Front Axle Issues
This is a discussion on Front Axle Issues within the General RZR Discussion forums, part of the General RZR category; Is anyone else having any problems with their front axles??? I rode it for the first time and both front axles starting clicking. Took it ...
Old April 19th, 2008, 01:24 PM
misi68's Avatar
Member #2151
View misi68's Photo Gallery(0)
Front Axle Issues
Is anyone else having any problems with their front axles??? I rode it for the first time and both front axles starting clicking. Took it into the shop and they said water poured out of the boots when they removed them. Had the axles replaced, took it out this past weekend and the left front is clicking again. I did not "mud" it this time. Only normal trail riding. I am curious if anyone else is having problems, so when I call the dealer on Monday, I can have some ammo. I really love my Rzr but I do not want to have to take it in the shop every time I ride it.
Old April 19th, 2008, 02:54 PM
08800rzr's Avatar
First Name: joe
My RZR: 2008 black
Member #382
View 08800rzr's Photo Gallery(0)
Re: Front Axle Issues
i had the same problem with the front axles called the dealer and they told me to pull the carter pin and tight the axle nut and so i did and the clicking went away but now mine are clicking again going to try it again
Old April 20th, 2008, 04:50 PM
lawley's Avatar
Member #2167
View lawley's Photo Gallery(0)
i have had my rzr for about 4 or 5 months and i went up a hill in four wheel drive and when the front end set down it made a loud pop. It has been poping ever since. I think i broke the cv joint cage.
Old April 20th, 2008, 06:47 PM
stacrzr's Avatar
Build Your Own
My RZR: Green G2
Member #1216
View stacrzr's Photo Gallery(0)
The front broke at the spline. Polaris replaced because under warrenty.
axle clicking
poalris rzr front axle loose
front axle
2003 polaris front end loose
Rectifier mounted in front of radiator. Issues? Rob4092xx General RZR Discussion 11 February 8th, 2009 07:32 PM
Front Axle Removal crazywatson Projects and How-To 7 January 16th, 2009 11:39 AM
poping in left front axle???????? mudweiser-z71 General RZR Discussion 3 October 13th, 2008 10:25 PM
Front axle THNKTWCE RZR's and Parts 0 August 5th, 2008 07:08 PM
Front axle loose supertuner Engine and Drivetrain 4 May 11th, 2008 05:24 PM
