March 31st, 2008, 11:25 AM
Touchy Throttle Fix?
I replaced the spring with the heavier one, wrapped tape around the cable roller and it's still tough to manage (rock climbing). Any ideas? Just got back from Moab, it was great, but needs a lift too!
April 1st, 2008, 10:02 AM
Black Bart
First Name: Bart
My RZR: Fully Loaded RED RZR
Re: Touchy Throttle Fix?
ScottCo,
Who did u get the heavier spring from? When compared to the stock spring, could u tell any difference?
Reason for asking... I've taped roller also welding 2 pieces of angle iron to original stock pedal arm, thus added about 1/4 to 1/2" preload to spring. Biggest change was removing stock pedal w/spring and replace with a flat non movable pedal set at a different angle. Bart
April 1st, 2008, 10:14 AM
I got the spring on Ebay. Basically it just is wound tighter and maybe a little heavier wire. It helped a little, but not what I was expecting. What pedal are you using?
April 1st, 2008, 02:25 PM
Most people complain about the throttle being touchy as they ride fast over bumpy trails. This shouldn't be the case when rock crawling. What problem are you having?
Now a 2-Rzr household.
http://tinyurl.com/8ltm8
April 1st, 2008, 04:38 PM
It seems to be all or nothing. Especially in the rocky stuff.
April 1st, 2008, 04:45 PM
My RZR: '08 Red Gen 3
Best way I've found is to rest the right side of your foot on the ridge next to the gas pedal for stability. Then roll your foot onto the gas pedal.
April 1st, 2008, 04:56 PM
If you do lots of slow technical riding like rock crawling you might want to do some work to the clutch so it engages just off idle and upshifts much slower to give you more control.
April 1st, 2008, 05:02 PM
The best way to fix the touchy throtle and the cheapest is to buy a 1.50 cent sponge and put it under your peddel, it works great, no jumping just a smothe peddel.
April 1st, 2008, 05:05 PM
This sounds like what I want. How does one do that? Is there a kit?
April 1st, 2008, 05:09 PM
I like this better, do you use one thick enough to stay or attach it somehow?
April 1st, 2008, 05:58 PM
Yea you just put a thick sponge inthere and it stays.
April 1st, 2008, 06:00 PM
I went to wallmart and bought a sponge where the car washing stuff is and just wedge it in there
April 1st, 2008, 06:30 PM
2008 Gen 3 RZR
First Name: Will
My RZR: Gen 3, Built 2/11/1008
Even on a Gen 3 with the heaver factory spring I still find I have to do the same thing as Rubidude, rest the side of my foot on the center righe.
April 1st, 2008, 07:44 PM
Black Bart
First Name: Bart
ScottCO, As I said earlier, I used stock pedal arm, just stiffened it up a bit, but the biggest change was getting rid of the stock pedal w/the spring. I found that this just made the problem worse because of the tilting motion. As I did was remove the plastic foot piece w/spring, cut a smaller foot out of aluminum and JB welded it in place. The replacement foot is about 1" shorter and set at the same angle as the stock. So far it appears to be working and I have clutch kit that engages at about 1800 rpm, much higher than stock. If you do much rock crawling, you should check with EPI. They seem to know quite a bit about dialing in a RZR for specific needs. If not try the sponge, heck if it doesn't work on the pedal, you can always use it to wash with.
If you're interested, I could try to post a pic of what I've done.
At any rate, GOOD LUCK, Bart
April 2nd, 2008, 08:19 AM
Just try the sponge guys ,what do you have to loose it does work and yes you can use it to wash with I do.
