tilt wheel steering problem - Polaris RZR Forum - RZR Forums.net
This is a discussion on tilt wheel steering problem within the General RZR Discussion forums, part of the General RZR category; the steering wheel will no longer lock into a given position,it just extracts itself all the way up no matter what you do with the ...
Old June 26th, 2008, 08:13 AM   #1
Sprinklerhead's Avatar
First Name: Kevin
My RZR: uuhh-Green
Member #1970
View Sprinklerhead's Photo Gallery(0)
the steering wheel will no longer lock into a given position,it just extracts itself all the way up no matter what you do with the tilt lever.Any clues bout this would be appreciated.Surely that little oil locking shock isnt bad...it is never used.
Sprinklerhead is offline   Reply With Quote
Old June 26th, 2008, 10:40 AM   #2
RGERBER's Avatar
First Name: RUSTY GERBER
My RZR: 2008 GENERATION 1
Member #315
View RGERBER's Photo Gallery(0)
Re: tilt wheel steering problem
mine did the same thing, extended warranty said it does not replace shocks, it cost me about $ 110.00 for the new one.
RGERBER is offline   Reply With Quote
Old June 26th, 2008, 10:49 AM   #3
RandyGRZR's Avatar
My RZR: 08
Member #1203
View RandyGRZR's Photo Gallery(0)
I have mine for sale $40 it works fine!
RandyGRZR is offline   Reply With Quote
Old October 26th, 2009, 02:32 PM   #4
KC
KCCOMPUTERS's Avatar
First Name: Kevin
My RZR: 08 Red RZR
Member #5370
View KCCOMPUTERS's Photo Gallery(52)
Still have it ??
and is it still for sale ??
Mine broke so Im in need of one..
There are three models, Mines the first style, 08 RZR (not an "S")
Please let me know, Thanks. KC.
Im a victim to the RZR addiction, For which there is no cure...
But I am accepting donations for rehab. Please give what your heart tells you to. Thanks.
KCCOMPUTERS is offline   Reply With Quote
Old October 26th, 2009, 09:49 PM   #5
Johnpeq's Avatar
Member #1490
View Johnpeq's Photo Gallery(0)
This has been conered a few times, it's a easy repair. Remove the shock and chuck it in your vise @ the bottom bolt hole. Loosen the bolt @ the top and remove the lever. Now look in the center of the shaft and you wll see a rod. Soak this with WD-40 or a syclone spray and let it stand for an hour or so. Now grab the top of the rod with a pair of vice-grips and rotate it. If the rod is flush and you can't grab it, use a small punch and tap it to get it to extend. Once it rotates freely, reassemble and test, it should work.
John
Johnpeq is offline   Reply With Quote
Old October 27th, 2009, 06:44 AM   #6
KC
First Name: Kevin
My RZR: 08 Red RZR
Member #5370
John
Tried that.. Didnt work.. Valve stuck open.. Thinkin replacement is the way.. KC.
Old October 27th, 2009, 08:14 AM   #7
Hell-RZR's Avatar
Member #2044
View Hell-RZR's Photo Gallery(0)
Where could a guy get some kind of boot to slide over the entire shock to keep water and dust out of it? I know it wouldn't keep water out if it's submerged but....
Just an idea.
2016 XP 1000
Hell-RZR is offline   Reply With Quote
Old October 27th, 2009, 08:26 AM   #8
KC
First Name: Kevin
My RZR: 08 Red RZR
Member #5370
Grease will, pack the end around the lever openings with marine grease, that will repel the water. KC.
Old October 27th, 2009, 08:34 AM   #9
Hell-RZR's Avatar
Member #2044
Grease would work but, what a mess.
I have a bingo thanks to a private PM:
Moose Racing 2010
2016 XP 1000
Old October 27th, 2009, 08:37 AM   #10
charliep's Avatar
Member #3075
View charliep's Photo Gallery(0)
John
This is what I did this weekend. The rod was inside, so I had to tap on side of the shock until the rod popped out. I WD'd it more and worked the rod in and out.
charliep is offline   Reply With Quote
Old October 30th, 2009, 11:17 PM   #11
Feedback Score: 26 reviews
MotoXXX's Avatar
First Name: Jeff
Member #4542
I took mine apart tonight, wish I hadn't touched it! It was staying right where I wanted it lately but I had troubles with it in the past. When I took it apart the little pin in the center was stuck so I sprayed it with WD-40 then it would turn and go in & out but it has no pressure against it. It will stay where you leave it, in or out, or wherever. Now the steering wheel is at the top position for good until I get it working right. Is there a broken spring inside now or what? The website of the shock manufacturer isn't much help at all.
MotoXXX is offline   Reply With Quote
Old December 2nd, 2009, 09:26 PM   #12
Rol'47's Avatar
Member #9111
View Rol'47's Photo Gallery(0)
Thanks alot for your info on the tilt steering fix, it worked for me. Just took a bit of fine tuning to get the adjustment right on the valve. Thanks again....saved me $100+. Let me know if you are ever in s. Idaho and I'll buy you a cool one.
Rol'47 is offline   Reply With Quote
Old December 2nd, 2009, 10:04 PM   #13
waynesoffroad's Avatar
First Name: Wayne
My RZR: 09 RZR S
Member #6297
View waynesoffroad's Photo Gallery(0)
Mine stopped working while it was at the dealer for other repairs. They covered it under warrenty and told me that there was an updated part because it was a common problem.
waynesoffroad is offline   Reply With Quote
Old December 3rd, 2009, 09:08 AM   #14
JJ
JJammo1's Avatar
First Name: JJ
My RZR: 2010 RZR S 800
Member #7368
View JJammo1's Photo Gallery(0)
I think there should be a recall on this from the number of failures. Replaced mine through cheapcycleparts.com about $62. The replacement is much better quality with really good spring.
JJammo1 is offline   Reply With Quote
Old December 3rd, 2009, 09:22 AM   #15
Fast Guy's Avatar
First Name: Pat
My RZR: 2008
Member #4459
View Fast Guy's Photo Gallery(1)
Mine does this occasonially if I let it sit too long. Just pull the steering wheel down all the way & jiggle the leaver. Works every time. (Works for the driver too)
Fast Guy is offline   Reply With Quote
eliminate rzr tilt steering wheel
polaris 700 tilt wheel maintenance
polaris ranger tilt steering problems
polaris ranger tilt steering shock problem
polaris ranger tilt steering wheel repair
polaris rzr broken tilt
polaris rzr tilt steering problem
polaris rzr tilt wheel
polaris tilt steering problems
rzr s adjustable steering shock problems
rzr tilt steering problems
rzr tilt wheel
rzr tilt wheel fix
tilt wheel on a rzr
where is the tilt steering wheel rzr 170
Anyone had troubles with tilt steering ram? pipedup General RZR Discussion 19 March 12th, 2010 09:55 PM
tilt steering problem rzr396 General RZR Discussion 18 April 12th, 2009 02:46 PM
Tilt Steering broken JPBabyRange General RZR Discussion 3 January 27th, 2009 07:28 AM
Tilt steering no longer tilts. JoDyO General RZR Discussion 3 September 24th, 2008 05:27 PM
Tilt steering..... efornshell03 General RZR Discussion 3 May 4th, 2008 02:02 PM
