Transmission and gearcases - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old December 1st, 2010, 09:03 AM Thread Starter
DReese's Avatar
Transmission (Main Gearcase) AGL - Synthetic ATV Gearcase Lubricant 24 oz.
Transmission (Transfer Case) AGL - Synthetic ATV Gearcase Lubricant 14 oz.
Front Gearcase Demand Drive Plus 6.75 oz.
Rear Gearcase ATV Angle Drive Fluid 26 oz.
Trans Fill & Level Plug is Under Shift Lever Near Left Rear Tire.
Transfer Case has 3 Plugs, Fill, Level, & Drain.
Front Diff has a Fill/Check & a Drain Plug.
Rear Diff has a Fill/Check & a Drain Plug.
Here's another good idea I found on another site;
To keep the oil from running all over your frame when changing the oil filter.
1st, unscrew the filter slightly, just enough so you can turn it with your hand, then use a punch or phillips screwdriver and tap a small hole in the filter about 12 o'clock. Get an old ball point pen, disassemble, and using just the tube, insert it in the hole. Now rotate the filter so the tube is at the bottom & let it drain.
DReese is offline
post #2 of 4 Old December 1st, 2010, 09:18 AM
FunRide's Avatar
Re: Transmission and gearcases
Thanks Don. Just about to change all my gear fluids.
Where did you get these quantities? Manual calls for two quarts in the engine and it takes less.
Good call on the driver/pen combo for those that don't vacuum.
FunRide is offline
post #3 of 4 Old December 1st, 2010, 02:02 PM Thread Starter
DReese's Avatar
I found the info on the web.
mine takes 2 qts...
DReese is offline
post #4 of 4 Old December 1st, 2010, 02:46 PM
FunRide's Avatar
mine takes 2 qts...
Mine will take 2 quarts too, but it's well over the high mark on the stick. Then when drained, I've measured roughly .8 of a quart.
FunRide is offline
rzr transmission vectorboy_99 Want to Buy 0 June 20th, 2010 06:20 PM
transmission hommer1 General RZR Discussion 8 May 17th, 2010 10:20 AM
RZR Transmission BlueSVT Want to Buy 8 December 26th, 2009 02:08 PM
Need a New Transmission richboy202 Engine and Drivetrain 3 September 25th, 2009 03:27 PM
Transmission SuperBuys Engine and Drivetrain 4 June 20th, 2009 12:49 PM
