This is a discussion on How do I reset the Maintance Light? within the General RZR Discussion forums, part of the General RZR category; How do I reset the maintance light after doing the service to the machine?...
Thanks, Hookie |
| Sponsored Links | ||
Re: How do I reset the Maintance Light?
It's in the owners manual. You can also set it up to come on whenever you want.
This may be something to think about, but I use my blinking wrench to time the delay I use after turning on the key and starting the engine. I have found that delay beneficial to allow my system to compensate for any changes since the last time I ran it. Sounds weird, but all my low idles, single cylinder issues, etc. have gone away,
John |
From the Owner's Manual: Programmable Service Interval When the hours of engine operation equal the programmed service interval setting, the wrench icon will flash for 5 seconds each time the engine is started. When this feature is enabled, it provides a convenient reminder to perform routine maintenance. The service interval is programmed at 50 hours at the factory. To enable or disable the service interval: 1. Enter the diagnostic mode. Toggle to the service interval screen. 2. Press and hold the mode switch for about seven (7) seconds, until either ON or OFF appears in the Rider Information Center, depending on your preference. To reset the service interval: 1. Enter the diagnostic mode. Toggle to the service interval screen. 2. Press and hold the mode switch for 2-3 seconds, until the wrench icon flashes. Release the switch. 3. Press and release the mode switch once to advance the setting by one hour. Press and hold the mode switch to advance the hours quickly. NOTE: If you scroll past the intended number, press and hold the switch until the hours cycle back to zero. 4. When the desired setting is displayed, wait until the wrench icon stops flashing. The new service interval is now programmed.
Please send any future inquiries to kyle@utvtech thanks UTV Tech |
John
_______________________________ Romeo, MI |
How do you enter diagnostic mode?
Don't ask to drive it, if you can't afford to fix it! |
#8
Jeez...read the owners manual...didn't you do this when you bought the machine? When you have problems, its an excellent place to start. The response from Dave was excellent.
I've spent hours getting to know my machine's technology and how everthing works. What better way to make your machine better, than to know how it was designed to work. |
#9
I've spent hours getting to know my machine's technology and how everthing works. What better way to make your machine better, than to know how it was designed to work. So I made the mistake of asking the question here. Sorry! I'll look elsewhere.
#10
I've spent hours getting to know my machine's technology and how everthing works. What better way to make your machine better, than to know how it was designed to work. I read mine cover to cover two times, then I bought the factory service manual and read it to familiarize myself with the RZR he is probably the type that sets on the toilet talking on his cell phone not reading something ![]() Someone just spoon feed it to him he dont want to learn anything. |
#11
I've spent hours getting to know my machine's technology and how everthing works. What better way to make your machine better, than to know how it was designed to work. So I made the mistake of asking the question here. Sorry! I'll look elsewhere. Go to a dealer and order one then read it best modification you will spend money on. |
#13
Diagnostic Mode The wrench icon will display when the gauge is in the diagnostic mode. To exit the diagnostic mode, turn the key switch off and on. Any movement of the tires will also cause the gauge to exit the diagnostic mode. To enter the diagnostics mode: 1. Turn the key switch off and wait 10 seconds. 2. Place the transmission in neutral. 3. Hold the mode switch and turn the key switch on. Release the switch as soon as the display is activated. 4. Use the mode switch to toggle through the diagnostic screens.
#14
Never a problem asking a question. You should be able to go to the Polaris dealer and get a replacement. It has a lot of good information in it. As someone noted, perhaps you can download it. But, it would be better to have a printed copy to carry with you.
| Search tags for this page |
2010 f150 wrench icon reset,erase wrench on polaris 900 rzr,how to reset a 2010 polaris service light,how to reset maintance on polaris razor,how to reset service engine light on 2013 500 polaris ranger,how to reset service light on 2010 polaris ranger,how to reset service light on polaris ranger crew 800,how to reset service light on polaris rzr,how to reset service light on rzr,how to reset the wrench light on a polaris rzr,oil change light 2010 polaris ranger,reset electrical system polaris rzr,reset maintance light on razor 2012,reset maintenance light polaris ranger 2009,resetting polaris rzr service indicatir
| Thread Tools | |
| Display Modes | |
| Rzr 170 Got Light? | Jojano | RZR 170 Specific Disccusion | 3 | February 27th, 2010 06:06 PM |
| Reset: King Upgrades for your Rzr S, anyone have them? | Repeat Offender | Suspension | 19 | December 6th, 2009 07:46 PM |
| front end maintance | mountain-rzr | Engine and Drivetrain | 6 | May 27th, 2009 10:51 PM |
| New dfr led light bar | DRAGONFIRERACING | General RZR Discussion | 11 | April 7th, 2009 12:07 PM |
| Blink Code 25 won't reset | racer727 | Engine and Drivetrain | 6 | February 16th, 2009 06:56 PM |
