Help with cabin sealing kit - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old June 24th, 2008, 12:15 PM Thread Starter
Johnpeq's Avatar
Member #1490
View Johnpeq's Photo Gallery(0)
I swear Polaris can make an easy installation challanging.
I have the factory kit (P/N 99161232) and i got the top two pieces in.
The fender well block off has me stumped! The parts are identical but I can't for the life of me figure where they go! I'm assuming the front wells but I'm supposed to drill four holes in Frame?
Help
John
Johnpeq is offline
post #2 of 8 Old June 24th, 2008, 12:23 PM
Commadore's Avatar
My RZR: Green '08
Member #1712
View Commadore's Photo Gallery(0)
Re: Help with cabin sealing kit
Yes, the front fender wells. Look in there and you will see a nut sticking out from the body. The notch in the block off piece is there so that it doesn't hit that nut when you lay them up against the frame. I used heavy duty tie wraps to avoid drilling the frame. They haven't moved an inch.
Commadore is offline
post #3 of 8 Old June 24th, 2008, 12:25 PM
Commadore's Avatar
My RZR: Green '08
Member #1712
Just a note, I believe that the PN that you posted is the pre-production part number. My dealer did not know what that number was. The production part number is 2876900.
post #4 of 8 Old June 24th, 2008, 12:45 PM Thread Starter
Johnpeq's Avatar
Member #1490
Thanks Commadare, yes you are right about the P/N. I tok it off the "Directions" but have the correct part # staring at me on my computer. I'll get out there ater work with your guidance. Does the gen#3 RZR need the two rubber sealing parts?
John
Johnpeq is offline
post #5 of 8 Old June 24th, 2008, 12:51 PM
Commadore's Avatar
My RZR: Green '08
Member #1712
All Gens need the rubber sealing part unless you intend to also RTV everything which is what I did. No more water coming over the firewall ever time you spin the front tires.
post #6 of 8 Old June 24th, 2008, 09:37 PM Thread Starter
Johnpeq's Avatar
Member #1490
Got them in with you suggestions. I'm glad you mentioned using tie-wraps for I didn't want to drill 8 holes in the frame with me spending most of my time around the ocean spray. Now all I need to do is to get a can of spray foam for all the little areas.
John
Johnpeq is offline
post #7 of 8 Old June 24th, 2008, 10:28 PM
Bena's Avatar
First Name: BENA
My RZR: RZR XP4 1000
Member #1604
View Bena's Photo Gallery(0)
Do you have pics by any chance ??
Bena is offline
post #8 of 8 Old June 25th, 2008, 06:11 AM
RZRider's Avatar
First Name: Al
My RZR: 16 Platinum XP1000
Member #482
View RZRider's Photo Gallery(0)
Before
After
RZRider is offline
Exhaust Fumes in cabin at low speeds txmd500 General RZR Discussion 16 December 26th, 2008 12:09 PM
New 09 Exhaust Keep Fumes out of cabin? bluesun General RZR Discussion 1 September 18th, 2008 05:19 PM
Fumes in cabin with full windshield jansboy General RZR Discussion 1 June 5th, 2008 08:34 AM
sealing air box after snorkeling monster1rzr General RZR Discussion 3 March 5th, 2008 12:00 PM
Sealing the Dash RZRider General RZR Discussion 7 January 10th, 2008 09:48 PM
