What would a clogged spark arrestor do? - Polaris RZR Forum - RZR Forums.net
This is a discussion on What would a clogged spark arrestor do? within the General RZR Discussion forums, part of the General RZR category; I'm troubleshooting a problem with my RZR. It shuts off while I'm sitting idle on the trail, but I can start it up no problem. ...
Old July 21st, 2010, 06:00 AM   #1
RickRZR's Avatar
Member #1582
View RickRZR's Photo Gallery(0)
I'm troubleshooting a problem with my RZR. It shuts off while I'm sitting idle on the trail, but I can start it up no problem. Now it's starting to hesitate while I start to accelarate.
I removed the fuel sending unit /fule pump from the tank to make sure that there was no water or trash in the tank and it was clean. In doing so three of the screws that hold the sender in place were seized to the pressed in nut. I had to pull these out of the tank and now I need to figure out how to fix this as well ( that will be another thread) . Any thoughts would be appreciated on repairing this too.
QUESTION: Can a clogged spark arrestor cause it to hesitate or stall? From everything I have read, removing one can be a PITA, and I dont want to waste time and get pissed off trying to remove this thing if it will not cause my problem.
Rick
RickRZR is offline   Reply With Quote
Old July 21st, 2010, 06:45 AM   #2
Feedback Score: 176 reviews
swingarm1's Avatar
First Name: Tim
Member #7690
Re: What would a clogged spark arrestor do?
Rick
It can and will raise hell with the running of the motor... Hesitating, over heating, surging, poor idle etc... If you don't want to take it out spray it with brake cleaner 3 or 4 times and see if you can open it up...
If that doesn't work you'll have to remove and clean it or replace it... It's just a screen (heavy duty)...
Old July 21st, 2010, 10:13 AM   #3
Feedback Score: 16 reviews
guy48065's Avatar
Member #309
Use a bearing puller.
Mine came from the factory with 2 arrestors installed so they were very hard to extract. This got them out without damage. The bearing puller has 2 opposing jaws that grip from the inside & attached to a slide hammer.
guy48065 is offline   Reply With Quote
Old July 21st, 2010, 10:16 AM   #4
RickRZR's Avatar
Member #1582
Where did you find that puller? What size is it?
Rick
Old July 21st, 2010, 11:01 AM   #5
swingarm1's Avatar
First Name: Tim
Member #7690
Rick
Harbor Freight has them or the Tool Exchange...
Old July 21st, 2010, 11:59 AM   #6
UTVRZRREBEL's Avatar
First Name: Anthony
My RZR: 2009 RZR LE Sunset Red
Member #9641
View UTVRZRREBEL's Photo Gallery(0)
Just a thought, mine started doing something similar to yours. It started ideling really low when slowing down or coming to a complete stop, and finally it ideled so low that it died. It was around 700 rpms when it's suppose to idel around 1200-1230 rpms, I was told that it could be the TPS sensor got out of adjustment. So I decided to try to adjust it myself by loosing the Star headed bolt and adjusting it myself. It began to idel terrible and died and by moving it I got it where I could ride it on the Mtns. and a Polaris Dealer was at the event and they told me that I should have not moved it. So they took another TPS off the rental 09 and put it on my RZR so I could ride. Because I drove 600 miles to ride the weekend and they got me going, but it still wasnt calibrated just right. So I tool it into the Dealer in Jax FL and they put me a new TPS on and now its fine. But you can take a wrench and take the bolt out and then put it inside the tailpipe and screw it about half way down and then take bigger wrench and put over the bolt and attach a pair ov vise grips on the end of the wrench and tap it out with a hammer. First use some penertrating spray and let it sit for a few minutes and then tap it out. Mine came right out and then I cleaned it with brake cleaner and used a small screwdriver to break loose the carbon around the head of the Arrestor. There is a groove around the head, at least mine has one. I've read that some guys leave it out to get a deeper sound and put a small bolt in the hole so it doesnt sputter. Doesnt sound bad at all. So maybe this helps.
Anthony
UTVRZRREBEL is offline   Reply With Quote
Old July 21st, 2010, 12:51 PM   #7
clemson726's Avatar
My RZR: 2010 RZR S
Member #11797
View clemson726's Photo Gallery(0)
That's very clean compared to what mine looked like when i pulled it out earlier in the week. Mine was so clogged up i couldnt see through it when holding it up to the sunlight. Despite how restricted it was, my rzr was running just fine.
2010 RZR "S" SOLD
2015 RZR 900 S
clemson726 is online now   Reply With Quote
Old July 21st, 2010, 07:10 PM   #8
guy48065's Avatar
Member #309
I prolly had less than 100 miles on when I discovered the factory had jammed 2 in the tailpipe so that's how a 'clean' one looks.
Now you got me wondering what it looks like NOW.
FWIW I really liked the sound better with 2 arrestors. Nice low & mellow tone without the 'chuffing' I have now.
Old February 4th, 2011, 09:40 AM   #9
natedawg88's Avatar
Member #18438
View natedawg88's Photo Gallery(0)
Don't go buy anything to remove it. A simple boat plug will work! Put it in the exhaust and tighten it up then pull it out with a wrench. The cheap style screw in ones is what I used. The ones that have the flip handle on them don't seem like they would be a good choice. I have removed mine and cleaned it numerous times this way.
natedawg88 is offline   Reply With Quote
Old February 4th, 2011, 09:50 AM   #10
8ball_99's Avatar
My RZR: 2013 Black RZR4 XP LE
Member #7209
View 8ball_99's Photo Gallery(0)
Mine was very clogged when I had stock exhaust.. I took the bolt out that holds the arrestor. Then In screwed it into the arrestor from the inside of the pipe.. stuck a wrench on the bolt with some vice grips and used a hammer to knock it out.. I also had to spray it with PB blaster a few times since it was pretty stuck..
Isn't is it a bit unnerving that doctors call what they do "practice"?
Why do we drive on the parkway and park in the driveway?
Problem with political Jokes is,, they get elected..
8ball_99 is offline   Reply With Quote
Old April 21st, 2012, 02:19 AM   #11
RacerSam's Avatar
My RZR: 2009 Nuclear Orange LE, 2012 Walker Evans
Member #7858
View RacerSam's Photo Gallery(0)
will a clogged spark arrestor cause considerable loss in power? while riding few weeks ago went of in hole slowly nose first ,came up to just below headlights wit hrzr back tires still high up on dry dirt, and after several attempts to back out/up, I could, so putit in 4x4 low, went for it made it to the other side and just as bout to come out, got stuck. so now have to let it idle to change gears into Reverse, (exh under muddy water just barely ,and it almost died when letting idle to change gears, it didnt but sorta burbled a bit. think got some that slimmy stuff in exh, though once it evaporated the water fro mthe thick muddy water, gonna leave the dirt in spark arrestor/muffler, got it out down on power, didnt miss nor hesitate , just weak, boggish sort of over 1/4 to 1/3 throttle. and going up a hill was boggish too. would really rev up either.
after limping to trailer ,hauled home, removed seats/engine cover checked oil, its clean, and washed off air filter housing (we run a UNI filter in it) and removed air filter end cover, still looks brand new inside, so clean there, I remove the spark arrestor, it looks totally stopped up to me, black with carbon/soot and figured dried dirt under the blackish soot. havent drove it yet ,but once I removed the spark arrestor, it does seem to rev up now like normal. does that sound possible that the spark arrestor was so stopped up, it killed atleast half the engine's power?????
RacerSam is offline   Reply With Quote
Old April 21st, 2012, 03:00 AM   #12
medik418's Avatar
First Name: Tom
My RZR: 2009 RZR
Member #14212
Texas Re: What would a clogged spark arrestor do?
Harbor freight also carries a blind hole bearing puller that will work for things such as this and works great for pulling stuck CV joints that have welded themselves to the differential. (ask me how I know) I think they were originally designed for pulling pilot barings out of crankshafts but they work wonders for this kind of thing.
medik418 is offline   Reply With Quote
Old April 21st, 2012, 06:36 AM   #13
Cade's Avatar
First Name: Cade
My RZR: 2012 S
Member #35621
View Cade's Photo Gallery(1)
Mine done the same thing your talking about man...I changed spark plugs , oil and next step was the fuel pump... it ran just like that with no power at all and I stuck my hand over the exhaust and felt out wasn't right so I pulled the spark arrestor/ baffle out and i cranked it up and ran perfectly without it so i cleaned it up real good and put it back in and it's ran like a champ since
Sent from my C771 using Tapatalk 2
Cade is offline   Reply With Quote
Old April 21st, 2012, 11:44 AM   #14
RacerSam's Avatar
Member #7858
Thanks, what did you clean it with?
Old April 21st, 2012, 12:01 PM   #15
Cade's Avatar
First Name: Cade
My RZR: 2012 S
Member #35621
I cant remember exactly I have a friend that has a mechanic shop and he had some stuff there...I wanna say it was some kind of carbon break up stuff
clogged spark arrester atv
clogged spark arrestor symptoms
clogged spark arrestor symptoms fl250
consequence of not clean spark arrestor, mtu
flame arrester dirty on mercruser motor can cause not to start
how much does a clogged flame arrestor affect boat performance
problems atv spark arrestor
rxpx flame arrestor clogged
spark plug arrestor symptoms
stoped up spark arrester on yamaha
symptoms of a blocked arestor screen
symptoms of a clogged spark arrestor
what does a spark arrestor do
will a plugged muffler cause motor not to rev up
Spark Arrestor ces43 General RZR Discussion 19 September 17th, 2010 10:42 AM
Spark Arrestor Q's loneRZR General RZR Discussion 9 January 19th, 2010 09:41 PM
Want OEM spark arrestor. loneRZR Want to Buy 9 January 18th, 2010 09:18 PM
Spark arrestor for '08? RZRUP Want to Buy 3 October 5th, 2009 09:24 AM
Spark Arrestor HivoltageRZR General RZR Discussion 20 March 15th, 2009 09:13 AM
