May 23rd, 2008, 05:42 PM
air filter maintenance
Just ordered a Uni air filter for my Rzr. Does anyone know the difference between the uni filter kit and the k&n?? I have a k&n kit and wonder if it would be usable on the uni.
May 23rd, 2008, 06:38 PM
Re: air filter maintenance
The Uni Is double foam, oilable unit..I feel it is better for protection than the K&N but they still suck dirt because of the negative pressure or Vaccume the engine puts on the canister/ silencer.Polaris must address this issue...I will post a You tube video of a Uni filter that sucked dirt as soon as it uploads..Meanwhile you can watch this..
YouTube - RZR air filter
May 23rd, 2008, 08:50 PM
mudweiser-z71
First Name: scotty
My RZR: green 2008
hello; when you say canister/silencer do you mean exhaust?
i should be receiving my gibson ss exhaust system next week.
i have a k&n filter that i clean regularly.
will this new exhaust help fix the dist sucking prob.?
May 23rd, 2008, 09:45 PM
My RZR: Gen 1
Let us know what Polaris says about that video. I would be interested in hearing what they think of that.
May 24th, 2008, 06:57 AM
Yes here is a Video of a Uni that sucked dirt as well..After three differant filters, this machine has lost 25 lbs of compression per cyclinder in 18 hrs...And we check filters every time we ride..The air box does not have enough volume of incoming air that the engine requires under hard acceleration causing a vacuum effect in the airbox. No filter can stop negative pressurized dust . It is a little long so bare with it..
May 24th, 2008, 07:31 AM
Dr. RZR
First Name: dean
My RZR: 08 grn gen 2
great vid! You would have the same results with many filters that i have tried! The best results are with the AFE pro guard 7 I have 50 miles no dust! But due to the poor air box design i am waiting for my dragonfire snorkled cyclone canister!! I will keep you posted!
May 24th, 2008, 07:43 AM
Yes at this point we have a fix for this flaw..But the damage to the engine is done.I can feel a power loss and down 25lbs of compression per cyclinder is unacceptable...I want a new topend out of this ...
May 24th, 2008, 07:54 AM
ARZEEAR
My RZR: 2008 Red RZR
What should the compression be for new?
I haven't done any mods to my air filter yet. What do you reccomend for keeping the dirt out as of now?
I want a cleanable re-usable filter, do you have some part numbers for me? Thanks in advance.
May 24th, 2008, 07:59 AM
Dr. RZR
First Name: dean
Guess i need to get the ol comp. tester out! After 150 mi. and a lot of dust i'm afraid of what I will find!! Does not seem to be low on power but the idle is totally erratic!! Beds coming off tonight to prepare for the dragonfire, so I will check comp. then get the PLEDGE out for some dusting of the throttle body!!
May 24th, 2008, 09:06 AM
Polaris service manual states compression range from 150lbs to 200lbs per cylinder. Leave other plug in, and of course both plug boots away from any metal. Hold throttle completly open. Spin over engine till a max reading is achieved...Usually about 8 to 10 seconds.Ive done this with the engine warm and cold. The reading was the same.
Your idle is all over the place because the sensor in the air tube from canister to carb is covered in dusty material . If you remove filter and spray WD-40 on this sensor, plus clean the entire intake track out .Your idle will go back to 1180 to 1220.
My experiance anyway..
May 24th, 2008, 12:17 PM
+1
2008 RZR
May 24th, 2008, 02:55 PM
My RZR: 2008 3rd Gen
Do you have a link to a source for this filter. Or a model number? I've looked around and only find them for cars.
May 24th, 2008, 04:05 PM
Dr. RZR
First Name: dean
The filter is a brand new part # you need to call them!!951-493-7100 part #87-10034
May 24th, 2008, 05:58 PM
My RZR: Gen 3
whoa do i really need a better air filter??
will my new rzr lose lots of compression as stated? there hasnt ever been anyone complaining about loss of horsepower or compression on the rzr. Is the dust getting in there quite common and serious? and is this good if i have to get one? RANGER RZR TRUE FLOW AIR FILTER from Polaris Ranger & Ranger RZR Access. & Apparel
May 24th, 2008, 06:27 PM
ssroadster
My RZR: Green
Could you let us know what the fix is!
