic it's the same weight as Polaris extreme oil but much better in my opinion
calebowings195 is offline
post #10 of 25 Old March 21st, 2017, 01:15 PM
Member #188729
Correction Polaris is 10w50
post #11 of 25 Old March 21st, 2017, 01:55 PM
Diamond K's Avatar
Member #71671
Most mechanical issues are caused by neglect and abuse. There will always be the rare exception to that rule but for the most part if you keep it lubed, feed it clean fuel and air, it will last a long time. Never under estimate the importance of clean air.
post #12 of 25 Old March 22nd, 2017, 04:00 AM
dak
dak's Avatar
My RZR: 800s le
Member #50509
View dak's Photo Gallery(0)
Most of these oil threads are just silly! Fact is pretty much any brand oil will last way longer than you should keep it in your machine. The reason you're changing your oil in these machines is not because the oil breaks down. It's because the oil gets dirty due to the environment is operated in. Sure you can spend the money and use Amsoil, but when you change it out you're throwing away dirty oil that still has hundreds of hours of viscosity left. When you buy cheap no name oil, you change it out when it gets dirty and it still has hundreds of hours of good viscosity left. That being said most oils come from one of very few refineries, or for synthetics chemical plants. They can tell you all about the fantastic things their oil does, or what they put in it. But Polaris doesn't make oil they just put their name on it. Moral of the story change your oil often, more often if used in very dusty environments and you'll have a clean engine. More importantly-much more importantly- keep your air filter clean and change it often.
2017 XP Turbo Cruiser Black
2014 RZR 900XP Black Stealth - Gone
2013 RZR 800S Blue fire - History
dak is offline
post #13 of 25 Old March 22nd, 2017, 07:00 AM
BAG
LHartman's Avatar
First Name: Loren
My RZR: TWEEKER
Member #115873
View LHartman's Photo Gallery(11)
Rotella T6. Was using Polaris and Amsoil previously. After researching and speaking to some people, T6 will work just fine.
Beanhead likes this.
2015 RZR 900 Trail EPS 4500# Winch with synthetic rope, Polaris sport roof, Polaris overhead storage bag, Polaris half windshield, Polaris rear windshield, Turbo Hood, XP1000 Doors, UTV Giant lower doors, UTV Giant center seat, Ripsaws, SSV Works MRB3 Media Controller, Rockford Fosgate Amp, SSV Works Kick panel speaker pods with Kenwood Excelon XR-1700P speaker system, Glovebox sub with Kenwood KFC W100 subwoofer, Kimpex Expedition cargo box.
LHartman is offline
post #14 of 25 Old March 22nd, 2017, 07:29 AM
CaptainYARRR's Avatar
Member #88097
View CaptainYARRR's Photo Gallery(0)
Lots of people have great luck with Polaris oil. I think a lot of people try cheaping out (not saying you are) and pick a different brand. In the grand scheme of things, it's one of the cheapest things in your RZR...just do the Polaris and go have fun.
Smith likes this.
CaptainYARRR is offline
post #15 of 25 Old March 22nd, 2017, 07:53 AM Thread Starter
JRush311's Avatar
Member #183209
Def not cheaping out just want the best lube
JRush311 is offline
Engine Oil Options strate6 RZR XP 1000 132 May 26th, 2017 09:43 AM
Turbo burning oil IBEW1464 Forced Induction 4 April 12th, 2017 09:17 PM
HMF Oil Filter relocation kit for pro star twins mHMFs HMF Racing 0 January 19th, 2017 06:35 AM
oi cooler joemamma RZR 900 Engine 25 June 22nd, 2016 03:15 AM
Oil cooler on Prostar engine 2011redxp RZR 1000 Engine 0 February 4th, 2016 08:38 AM
