Poping and clanking noise from left front?
This is a discussion on Poping and clanking noise from left front? within the General RZR Discussion forums, part of the General RZR category; I have a brand new 2008 with 48 hrs on it. It just started making this poping and clanking noise on the front left wheel. ...
Old March 10th, 2010, 06:40 AM
rockytopper's Avatar
Member #10303
View rockytopper's Photo Gallery(0)
I have a brand new 2008 with 48 hrs on it. It just started making this poping and clanking noise on the front left wheel. This is occuring when I make a full lock left turn. It is happening in 4x4 or 2x4 mode. What is going on? Do I need to check or correct something.
Thanks in advance
RZR Rookie
Old March 10th, 2010, 07:08 AM
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
Re: Poping and clanking noise from left front?
You either have a bad CV joint or broken front hub, either way you need to jack up your RZR and fix it quickly before you do more damage or are left stranded on the trail. My bets are on one of the the CV joints, probably the outer one.
Just wondering how can you have a new 08 with 48hrs? Its 2010 and 48 hrs is certainly not a new ride or do you mean you just purchase a used RZR that is new to you.
1 Limey in a world of Yanks
Old March 10th, 2010, 07:34 AM
Member #10303
I bought it new from a dealer about 5.5 months ago I guess I better get it in before the warranty runs out.
Old March 10th, 2010, 07:55 AM
Member #10303
Just my luck go figure, After looking it was bought on 8/29/2009 it appears my warranty ran out 2 weeks ago. Darn it................ I guess all that power drifting in the snow did in the cv joint.
Old March 10th, 2010, 08:11 AM
Just Chuck's Avatar
Just Chuck
First Name: Chuck
My RZR: 09 RZR S
Member #6362
View Just Chuck's Photo Gallery(0)
Try graesing the wheel bearing mine did the same thing when i turned. took it apart and greased it and it was cured
Old March 10th, 2010, 09:14 AM
Member #10303
Thanks Chuck I will try that that first.
Old March 10th, 2010, 11:15 AM
atvkris's Avatar
have u seen my goat?
First Name: kris
My RZR: green 09 rzr
Member #12913
View atvkris's Photo Gallery(0) Send a message via MSN to atvkris
my friend had the same prob, talked to the dealer and they sent him a shim, no charge, took care of it instantly no more popping clunking.
  #8
Old March 10th, 2010, 12:15 PM
Member #10303
Sorry for my ignorance I'm a rookie and have only changed the air filter & oil so far. Were does the shim go? Another words what was making the noise on you friends RZR?
  #9
Old March 10th, 2010, 12:28 PM
Stumpduster's Avatar
First Name: Mike #688
My RZR: 08 Rzr.....
Member #1676
A new 08 ........imagine that!
Here you go, way back in the early days this was a well known issue. Luckily if this is your problem it is cheap and easy.
http://www.rzrforums.net/attachments..._end_noise.pdf
Polaris Team Tip issued 08-08-01
  #10
Old March 10th, 2010, 03:07 PM
atvkris's Avatar
First Name: kris
Member #12913
just as it says thanks stumpduster
  #11
Old March 10th, 2010, 03:26 PM
Member #10303
Thanks Guys. I called my dealer and he said that they had to do this to a couple of machines they have sold. He ask for my VIN number to determine if my 2008 is one of the models that could have this issue. Apparently it was corrected some time in 2008 production. I didn't have the vin number will call the dealer again tommorrow. I will check it out this evening to see if there are signs of it being something else like a cv joint. Thanks again for the help. Sense I didn't buy a warnanty I'll have to learn how to work on these bad boy toy's.
  #12
Old March 10th, 2010, 03:53 PM
cowkicker84's Avatar
First Name: Troy
My RZR: 08 RZR
Member #8939
View cowkicker84's Photo Gallery(9)
hard to grease a sealed bearing dont ya think??????????????
  #13
Old March 10th, 2010, 04:44 PM
Just Chuck's Avatar
Just Chuck
First Name: Chuck
My RZR: 09 RZR S
Member #6362
It was the splines on the shaft that i ended up greasing not the wheel bearing, I thought it was the wheel bearing my bad
  #14
Old March 10th, 2010, 07:40 PM
rzrnaz's Avatar
My RZR: 2010 S
Member #1446
View rzrnaz's Photo Gallery(0)
2008's are notorious for having a popping noise from the front. The shim fixes them because it allows the castle nut to torque up properly.
  #15
Old March 13th, 2010, 09:57 AM
Member #10303
Thanks for the heads up atvkris the spacer did the trick. I didn't even have a socket to fit the nut to use my torque wrench. I just grapped a 1-1/16 wrench and snucked it on and wala it is quite as a mouse. Cost 1.34
Thanks again
Rocky
popping noise behind left front wheel DEERHUNTERBOB General RZR Discussion 7 March 13th, 2010 04:33 AM
poping noise 09 rzr ryan85 Engine and Drivetrain 0 February 14th, 2010 02:50 PM
Popping noise at front left wheel DEERHUNTERBOB General RZR Discussion 2 April 30th, 2009 08:29 PM
Front End Clanking Noise...HELP CRAZYRZR85 Engine and Drivetrain 6 April 17th, 2009 07:08 PM
poping in left front axle???????? mudweiser-z71 General RZR Discussion 3 October 13th, 2008 10:25 PM
