RZR Heater - Polaris RZR Forum - RZR Forums.net
RZR Heater
This is a discussion on RZR Heater within the General RZR Discussion forums, part of the General RZR category; I have been doing some research on some heaters and found one from Flex-a-lite. It looks like a good setup and looks to be a ...
Old November 1st, 2009, 09:15 AM   #1
RazeCraze's Avatar
My RZR: 2009 RZR-S
Member #5128
View RazeCraze's Photo Gallery(0)
RZR Heater
I have been doing some research on some heaters and found one from Flex-a-lite. It looks like a good setup and looks to be a popular set up in jeeps. The heater sells for $160.00 and also had a duct kit that can be bought seperatly. Does any body know how to plumb this in the the heater system in the rzr. Some of the heaters out on the market run from 300.00 to 450.00 this could be a cheaper install for about half the dollars. Any help would help before the chill season starts.
RazeCraze is offline   Reply With Quote
Old November 1st, 2009, 09:55 AM   #2
addicted
Rzr in NH's Avatar
First Name: Mike #4
My RZR: 2016 rzr s 1000
Member #4434
View Rzr in NH's Photo Gallery(0)
Re: RZR Heater
There is a post on here about a heater you can get at jc whitneys its a 3 speed and costs 100-200 and the quality is 10 times the polaris heater.
09 DirtyDawg Performance Clutch Kit. 3 inch roktek lift, 1.5" holz wheel spacers (rear), 28" Mud lites on itp ss312, Arctic Thunder Kustoms snorkel kit, DFR seats and Harnesses, Viper mx 4500 winch
2016 rzr s 1000 polaris roof. much to come
Rzr in NH is offline   Reply With Quote
Old November 1st, 2009, 12:39 PM   #3
EUROPEAN RZR
palangui's Avatar
First Name: Palangui
My RZR: RZR 800 09
Member #7336
View palangui's Photo Gallery(0) Send a message via Skype™ to palangui
Re: RZR Heater
I have a second radiator inside the car working as heater and it works perfect. I ca show you some picks if you want.
Another cheap solution is this one:
Coleman Golfcat Portable Catalytic Heater - Find lowest price on Coleman Golfcat Portable Catalytic Heater at Shopping.com
SPEED FREAK
Braking is cowardly
palangui is offline   Reply With Quote
Old November 1st, 2009, 03:24 PM   #4
lawnman's Avatar
Member #10894
View lawnman's Photo Gallery(0)
Re: RZR Heater
I just got one with my beaver pro cab kit. It looks just like this.
The install was great, comes with all plumbing and fittings to tap into heater hoses. Pretty easy install overall.
lawnman is offline   Reply With Quote
Old November 1st, 2009, 04:01 PM   #5
Trail Junky
Dusty's Avatar
First Name: Brian
My RZR: 08 Rzr
Member #20
View Dusty's Photo Gallery(0)
Re: RZR Heater
I like this one from rangerware 2008-10 POLARIS RANGER RZR 800 CAB HEATER WITH DEFROST!:eBay Motors (item 300361675212 end time Nov-27-09 12:01:54 PST)
It has a windshield defrost. Haven't tryed one personally, but I like how it's setup.
I've seen these go from Breese for $350 or less.
Brian
Otsego, Mi
08 Mean Green
Dusty is offline   Reply With Quote
Old November 1st, 2009, 04:06 PM   #6
ncrider's Avatar
First Name: Scott
My RZR: 2010 RZR S
Member #9621
View ncrider's Photo Gallery(0)
Re: RZR Heater
I just ordered the same heater. $379.00 from my dealer. i hope it's as good as it looks.
ncrider is offline   Reply With Quote
Old November 1st, 2009, 05:54 PM   #7
RazeCraze's Avatar
My RZR: 2009 RZR-S
Member #5128
Re: RZR Heater
If you go to Flex-a-lite web you can look at the heaters that I have been looking at. The heater offers more heat and defrost ducts. The unit from summit racing is about 160.00. I found a post on the rhino forum with one installed and he said it worked great. Just looking for the perfect setup.
Old November 1st, 2009, 06:39 PM   #8
Feedback Score: 5 reviews
tightline's Avatar
My RZR: RZR 4 XP
Member #3399
View tightline's Photo Gallery(0)
Re: RZR Heater
When looking at the rangerware unit on the web it looks like it takes up the storage area in the front under the hood. Can anyone confirm if it takes all that space or if it is mounted below the "trunk" in the front?
tightline is offline   Reply With Quote
Old November 1st, 2009, 07:49 PM   #9
RZRDan's Avatar
My RZR: 2008 RZR
Member #2054
View RZRDan's Photo Gallery(0)
Re: RZR Heater
I run the Rangerware heater on a 2008 Gen 3, it does not take up the storage area, but it is a snug fit.
RZRDan is offline   Reply With Quote
Old November 1st, 2009, 08:30 PM   #10
Tunnel vision's Avatar
My RZR: 2009 RZR S
Member #9031
View Tunnel vision's Photo Gallery(11)
Re: RZR Heater
I have been looking at that heater, however I do have a question.
Do you have any pics of it installed?
It looks like from the picks on eBay the fans are exposed to the elements, mud, snow and water.
And if it has the fan intake outside of the cab it would not re-circulate the heat...am I seeing it wrong?
Dan
Tunnel vision is offline   Reply With Quote
Old November 1st, 2009, 08:46 PM   #11
My RZR: 2009 RZR S
Member #9031
Re: RZR Heater
I like that cab, how is it? I'm looking to by a cab.
I really want the Bestop soft cab, but the looks of the Beaver Pro is great!
Does it rattle or squeak? How about when you take it of in the summer are there a lot of holes or bracket left behind?
Doe's the heater keep the cab comfortable, how did you fill all of the hole that are in the RZR floor and under the dash?
Is yours on a RZR or RZR S?
Will you post up some pics of you cab installed?
Dan
Old November 1st, 2009, 09:23 PM   #12
RZRDan's Avatar
My RZR: 2008 RZR
Member #2054
Re: RZR Heater
Sorry no pics..
It is exposed but has held up well for over a year of use. It uses outside air but has no problems keeping my soft side cab warm, I have used it at -15F pushing snow. The problem with using outside air is if it grabs snow dust or water from splashing it steams the windshield instantly - suprisingly that is not often. If that doesn't answer your questions let me know.
Old November 1st, 2009, 09:43 PM   #13
jerrzr's Avatar
Member #1635
View jerrzr's Photo Gallery(0)
Re: RZR Heater
IT KEEPS ME WARM! Flex-A- Light ,but when I bought mine it was $150
jerrzr is offline   Reply With Quote
Old November 2nd, 2009, 01:43 AM   #14
Better Friend Than Enemy
Repeat Offender's Avatar
My RZR: 2016 Turbo
Member #5088
View Repeat Offender's Photo Gallery(4)
Re: RZR Heater
That's a nice little unit.
Repeat Offender is offline   Reply With Quote
Old November 2nd, 2009, 05:02 AM   #15
lawnman's Avatar
Member #10894
Re: RZR Heater
Yes it is great! It has two vents on the bottom side as well you can aim towards your feet!
2013 polaris rzr s fire extinguisher holder
best rzr heater
diy rzr heater
heater for rzr
heater rzr
how to install a store heater pics
pics of heater for polaris rzr installed
polaris rzr heater
polaris rzr heater kit
rzr forum
rzr heater
rzr heater and how it works
rzr heater cheap
rzr heaters
summit cab heater in rzr
Added A Heater billyboy_1 Lighting, Stereo and Electrical 8 December 20th, 2010 06:50 PM
Polaris Rzr Heater goatheady Polaris RZR Parts For Sale 20 October 30th, 2009 12:46 PM
heater install jerrzr Projects and How-To 18 January 1st, 2009 07:07 PM
For the do it yourself RZR heater people TennesseeRXP Projects and How-To 28 September 24th, 2008 03:40 PM
heater pictures jerrzr Projects and How-To 0 August 28th, 2008 07:29 AM
