Ground Clearance
This is a discussion on Ground Clearance within the General RZR Discussion forums, part of the General RZR category; Noticing the RZR only has 10" that I assume starts evaporating when the seats are full. My Question is how much clearance do you think ...
Old July 24th, 2008, 06:39 PM
jonesntn's Avatar
Member #2556
View jonesntn's Photo Gallery(0)
Ground Clearance
Noticing the RZR only has 10" that I assume starts evaporating when the seats are full. My Question is how much clearance do you think is reasonable for trail riding? How Much Clearance do you have and what did it take in $$ and sacrifice in order to get it up? I am still picking between the RZR and the Rhino, However I have noticed the RHino starts off with a slight advantage in this department.
Old July 24th, 2008, 07:22 PM
jhay2277's Avatar
Member #3084
View jhay2277's Photo Gallery(0)
Re: Ground Clearance
In stock form the ground clearance of the RZR is not good enough for any kind of rugged trails.
For mine I got some 26" tires on 14" rims, and also added a 2' lift kit. Now I am sitting at a sold 11' ground clearance fully loaded and I can handle whatever comes my way.
Old July 24th, 2008, 07:31 PM
jonesntn's Avatar
Member #2556
What is your total width now?
Old July 24th, 2008, 07:48 PM
chp-sk8's Avatar
My RZR: green RZR
Member #1077
View chp-sk8's Photo Gallery(0)
26" on 14 wheels is right @ 65inches
I suggest you trail ride both and you will be sold on the RZR . It will take one good hill climb! good luck
Old July 24th, 2008, 08:18 PM
jhay2277's Avatar
Member #3084
I am at 55" / 56" wide.
Old July 24th, 2008, 08:44 PM
Cooter's Avatar
My RZR: 800
Member #500
View Cooter's Photo Gallery(0)
I'm at 64" with 14" of ground clearance. Mine bottoms out occationaly on G outs.
Old July 25th, 2008, 12:15 AM
gone!!!!!!!
Feedback Score: 6 reviews
Member #787
my friend has a rhino and i can say this is the only area he has me beet in..... i added affco shocks and now have almost 11 in of clearance but anotheir thing hurting the rzr that most people forget the wheel base on it is alot longer than the rhino so even if they both had the same clearnce the rzr would still bottom out first so a 2 in lift kit will help taller tires too and not alot more to do or youll over do the cv's on angle.... sort of like a long wheel base p/u vs short wheel base jeep sucks but i just gas it more....lol
lots of toy's
  #8
Old July 25th, 2008, 05:32 AM
Fishalope's Avatar
My RZR: Red - 08
Member #3297
View Fishalope's Photo Gallery(3)
[quote=jonesntn;31331]Noticing the RZR only has 10" ...QUOTE]
Advertising 10 inches is a bit of a stretch on Polaris’s part. I just put on a 2 inch lift kit on mine and NOW I’m at 10 inches.
I’m on stock tires and stock width. I have 1.5 inch wheel spacers coming in this week. I’m also planning on adding 1 inch spring spacers.
  #9
Old July 25th, 2008, 06:36 AM
Baditude's Avatar
My RZR: 2009 RZR S
Member #1091
View Baditude's Photo Gallery(2)
I have a 2" lift, 27" tires on 14" rims and bottom out only on the toughest terrain. I am thinking of adding 1" spring spacers someday, but I am very happy with the setup so far. I have measured my clearance at 12" but that is with nobody sitting in it.
  #10
Old July 25th, 2008, 07:35 AM
DoctahB's Avatar
First Name: Doc
My RZR: Gen 2 Greenie
Member #1012
View DoctahB's Photo Gallery(0)
At one point, I had front sway bars off, 2" lift kit and 1" spring spacers up front, with Highlifter springs , and had about 14-15" clearance. I also blew out my front shocks and screwed my rack and pinion up first hard ride, and bad CV trouble shortly thereafter.
Took the spring spacers off, and now I'm around 13-14" unloaded. No shock or CV troubles since.
It you can't get aftermarket shocks yet, the HL springs are really worth it.
26" Maxxis Bighorns, Highlifter springs, Rubberdown 2" lift kit, Hunterworks 1.5" wheel spacers on the back, Warn 3500, Pre-runner bumper and rock sliders, F&R cv covers, Front swaybars off, Overfender mud flaps, DFR harness. HID's, Odessey battery, EPI clutch kit,
  #11
Old July 25th, 2008, 07:37 AM
Crowdog's Avatar
First Name: Jon
Member #311
View Crowdog's Photo Gallery(0)
10" is definitely a stretch in stock form. More likely 9" and you will hit it a lot.
The new RZR S has 12.5". That is a much nicer setup.
www.UTVGuide.net
www.UTVWeekly.com
  #12
Old July 25th, 2008, 08:08 AM
Baditude's Avatar
My RZR: 2009 RZR S
Member #1091
Problem with the RZR S is the 60" width great for dunes bad for trails.
Make you feel like your in an Artic Cat, I ride with one and more often than not on the tight trails he has to take the path less traveled (or create his own)
  #13
Old August 5th, 2008, 11:59 PM
Chips's Avatar
First Name: Shawn
My RZR: Green One
Member #1984
View Chips's Photo Gallery(0) Send a message via Yahoo to Chips Send a message via Skype™ to Chips
I just got back from Watson road here in Phoenix and went through some hard core rock trails way back in the mountains with my buddy who has a Rhino.
The Rhino clearly has the clearance but I easily outmaneuvered him through quite a few spots. Not to mention he almost rolled it going over a down facing ditch after a off camber spot and I cruised over it no problem.
I was blowing up rocks like land mines at high speeds through tight trails (15-40mph), rocks the size of small watermelons or cantelopes. I totally destroyed the lame plastic body plate and put a few nasty dents in the frame. Overall though it handled much better through the crazy stuff than me or my buddy thought. If you have experience you can use the longer wheelbase and narrower width to your advantage, where the Rhino gets unstable due to leverage issues. If you don't care about thrashing your ride then its no question the RZR can outperform the Rhino even in moderate to serious rock crawling. And I mean thrashing as in mangling your plastic skid and denting your frame underneath...not thrashing your axles or drive train.
I even hit a rock dead center at about 40mph that exploded on contact under the frame and blew my hood off. I will get some pictures and post them up.
  #14
Old August 6th, 2008, 06:14 AM
simadownow6988's Avatar
If your not 1st,Your last
First Name: Jon
My RZR: 2009 RZR S!!!!
Member #1253
View simadownow6988's Photo Gallery(0)
I wish I had the money to not care about my ride.....
  #15
Old August 6th, 2008, 06:57 AM
BlackRaptor's Avatar
Member #3489
View BlackRaptor's Photo Gallery(0)
Dang Chips.
That poor RZR. you need to get full body armor for that thing. ha-ha
2008 Gen 3 Polaris RZR
2001 Polaris Xplorer 400
2000 Honda CR250
What is ur ground clearance Trey Suspension 17 March 2nd, 2009 09:30 AM
Ground Clearance jerrzr Suspension 0 January 8th, 2009 07:16 AM
AFCO's and ground clearance EBT531 Suspension 2 August 13th, 2008 10:40 PM
Ground Clearance 1idrod Suspension 7 January 14th, 2008 06:23 AM
24" of Ground Clearance txmd500 RZR and UTV Video's 9 January 10th, 2008 09:40 PM
