Seat back angle - Polaris RZR Forum - RZR Forums.net
Seat back angle
This is a discussion on Seat back angle within the General RZR Discussion forums, part of the General RZR category; So, I am not a big fan of the angle of the seat back on the OEM seats. I would like it to be less ...
Old October 22nd, 2010, 07:46 PM   #1
safehaven's Avatar
My RZR: 2010 RZR-S
Member #15456
View safehaven's Photo Gallery(2)
Seat back angle
So, I am not a big fan of the angle of the seat back on the OEM seats. I would like it to be less reclined. I do not like feeling like I am reaching for the wheel (yes, I have tilted it down and still feel as though I am reaching). I have moved my seat as far forward as I can without hitting my knees.
First let me say, I do not want to buy new seats. Simply not an option.
I am curious if anyone else has had an issue with this and what their solution was.
Obviously, I could simply put a jacket or something behind me. But, I am looking for a solution that is semi-permanent. I was thinking that one could make something to hang over the seat that would add a wedge shape of padding... no padding at the butt and maybe 2" of padding at the back of the head. I do not know how I would go about implementing this, though.
Thoughts?
safehaven is offline   Reply With Quote
Old October 22nd, 2010, 08:14 PM   #2
Feedback Score: 11 reviews
mark5193's Avatar
First Name: mark
Member #1018
View mark5193's Photo Gallery(5)
Re: Seat back angle
can you raise the rear mount? add washers below or a spacer? wouldn't take much, 1/2" raise in the rear would make a big difference.
mark5193 is offline   Reply With Quote
Old October 22nd, 2010, 08:21 PM   #3
Feedback Score: 4 reviews
jmattor's Avatar
First Name: Jim
My RZR: 2010 RZR 4bo
Member #12929
View jmattor's Photo Gallery(19)
Re: Seat back angle
I think if you made two shims the proper height and used longer machine screws you'd probably be OK.
Another option would be to modify the seat back. Perhaps bend it forward and weld (or bolt) a small gusset to the side of the tube at the bend for reinforcement ?
I love the smell of styrene in the morning....
jmattor is offline   Reply With Quote
Old October 23rd, 2010, 08:18 AM   #4
gunrunner's Avatar
First Name: Man
Member #4830
Re: Seat back angle
just loosen the 4 bolts on the bottom, and buy 2 longer ones and shim up the rear two as high as you want. I wanted mine taller for more leg room so i added a 1'' square tube under my mount and it works great.
site de flirt internet
gunrunner is offline   Reply With Quote
Old October 23rd, 2010, 07:08 PM   #5
safehaven's Avatar
My RZR: 2010 RZR-S
Member #15456
Re: Seat back angle
I gave the shim idea a shot. I used composite shims from Home Depot. I had to trim them to fit in the channel of the seat base. I use three on each side, raising the rear up 3/4" (each shim was 1/4" tall). I do not know yet how far it actually leaned the seat forward. My guess is a couple of inches, but I do not have the other seat readily available to compare. Hopefully, this works out.
angle of back seat
machining rzr heads to have more of a wedge shape
racing seat back angle
rzr seat back angle
rzr seats for bad backs
seat angle for bad back
seat back angle
what angle of seat back is best for bad back
what angle should tube be in the back of polaris
best seat for rzr for bad back/disc polarisman General RZR Discussion 4 October 19th, 2010 11:53 AM
Back Seat Mod for the kids Catmostfeared Projects and How-To 7 October 4th, 2010 07:40 PM
Cage with Back Seat tjmotors Polaris RZR Parts For Sale 5 January 3rd, 2010 08:18 PM
Seat won't go back khorton Seats and Belts 0 December 28th, 2009 09:09 PM
Most comfy seat for bad lower back? RockRazr Seats and Belts 16 September 15th, 2009 10:17 AM
