Water hole - Polaris RZR Forum - RZR Forums.net
post #1 of 6 Old March 19th, 2017, 08:29 PM Thread Starter
Dro276's Avatar
Water hole
Got into a water hole this weekend. The belt was slipping at first, after I got out. Went away after I got on some dry land and cruised at a low speed. Should I be worried. How about anything else?
Thanks.
Dro276 is offline
post #2 of 6 Old March 19th, 2017, 08:51 PM
Feedback Score: 16 reviews
BLOODY BILL's Avatar
Colorado Re: Water hole
there is a little red drain screw on your drive belt housing just for that draining out water
i,d take the drive belt cover off and inspect and clean out any mud dirt
WARNING!
GET YOUR RIDE INSURED / THEFT
BLOODY BILL is offline
post #3 of 6 Old March 20th, 2017, 01:01 AM
Reschjo's Avatar
Was it just water or a deep mud hole where you were struggled to get out? I had that issue when spinning a bunch when stuck. It wasn't water it was overheating the belt. I removed the drain plug and nothing came out. Think I just got the belt hot spinning the tires.
Reschjo is offline
post #4 of 6 Old March 20th, 2017, 07:02 AM Thread Starter
Dro276's Avatar
Re: Water hole
Just water. I pulled the plug later. Nothing came out. The seal was dry also around the screw. Think a little may have got down the air hose.
Dro276 is offline
post #5 of 6 Old March 20th, 2017, 10:56 AM
Smilfen's Avatar
Re: Water hole
Depending on where your vent hoses are located on the front and rear diffs, I would remove the fill plugs to each diff and check to see if any water made it in there. If so, drain and refill with fresh fluids.
Smilfen is offline
post #6 of 6 Old March 20th, 2017, 03:01 PM Thread Starter
Dro276's Avatar
Re: Water hole
Thanks for all the info. I'll be doing some investigation work.
Dro276 is offline
Deep Water on first trip Smilfen RZR XP 4 Turbo 7 March 1st, 2017 07:09 PM
Get the hole shot on your Polaris XP Turbo RZR OspJustin RZR XP Turbo 2 October 18th, 2016 04:55 PM
What To Check After Getting Stuck in Water? brandonjansen RZR XP 900 1 October 17th, 2016 03:11 PM
Water pump, weep hole? Creisol RZR S 1000 0 March 12th, 2016 10:00 PM
Z1 Pace Offroad Billet Water Pump Housing PaceOffroad General RZR Discussion 21 February 25th, 2016 12:15 PM
