Adrian, not sure if this is your case, but you may want to run a post search and type in Code 26. I know you said 2.6, but unless they've changed their code numbers they are all even amounts. This would be the vehicle speed sensor or throttle position sensor having an issue. Apparently, it's happened on quite a few 2010's....including the Rzr4. Hope this helps.
thank you ..i have even read those threads before dont know what i was thinking..i was just confused because my manual did not list a 26...speed sensor..... again thanks..
Call the dealer before you tote it over their, from what I have read their still is no fix for the code.
I called my dealer they dont know anything about the error 26 thing, they checked the Polaris web site (guess its a place for techs to go for help?) and their was no bulletin on the error code 26 so he created a ticket on it to let Polaris know I am getting the code 26.
If their is no fix their is no reason for you to take it to the dealer?
Let us know what they say.
I hate to see you spend an hr driving their for them to tell you their is no fix, or to just disconnect your battery for a minute to clear the code.
I am having 26 pop up when I run the diagnostic's on my s(2010).... Somtime when I start it up it seems to be running like the choke is stuck,shut it off and start it back up and everything is normal????????
Yep just called...they had not heard of it...
so i asked them to send the problem to PoPo, he took down my Vin and info and said he will let me know...
We will see:rollfinger:
yep... all i got was come in and we will adjust the belts....
its like when you go to the doctors and they say "its a viral infection" lets do some tests...meaning..we dont have a clue...
I even told him about what was written here, speed sensor and all...but he said Popo had no clue right now "but stay in touch"
maybe if i nailed some wood from one wheel to the other so they don't spin , disconnect the battery i will be fine...sounds like a solution to me!!!!!!!!!!!!
Related Threads
3.1M posts
141.5K members
Since 2007
