Transmission fill check plug size - Polaris RZR Forum - RZR Forums.net
post #1 of 5 Old December 12th, 2010, 12:46 PM Thread Starter
FunRide's Avatar
What size allen (square) is required to correctly remove the various transmission fill/check plugs? Any other fill checks on gearcases that are out of the ordinary?
Got the allen, just wondering about the square size....
FunRide is offline
post #2 of 5 Old December 12th, 2010, 03:52 PM Thread Starter
FunRide's Avatar
Re: Transmission fill check plug size
Wow, 21 people looked at this nobody knows what size socket to check/fill the various gearcases....I figured it out.
Will post a brief summary for those that may want to do it....fluild volumes, tools, drains, fills.
FunRide is offline
post #3 of 5 Old December 12th, 2010, 04:45 PM
groundhog's Avatar
Got mine with just the socket extension.
groundhog is offline
post #4 of 5 Old December 12th, 2010, 05:52 PM
TURBO'S RULE
allcool's Avatar
Well, none of the sizes are out of the ordinary.
What one should be aware of, is there are 2 sections of the gearbox/transfer case assembly that have separate sumps.
Front transfer case has 1 drain, 1 fill, AND 1 Level check plug. Thats 3 plugs that have to come out on the front of the trans.
The fill plugs are all big 3/8" drive square plugs. All drain plugs are iirr 12mm(maybe 13mm)socket heads. The 1 separate level check is also a socket head plug, like the drain plugs, iirr.
The gear case has only 1 drain and 1 combination fill/ level check plug.No separate level check plug like the transfer case.
Front diff has a large Allen plug on it. Don't remember exactly if it was 7 or 8 mm, but it was bigger than the 6mm engine drain.
allcool is offline
post #5 of 5 Old December 12th, 2010, 08:27 PM Thread Starter
FunRide's Avatar
Yep, got them All....Thanks.
I did notice that 1/2" is a better fit than 13mm on the drains and 5/16 allen is a perfect fit on the front diff (didn't try metric). Not sure the shop manual calls for.
FunRide is offline
Transmission + Main Gearcase fluid check location? captnbombpop General RZR Discussion 10 November 8th, 2010 05:48 PM
Transmission Oil level plug stripping Larrymay General RZR Discussion 2 October 18th, 2009 09:18 PM
drain plug size straightliner General RZR Discussion 10 July 22nd, 2009 09:21 PM
Stripped Transfer Case Check Plug. Possible Fixes? Hell-RZR Engine and Drivetrain 2 May 24th, 2009 04:06 PM
Fill / Drain Plug Failure? fanjules Engine and Drivetrain 10 September 6th, 2008 02:44 PM
