Re: Oil level going UP??
My oil was also 1/4" above safe when it was new, but I didn't check it until after my first ride. I changed it soon after because I didn't like it being over full. I found that when changing the oil, it didn't hold exactly the amount it called for - 2 quarts. The dipstick showed full just shy of 2 quarts. To see oil rise, could be: gas blow by, water, not having let all the oil drain into the crankcase before checking, dipstick not being pushed in all the way (these are some things I've done before so I always check oil a couple of times ). I wouldn't worry about it unless it rises anymore
