Acc terminal not working - Polaris RZR Forum - RZR Forums.net
 6Likes
post #1 of 22 Old September 11th, 2016, 03:00 PM Thread Starter
Cajun Jeaux's Avatar
My RZR: 2016 rzr 900 trail
Member #122809
View Cajun Jeaux's Photo Gallery(0)
A while back I was wired in my radio into the terminal block. I ran 12v and ground to their spots and tied into the acc to turn in one by the key just like you wore it in your truck. It worked for about 5 seconds. Turned out my radio was bad too. But now the acc doesn't work at all. The fuse is still good but I'm not getting any continuity from the fuse box to the terminal. My blue floor light doesn't work either. It's like I blew an in line fuse but I can't find one. I even have the skid plate off for maintenance and can't find a pinched or damaged spot on the wiring harness. Any ideas?
Cajun Jeaux is offline
post #2 of 22 Old September 11th, 2016, 03:09 PM Thread Starter
Member #122809
Re: Acc terminal not working
And for added complexity if I run a jumper from my terminal to the positive side of the battery my blue light comes on
post #3 of 22 Old September 11th, 2016, 03:29 PM
topgun's Avatar
My RZR: 2014 RZR 1000
Member #17581
The fuse is blown. Are you checking the correct one? I believe it is labeled "TERM", 10 amp. The blue light works when you back feed the circuit since the fuse is beyond the light when feeding in the reverse direction.
Are you wiring the radio correctly? The Acc terminal is designed to power on a relay when you turn on the key. The relay is then wired to get power from the battery cables on the block which supply the power to the light, radio, or other accessory. If you try to run your accessory directly through the Acc terminal, you can blow the fuse. It is only meant to trip a relay when the key is turned on. You may get away with a little more but that is not the intent of the design.
2014 RZR 1000, Black Pearl
2008 Can Am Renegade 800
topgun is offline
post #4 of 22 Old September 11th, 2016, 03:32 PM
Burnt Orange's Avatar
Member #83480
View Burnt Orange's Photo Gallery(2)
Have you tried a new fuse? Sometimes they are bad even when they look okay.
Burnt Orange is offline
post #5 of 22 Old September 12th, 2016, 08:00 PM Thread Starter
Member #122809
The fuse is not blown. And I'm pulling the fuse to check continuity. I've checked voltage again and I'm getting 12.5 volts at the fuse box but only 7.7 at the terminal.
post #6 of 22 Old September 12th, 2016, 08:47 PM
Jjwheeler2's Avatar
Member #138641
View Jjwheeler2's Photo Gallery(0)
Sounds like you may have burned the contact on the key switch. Seems to happen when people overload the acc terminal.
Whenever wiring accessories always protect them and your machine by using additional fuses and relays.
Here's my wiring setup.
Jjwheeler2 is offline
post #7 of 22 Old September 13th, 2016, 03:42 AM Thread Starter
Member #122809
I think I'm going to splice into the wire close to the fuse box and run a new wire. The thing about it is that the only thing I had hooked up to it was the acc wire for the radio.
post #8 of 22 Old September 13th, 2016, 04:14 AM
Wildjon3006's Avatar
Member #79284
View Wildjon3006's Photo Gallery(0)
My ACC terminal stopped working also. The wire lost continuity somewhere right after it made the bend around the gas tank in the harness. I ended up splicing a new wire and double heat shrinking it to get it working again.
Wildjon3006 is offline
post #9 of 22 Old September 13th, 2016, 10:31 AM Thread Starter
Member #122809
Have you had any more issues with it since?
post #10 of 22 Old September 13th, 2016, 11:18 AM
mozart's Avatar
First Name: Al
My RZR: 2017 XP41k Titanium Metalic
Member #139465
View mozart's Photo Gallery(0)
please dont... find the problem first. you could risk more damage
generaljls and Rocksy9 like this.
2017 XP41k
mozart is offline
post #11 of 22 Old September 13th, 2016, 11:37 AM
Member #79284
No.
Without completely removing the harness, I'm pretty sure the wire insulation had a pinhole in it near the tank area, and it corroded until it lost continuity.
post #12 of 22 Old September 14th, 2016, 04:30 AM Thread Starter
Member #122809
I fixed my problem but I feel a little foolish. The acc terminal says acc on the fire wall and the acc on the wire so I assumed that the acc fuse supplied that wire. Made since to me. But as it turns out it's the fuse marked term that feeds the terminal and acc feeds the 12v port on the dash. Explains why I had no continuity. Lol
generaljls likes this.
post #13 of 22 Old September 14th, 2016, 07:09 AM
topgun's Avatar
Member #17581
Post 3 says to check the "TERM" fuse. Mentioned it because you are not the first person to check the wrong fuse. It's easy to do.
generaljls and dmharvey79 like this.
topgun is offline
post #14 of 22 Old September 14th, 2016, 03:20 PM
CaFireater's Avatar
First Name: Ross
My RZR: 2016 RZR XP4 TURBO 2015 RZR XP 1000
Member #76207
View CaFireater's Photo Gallery(0)
thank you!
I had the same problem and was checking the acc. fuse, it was driving me crazy
CaFireater is offline
post #15 of 22 Old May 17th, 2017, 12:54 PM
TedPk's Avatar
Member #199065
View TedPk's Photo Gallery(0)
I know this is an old thread but I am having the same issue, ACC terminal not working and both fuses ACC and Term have been checked, double checked, changed to new once and still no V in the ACC terminal.
What else can I check?
TedPk is offline
UTV INC RZR Under Hood 12V Power Terminal Kit UTV Inc. UTV Inc 125 April 24th, 2017 05:55 PM
acc not working ariktsa RZR S 900 5 May 3rd, 2016 08:25 AM
acc stop working (900s eps 2015) ariktsa Lighting, Stereo and Electrical 4 May 3rd, 2016 06:01 AM
Help - ACC post has no power. rzr44me Lighting, Stereo and Electrical 4 April 9th, 2016 07:05 PM
No power coming from acc wire Polson61 RZR S 900 8 April 5th, 2016 07:38 AM
