July 22nd, 2008, 11:11 PM
First Name: Sean
Gearcase Drain Bolt Thread Pitch?
I tried to change the oil in my gearcase tonight. The drain took hardly any torque to remove, and when I reinstalled it, it took very little torque to tighten, and never seemed to seat. When I removed it next, my fears were realized when I saw that gearcase threads hanging on the bolt.
I'm having a hell of a time figuring out what size bolt this is. The head is half inch, and the bolt diameter is either 3/8" or 10mm. However, I can't seem to find a good fit with either my standard or metric thread pitch gauge. I'm going to need to put in a helicoil, but it would sure help to know what size I'm looking for!
Using a metric gauge, it's very close to a 1.25mm pitch, or 20 threads per inch on the standard gauge. However, the drain plug threaded portion is so short that it's difficult to match up more than a few threads.
July 23rd, 2008, 11:13 PM
First Name: Rob
My RZR: 2008 800
Re: Gearcase Drain Bolt Thread Pitch?
The manual doesn't say what the thread pitch is, but it does say that the torque on transmission drain/level plugs is 30 - 45 INCH pounds. That's not very much. I suspect you will have to get the rest of the information from your dealer. Good luck.
July 23rd, 2008, 11:17 PM
First Name: Sean
Quadder,
Thanks for the reply. I eventually figured out that the threads are 3/8 - 24. Now I've got to try to get a Helicoil in there...
