April 6th, 2008, 08:55 PM
bajatruks
Stock RZR Hood
Went out today on the rzr's first trip on dirt and the hood flew off 3 times when i went 35 so i finally took it off. Does anybody know a good fix?
April 6th, 2008, 09:31 PM
ARZEEAR
My RZR: 2008 Red RZR
Re: Stock RZR Hood
I had 0 isues with the hood coming off. Are you sure you're locking it in right?
April 6th, 2008, 09:58 PM
First Name: Al
My RZR: 08 Red
Re: Stock RZR Hood
I'd make sure the front hooks are under the plastic and not sitting on top.
April 7th, 2008, 10:43 AM
Re: Stock RZR Hood
Yeah I have had the hood fly off on both a Gen2 and Gen3 RZR. It seems to be an issue with the lower bracket that presses against the hood being to thin and flexing...
I just made it out of thicker material and that has seemed to fix the problem.
April 7th, 2008, 11:51 AM
First Name: Al
My RZR: 08 Red
Re: Stock RZR Hood
Hmnnn, I wonder if running the Holz grill made a difference, stiffer frontal area or something because I tow mine at 70 plus and run the desert at WOT through all the terrains thown at me-no hood loss yet. I better knock on wood.
April 7th, 2008, 12:49 PM
Re: Stock RZR Hood
What I found agrees with what everyone has said:
http://www.rzrforums.net/general-rzr...blows-off.html
My hood very obviously *snaps* into place when pressed down in front. YMMV
Now a 2-Rzr household.
http://tinyurl.com/8ltm8
April 7th, 2008, 10:11 PM
bajatruks
Re: Stock RZR Hood
what did you use to make the new piece?
April 7th, 2008, 10:29 PM
akpa18
First Name: Vern
My RZR: 800
Re: Stock RZR Hood
I have a good fix!! I had this problem, expecially when the front was loaded with gear in the little cubby. I race snowmachines, and you can use some of that technology to help you out. I put 3 extra hood latch's on mine. We use them to keep our couling on while we are rolling at 100 mph. They are a cheap fix and look excellent on the RZR. I put one on each side towards the rear 2 corners, and then one pulling straight down on the front. I have not had any problems since then. Polaris makes them as a kit or you can buy them aftermarket through Western Power Sports. Good Luck.
