Glacier 2 Snow Plow is JUNK!!! - Polaris RZR Forum - RZR Forums.net
This is a discussion on Glacier 2 Snow Plow is JUNK!!! within the General RZR Discussion forums, part of the General RZR category; Hey everyone, 2 months ago I purchased this system and we got over 2 feet of snow in the past 2 days. The part of ...
Old February 6th, 2010, 07:29 PM   #1
cran19972000's Avatar
Member #8252
View cran19972000's Photo Gallery(0)
Hey everyone,
2 months ago I purchased this system and we got over 2 feet of snow in the past 2 days. The part of the plow that clips to the frame is bent and now it wont even stay on the plow mount. Has anyone else had problems with this system and does anyone know of a better plow system? I tried to take some decent pics but I had to crop them down a lot.
ID:	11730   Click image for larger version
ID:	11731   Click image for larger version
ID:	11732   Click image for larger version
cran19972000 is offline   Reply With Quote
Old February 6th, 2010, 07:47 PM   #2
RadRed44's Avatar
My RZR: 2010 800
Member #9228
View RadRed44's Photo Gallery(18)
Re: Glacier 2 Snow Plow is JUNK!!!
I wondered how that mount would hold up. It has a good lift angle, but it just doesn't seem as beefy as the ones with the push tubes that run underneath.
'10 RZR 800 - Sage Green
'08 Sportsman 800 Touring LE - - Sunset Red
RadRed44 is offline   Reply With Quote
Old February 6th, 2010, 07:53 PM   #3
Member #8252
Here are some more pics.
ID:	11735   Click image for larger version
ID:	11736   Click image for larger version
ID:	11737   Click image for larger version
ID:	11738   Click image for larger version
Old February 6th, 2010, 08:08 PM   #4
san4rd's Avatar
First Name: Shane
My RZR: 2009 Red RZR
Member #8395
View san4rd's Photo Gallery(0)
Hmm... I have a Glacier II, and I have not seen this type of fatigue. I use my pretty heavily, even pushing gravel and rock around during the summer. I have a feeling the problem could be a warranty issue, take it back to the dealer and ask them.
I suspect maybe the flop over springs may be too tight or you hit something very very hard, maybe on the corner of the plow blade?
I had trouble with my on machine mount looking "tweaked" but what I found was the mount had come loose, and slid back.
san4rd is offline   Reply With Quote
Old February 6th, 2010, 08:40 PM   #5
Feedback Score: 16 reviews
guy48065's Avatar
Member #309
Welcome to the forum!
IMO The Glacier plow is a nice unit and the quick mount/dismount is a good feature. Nobody likes to crawl on the ground to hookup a tube-mount plow and I've read some complaints that the frame mounts that remain can hang up the machine on rocks so nothing's perfect. The Glacier is weak but so is a Rzr. You just can't hammer it into a pile of snow without something giving. Hopefully you didn't bend your frame, too.
guy48065 is offline   Reply With Quote
Old February 6th, 2010, 08:46 PM   #6
RMR Man's Avatar
First Name: Steve
Member #11566
I looked at that plow, and decided it wasn't up for a rough winter. If you look at the hefty steel and reinforcements on a Wheel Horse or John Deere garden tractor plow, you'll see that they have learned the lessons of Severe Duty! Snow plows rank #2 in abusive use. First is "ground breaking implements" such as turning plows etc. Take 1000 pounds of RZR, add 40 HP and 15 mph. Mix together for 30 minutes. Result? One he!! of a tweaked mess of steel.
RMR Man is offline   Reply With Quote
Old February 7th, 2010, 08:22 AM   #7
guy48065's Avatar
Member #309
You're absolutely right. A JD plow mount is 1/4" boilerplate and attaches to 1/4" boilerplate. The blade is at least twice as thick as the Glacier. The arms on mine were 3/8" thick. The Glacier is thinwall square tube. There's no comparison at all--my BBQ grill has a stronger frame
BUT the Rzr does a much better job for me and I'm not too concerned about damaging it on familiar territory. After I got the Glacier & tried it out I sold my JD & hydraulic plow. No regrets in my 2nd year of plowing with the Rzr/Glacier.
There's no way I would use a Rzr to plow commercially on strange streets & drives. I know there are several here that do & maybe it pays good enough to repair any damage...?
Old February 21st, 2010, 07:52 PM   #8
Southern Indiana Hoosier
kvissing46's Avatar
First Name: kevin
My RZR: 2009 red RZR
Member #9594
View kvissing46's Photo Gallery(0)
I have used my Glacier 2 all winter and have also tweeked my tubular arms. I also wore out several wear cups or whatever u call them. Take the wear cups and throw them away and buy a 3 inch by 60 inch by 3-8th thick blade to replace the factory one. Use the old blade for template to drill your new blade. ( mine came from scrap pile). Also my bolts continue to loosen on the frame connection to the RZR. Next year I will use good lock nuts. I also will weld a plate to the bottom of the tubular arms to strengthen and keep them from wearing out dragging on the ground.
kvissing46 is offline   Reply With Quote
Old February 21st, 2010, 08:04 PM   #9
inthetundra's Avatar
First Name: Art
My RZR: 08 RZR
Member #12971
View inthetundra's Photo Gallery(17)
I haven't had a problem with mine and I am not gentle with it. I live out in the sticks and we get plenty of snow.
inthetundra is offline   Reply With Quote
Old February 22nd, 2010, 02:43 PM   #10
kvissing46's Avatar
First Name: kevin
Member #9594
I have been very careful with mine. It doesn't take much to bend that tab that changes angle or the whole tubular attachment. Be careful.
Old January 23rd, 2012, 06:22 PM   #11
joelfuns's Avatar
Member #35156
View joelfuns's Photo Gallery(0)
Just bend my Tab that changes the angle... Any idea if that item is available for replacement from the dealer or if it's a warranty item? First time I used the plow!!
joelfuns is offline   Reply With Quote
Old January 23rd, 2012, 06:27 PM   #12
NickPic83's Avatar
First Name: Nick
My RZR: 2011 RZR S LE Orange Madness
Member #21937
View NickPic83's Photo Gallery(0)
i live in NY and this is my 2nd season using it and so far its been great. no issues here and i love it so far
I.B.E.W. L.U. 363 Journeyman
2011 RZR S-LE Orange Madness w/ 3500lb winch, UTV inc doors, E-brake, XP flares, sport roof, HID's, Barkers dual exhaust, DMC fuel controller, UTV intake, grumpy rider mod, RDC 2" lift, RT dual rate springs, DFR harnesses, EMP tinted half windshield, LED reverse/work light, led interior lights, bed extender, LED fog lights up front
NickPic83 is offline   Reply With Quote
Old January 23rd, 2012, 07:02 PM   #13
diggerbuzz's Avatar
First Name: Brad
My RZR: 2012 Xp 900 LE
Member #18641
View diggerbuzz's Photo Gallery(0)
I have had mine on my ranger for 2 years also and no problems at all . works great and i have pushed alot with it.
diggerbuzz is offline   Reply With Quote
Old January 23rd, 2012, 07:11 PM   #14
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Our local dealer won't sell them anymore. One of the few factory parts the dealer refuses to stock or special order. -Polaris doesn't make the blue plastic plow blade they released earlier this year. It's been removed from the Polaris accessory site. Wonder why...
FunRide is offline   Reply With Quote
Old January 23rd, 2012, 07:19 PM   #15
NickPic83's Avatar
First Name: Nick
Member #21937
def glad i have the black metal plow. would never go for the plastic one
2008 glacier 2 snow plow
curtis plow polaris ranger
glacier 2 plow quick mount
glacier 2 snow plow parts
glacier ii plow
glacier ii plow system
glacier plow reviews
glacier plow system for polaris ranger quick release
glacier snow plow
glacier snow plows
polaris glacier ii 52 plow
polaris glacier ii plow system
rate glarcier 2 plows for ranger
used polaris glacier plows
who makes polaris snow blades
Glacier II Snow Plow Mount goatheady Polaris RZR Parts For Sale 7 January 30th, 2010 07:44 PM
Glacier 2 Plow??????? Cuzin Eddie General RZR Discussion 7 December 31st, 2009 11:32 PM
Glacier II Plow Brad777 General RZR Discussion 30 December 18th, 2009 05:22 PM
Glacier Plow for Rzr rzrcrzr General RZR Discussion 10 March 11th, 2009 12:37 PM
Glacier Plow michigan mudder General RZR Discussion 1 August 18th, 2008 09:27 PM
