Gas Mileage - Polaris RZR Forum - RZR Forums.net
post #1 of 28 Old January 25th, 2010, 10:38 AM Thread Starter
chizetown's Avatar
Member #10551
View chizetown's Photo Gallery(0)
Gas Mileage
Have a 2010 RZR LE with no performance mods, bone stock. I went riding this weekend and managed to get 50 miles on a tank of gas. NO hard or fast riding mostly about 15-20 on wooded trails.
This is only the second time I have rode the RZR since purchased brand new in October of 2009. Just wanted to see if that was about right for a RZR. I had a Ranger XP before and could get about 120 miles on a tank, granted it was a 9 gallon tank instead of 7.5.
So is it normal to only get about 50 miles on tank based on the type of riding? The fuel light started to flash and I could see the bottom of tank when I opened it up.
Thanks.
chizetown is offline
post #2 of 28 Old January 25th, 2010, 10:43 AM
Ronzo's Avatar
My RZR: '09 Sunset Red LE
Member #4558
View Ronzo's Photo Gallery(0)
Re: Gas Mileage
Unless I'm really pushing it, I can get 100 miles out of a tank.
Ronzo is offline
post #3 of 28 Old January 25th, 2010, 10:57 AM
Overlord's Avatar
First Name: Jason
My RZR: 09 800 (Red)
Member #7311
View Overlord's Photo Gallery(0)
Re: Gas Mileage
To be honest 50 miles is not much at all. I get better than that regularly.
Overlord is offline
post #4 of 28 Old January 25th, 2010, 11:06 AM
Trail Junky
Dusty's Avatar
First Name: Brian
My RZR: 08 Rzr
Member #20
View Dusty's Photo Gallery(0)
Re: Gas Mileage
Not sure if it's the same as the older models, but I can usually squeeze an extra 1 1/2 to 2 gallons of gas in my tank if spend the extra 10 minutes or so letting the tank burp when I'm filling it.
From 0 to 1 bar on my guage I only get 4 1/2 to 5 gallons tops if I don't burp the tank.
I think I am right around 100 miles on a full tank.
Brian
Otsego, Mi
08 Mean Green
Dusty is offline
post #5 of 28 Old January 25th, 2010, 11:11 AM Thread Starter
chizetown's Avatar
Member #10551
Re: Gas Mileage
Brian
I was thinking the same thing because when I filled it up before I left once the gas reached the neck I was done. But when I filled up at the after riding on the trail I got a little over a gallon in once it reached the neck and I let it settle.
Any reason why the machine would get such poor mileage?
post #6 of 28 Old January 25th, 2010, 11:18 AM
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
Re: Gas Mileage
Were you in low gear alot, this will reduce milage. If not slipping clutch belt or engine problems like a stuck injector.
XP1000 Titanium Black
RZR 800 put out to pasture
1 Limey in a world of Yanks
rjsmith is offline
post #7 of 28 Old January 25th, 2010, 11:25 AM
shanek62's Avatar
First Name: Shane
My RZR: 2009 RZR-S
Member #4990
View shanek62's Photo Gallery(14)
Re: Gas Mileage
I get around 10 mpg. Same as my snowmobile. More on the throttle faster gasoline goes, I'm sure that is fresh info. : (
2009 RZR-S; Street legal; 29" x 8.5" DOT approved Super Swampers from Interco; custom windshield wsher & wiper; parking brake; blinkers; bright lighhts with lighted switch and .......
shanek62 is offline
post #8 of 28 Old January 25th, 2010, 11:25 AM
gunrunner's Avatar
First Name: Man
Member #4830
Re: Gas Mileage
100 miles on a tank? wow, thats the best i ever heard of! Mostly A rzr will get 10mpg at best, a S a little less,( 7.2 gallons 72 miles) but i bet it wasn't full, when you gas these things up it will fill to the neck, then if you shake the rollbar you can watch it go down, it will take a gallon or more if you keep doing this. Also dont put much in the flashing low fuel light it starts when most times you still have a few gallons left. The only way to truly check your mpg is to completely fill it to the top after much shaking then set the trip meter and at the end of the day fill it again and do the math.
gunrunner is offline
post #9 of 28 Old January 25th, 2010, 11:27 AM Thread Starter
chizetown's Avatar
Member #10551
Re: Gas Mileage
Yeah I noticed it will go down when it reaches the neck and you can keep putting fuel in it.
I was in high all day no low range. Seemed kinda low, but figured I would just check here and see what's up.
post #10 of 28 Old January 25th, 2010, 11:31 AM
polyol's Avatar
My RZR: 09 RZR
Member #6951
Feedback Score: 5 reviews
View polyol's Photo Gallery(0)
Re: Gas Mileage
I can get dang near 100 miles at the dunes...though ive never truly ran it bone dry.
polyol is offline
post #11 of 28 Old January 25th, 2010, 11:33 AM
Orca's Avatar
First Name: Dennis
My RZR: 2009 RZR-S
Member #12048
View Orca's Photo Gallery(0) Send a message via AIM to Orca
Re: Gas Mileage
I get 85 to 100 miles per tank and I ride it like I just stole it..... and in the sand where it requires alot of gas......
"enjoy your ride"
Dennis AKA "air Walter"
Orca is offline
post #12 of 28 Old January 25th, 2010, 11:51 AM
Searching_ut's Avatar
First Name: Jeff
My RZR: 2010 800 LE
Member #11223
View Searching_ut's Photo Gallery(0)
Re: Gas Mileage
I've got a 2010 LE myself, and think that sounds about right. Like others have said, filling the tank all the way takes time and a little work. I've found mine also starts flashing, and like you mentioned looks to be empty a long time before it actually quits. Trail riding I've killed a tank in just under 50 miles, and on forest service roads, mostly high range I've gotten just shy of 100 miles on a tank.
Not to hijack a thread, but how is everyone carrying their spare fuel? I just strap a can to the bed, but find that doesn't work very well. Is anyone having luck finding cans that fit the polaris mount? What other good options are there?
Searching_ut is offline
post #13 of 28 Old January 25th, 2010, 11:56 AM
Jack Daniels please..
GEEZER's Avatar
First Name: Clem
My RZR: 09 Camo
Member #8938
View GEEZER's Photo Gallery(0)
Re: Gas Mileage
I usually get @ 100 miles also.. I just strap a 2.5 gal also looking for something better..GEEZER
2009 RZR Camo
1985 Yamaha Tri-z
2007 Crew cab D-MAX
"Why don't you practice falling down, Ill be there in a minute..." BJL 2004
GEEZER is offline
post #14 of 28 Old January 25th, 2010, 12:59 PM
rjsmith's Avatar
First Name: Ralph
Member #4388
Re: Gas Mileage
Spector 2 1/2 Gal gas tank at Kragen fits, except it that that POS carb filler neck.
rjsmith is offline
post #15 of 28 Old January 25th, 2010, 01:29 PM
hayfarmer's Avatar
Member #6591
View hayfarmer's Photo Gallery(0)
Re: Gas Mileage
i haul xtra gas in a polaris gas rack and a jug from walmart
hayfarmer is offline
Duramax gas mileage mdmigliori Tow Rigs, Trailers and Camping 29 April 2nd, 2011 10:35 PM
RZR Mileage simpleandy General RZR Discussion 2 November 6th, 2008 09:10 PM
Who's done the highest mileage in their RZR Alexlebrit General RZR Discussion 0 April 21st, 2008 04:49 AM
Gas Mileage wribbs General RZR Discussion 7 March 18th, 2008 07:27 AM
