Hunting with a RZR - Polaris RZR Forum - RZR Forums.net
post #1 of 24 Old June 2nd, 2010, 09:03 PM Thread Starter
Elk Hunter's Avatar
Hunting with a RZR
I am new to the forum and am looking for advice from those that have hunted with a RZR. I have always hunted off a quad and am getting a RZR or Ranger this fall. I want SXS for hunting. I have been caught in a few late summer/early fall storms that have ended my quad days for good. It’s time for a roof and windshield. I want a trail capable SXS that does not kick my butt before I start my hiking. I love the looks of a RZR and want a RZR over the Ranger but I am not decided. I use the quad to go from point A to point B FAST then hike. What are the thoughts of RZR owners? I am a little concerned about ground clearance but have researched lift kits. I am also looking at getting a little wider offset tire for stability. Is that needed?
Elk Hunter is offline
post #2 of 24 Old June 2nd, 2010, 09:08 PM
sandspanker's Avatar
Re: Hunting with a RZR
The only thing I hunt in my rzr are rhinos. welcome to the forum.
sandspanker is offline
post #3 of 24 Old June 2nd, 2010, 09:09 PM
Gunny's Avatar
Hi John, welcome to the forum....Don't hunt ,but there is a bunch of guys on here that do.....Let them find your post and you will get some answers.....
Gunny is offline
post #4 of 24 Old June 2nd, 2010, 09:11 PM Thread Starter
Elk Hunter's Avatar
Thanks guys. I am going to do a lot of trail rides and want something I can really use for hunting as well.
post #5 of 24 Old June 2nd, 2010, 09:12 PM
Gunny's Avatar
Do you have a 50 inch limit on the trails up there?
Gunny is offline
post #6 of 24 Old June 2nd, 2010, 09:14 PM Thread Starter
Elk Hunter's Avatar
No 50 inch limit
post #7 of 24 Old June 2nd, 2010, 09:22 PM
Gunny's Avatar
Well the S model has a roll cage going above the bed ( no game on the bed) The rzr bed is supposed to be able to hold 300 lbs...I don't know what a field dressed elk weighs, but I know it's more than 300 lbs, but as said earlier, let the members who hunt with rzr's find your post.....
Gunny is offline
post #8 of 24 Old June 2nd, 2010, 09:34 PM
Feedback Score: 26 reviews
MotoXXX's Avatar
I use my RZR for a lot of Rhino hunting, but I also use it for Deer & Elk hunting, both rifle & archery. It is so much more comfortable than hunting off of a quad, you won't regret it!
I have never had any ground clearance issues as of yet.
My RZR out archery elk hunting.....
My hunting buddy....yea right!, I wish!!!.....
MotoXXX is offline
post #9 of 24 Old June 2nd, 2010, 09:36 PM
Gunny's Avatar
Jeff , don't cha start another candy thread.... If you get an elk or deer where on the rzr do you put it..?
Gunny is offline
post #10 of 24 Old June 2nd, 2010, 09:40 PM
MotoXXX's Avatar
A deer is no problem, an elk will be multiple trips I would guess. I haven't killed an elk since buying this rig.....maybe it is cursed?.....
MotoXXX is offline
post #11 of 24 Old June 2nd, 2010, 09:44 PM Thread Starter
Elk Hunter's Avatar
The 300 pound rear box is more than the quad I used. It would be multiple trips but they could be fast trips
post #12 of 24 Old June 2nd, 2010, 09:44 PM
Gunny's Avatar
Na, you must be using crooked arrows
Gunny is offline
post #13 of 24 Old June 2nd, 2010, 09:46 PM
Gunny's Avatar
Now the hard part comes...RZR or RZR S
Gunny is offline
post #14 of 24 Old June 2nd, 2010, 09:50 PM
MotoXXX's Avatar
John,
I just added 1" wheel spacers all the way around on mine but haven't had it out to test yet, but I am sure it would add a little stability.
MotoXXX is offline
post #15 of 24 Old June 2nd, 2010, 10:27 PM
willaili's Avatar
Do alot of hunting from my rzr here in alaska. It cannot be beat when it comes to avoiding bad weather. I have a full windshield and top. As for hauling out game there are a couple of options that I found work great. Yes the bed is only rated to 300lbs but with a 2" lift and shocks on the tightest setting I have had over 400lbs of gear and meat(needless to say I looked like Jed Clampett coming out of the woods) in the back. The other option is to remove the passenger seat (for the record I do have friends). I have had a cabelas full guide series wall tent plus the stove, cots, and a cooler in that area. I try to balance the load as much as possible and drive fairly conservativly.
Just my two cents.
The back of the rzr makes a pretty good filet table for salmon and rabbit cleaning station too.
willaili is offline
RZR for hunting? MtnGolfer Engine and Drivetrain 6 October 26th, 2009 12:43 AM
Hunting!!!! billrigg General RZR Discussion 0 September 28th, 2009 07:34 PM
rzr for hunting mountainman General RZR Discussion 18 May 18th, 2009 02:41 PM
Hunting with RZR! DocJohsnon General RZR Discussion 2 January 12th, 2009 11:59 AM
