Intake issue questions and fixes? - Polaris RZR Forum - RZR Forums.net
View Poll Results: Have you had dust leak past the intake?
YES--with stock setup 333 47.64%
NO--with stock setup 280 40.06%
YES--with snorkels or other setup 32 4.58%
NO--since snorkels or other setup 92 13.16%
Multiple Choice Poll. Voters: 699. You may not vote on this poll
post #1 of 306 Old June 4th, 2008, 09:06 PM Thread Starter
crazeejames's Avatar
My RZR: 08, the faster green one, not the pretty red one ;)
Member #992
View crazeejames's Photo Gallery(0)
Just curious as to how many people have had intake leaking problems, and what kind of conditions they are riding in?
I have friends with RZR's as well as my own, and none of us has had leaking all are Gen2 or 3's, but we don't have silty dust in our area. Should we be snorkleing? Do snorklles fix the intake problems?
Just curious as to how wide spread this is, kind of like the "spacer" removal issues that were so big, but when asked, no one person stepped forward to say they blew a belt due to the spacer be removed.......hoping its a similar case with intake, and just isolated incidences.
crazeejames is offline
post #2 of 306 Old June 5th, 2008, 07:50 AM Thread Starter
Member #992
Re: Intake issue questions and fixes?
So am I assuming that the intake issues are an isolated few in extreme conditions...........with no one replying?
post #3 of 306 Old June 5th, 2008, 08:31 AM
chopperbill's Avatar
Member #443
The first thing I would do is make sure the filter is clamped on tight instead of the "slip it on and hope" method used by Polaris. That stopped dust in my intake. You probably arent getting many replies because there a dozens of topics of different mods folks have done to their machines. Guess a search would find most of them.
chopperbill is offline
post #4 of 306 Old June 5th, 2008, 08:40 AM
Talking bout' Yankee Rose
RickyRazr's Avatar
First Name: Rick James Bitch!
My RZR: Green 3rd Gen
Member #2638
View RickyRazr's Photo Gallery(0)
Gen 3, stock clamps tight, still sucked dust. Just installed UMP. We'll see how it goes.
RickyRazr is offline
post #5 of 306 Old June 5th, 2008, 09:16 AM
utvatv800's Avatar
Member #1895
View utvatv800's Photo Gallery(0)
Same here,Gen 3 and clamps are tight, with the polaris foam filter and dust still getting by. I live in western colorado and it can be very dusty here. Last ride was in moab just a 100 miles away and rode about 60 miles. After we rode 1st trail whitch was about 30 miles I changed the foam outer filter with the spare one That I carey with me, whitch is foam also. Both were full of dirt and dust and so was the paper filter. I have a 2002 sporstman 500 that did the same ride and there was a small amount of dust on foam but none on the paper, so it is a wide spread problem that Polaris needs to step up to the plate and FIX IT.
utvatv800 is offline
post #6 of 306 Old June 5th, 2008, 09:29 AM
trevorsride's Avatar
My RZR: 2012 XP 900 Liquid Silver LE
Member #54
View trevorsride's Photo Gallery(0)
Gen one with Extreme snorkels on mine, and no dust past the stock filter.
2012 XP Liquid Silver LE
trevorsride is offline
post #7 of 306 Old June 5th, 2008, 11:11 AM
Mudrocksandman
tdc1200's Avatar
First Name: Tom
My RZR: 2008 800EFI
Member #2307
View tdc1200's Photo Gallery(0)
if you have dirt in you airbox and down in your throttle body, and if you seem to burn oil at all you need to get in on the class action lawsuite if you expect anthing to come of this problem. This will will cause thousands of dollars of damage to you machine. Dealerships are declining you proper repair. call 415-455-1326 ext 223 ask to speak with Harry. this is a big lawfirm trying to put together a big claim. you need only give them basic info. there is no cost to you. if you snooze you loose people! Polaris needs to step up!
tdc1200 is offline
post #8 of 306 Old June 5th, 2008, 12:17 PM
Member #443
I have a hard time telling if folks are complaining about dirt in the AIR BOX or dirt getting PAST the filter and into the intake leading to the engine. I see lots of post of people talking about dirty air boxes and filters but that is not the problem, it is dirt getting PAST the filter that is.
post #9 of 306 Old June 5th, 2008, 06:10 PM
Grumpy Rider
Grumpy Rider's Avatar
Member #750
View Grumpy Rider's Photo Gallery(0)
Mine is a Gen1, I bought it back in August. I had already read of the intake issue back then. Needless to say, I didn't do more than 1 ride to see that there was an issue with dust getting into the throttle body. I quickly devised a two stage system to allow the intake end to filter the air before it even got to the airbox. This system along with going over the entire intake system sealing everything along the way, has cured this issue for me. Now, even regular maintenance on the airbox filter is minimal, as the intake end catches most all. Many have followed this design with success.
I ride in varied conditions, from dusty mountain region, silty deserts, ocean, dunes.
Here's a link to it....
PRC Ranger Club, LLC :: View topic - My intake Mod / Intake filter / UPDATE
Grumpy Rider is offline
post #10 of 306 Old June 5th, 2008, 07:38 PM
HivoltageRZR's Avatar
My RZR: Gen 3
Member #2522
I checked my airbox and there is a small hint of dust in it. But I only have 4 hours on it. My question Is this weekend I am gonna be doing some trail riding which is usually high water can I silicone the lid good just to be on the safe side?
2008 Polaris RZR - 29.5" Outlaws - SS 312 - SSV Works Overhead System - 2" Lift kit - Polaris Sport Roof - Dynatek CDI- Viper 3500 Winch - Custom Snorkels - HL Lift Springs - RZR S Exhaust - Super ATV Axles
HivoltageRZR is offline
post #11 of 306 Old June 5th, 2008, 07:41 PM
TNRZR's Avatar
First Name: Bobby
My RZR: 2014 XP1000
Member #800
View TNRZR's Photo Gallery(2)
I just returned from 2 days at Turkey Bay. The dust was really thick. My airbox and filter where dirty but the intake throat was clean. I cleaned the pre filter, blew the filter out with air until the dust stopped coming out, greased the filter and the cap and I'm going back in July. I have a GEN 2 with no problems yet. Knock on Wood!!!!!
TNRZR is offline
post #12 of 306 Old June 5th, 2008, 08:22 PM
DesertSportsman's Avatar
Member #207
View DesertSportsman's Photo Gallery(0)
Mine is a Gen 1 and it was pulling in the fine dust. Since POPO didnt seem to want to do anything about it I opted to replace the intake with the UMP before blowing up a motor and then having to wait for POPO to hopefully approve a new one. Almost 800 miles on the first filter with the UMP and it still looks new... Tells you something about the difference in the two... Stock vs. UMP..
DesertSportsman is online now
post #13 of 306 Old June 6th, 2008, 03:34 AM
azrzrguy's Avatar
First Name: Dan
My RZR: 08 Green Gen 2
Member #2594
View azrzrguy's Photo Gallery(0)
I have stock setup w/ uni and prefilter. No problems now. I ride in high desert conditions and help friends run in whiplash series.... tons of dust.
azrzrguy is offline
post #14 of 306 Old June 6th, 2008, 03:57 AM
LTZ470's Avatar
My RZR: Gen 1
Member #777
View LTZ470's Photo Gallery(0)
Right on Bill...I pulled the stocker first thing installed a K&N and CLAMP!!!! No brainer...I thought Polaris or the Dealer had left the clamp off by mistake!!!
LTZ470 is offline
post #15 of 306 Old June 7th, 2008, 10:15 AM
rzrdog's Avatar
Member #2799
View rzrdog's Photo Gallery(0)
rzrdog is offline
Intake questions? TRXR General RZR Discussion 3 January 23rd, 2009 09:50 PM
Is the airbox/intake issue fixed in the '09 RZR? tommy1170 General RZR Discussion 33 December 21st, 2008 12:25 PM
Air Intake Issue dniss Member Introductions 3 October 7th, 2008 12:11 PM
Air Filter / Intake.... Another dust issue adrenalinfanatic Engine and Drivetrain 7 August 22nd, 2008 10:51 AM
air intake questions... mudweiser-z71 General RZR Discussion 4 May 13th, 2008 09:32 AM
