Is there a thread or can someone help with parts and installation tips for a power block setup. This is what I want and everything should only be able to power up when the key is on.
1. Poly Planor Mp3 with two small speakers
2. Two Baja style bumper fog lights
3. 32" light bar - (maybe)
4. Maybe two small lights shining to the rear
Please help with mounting location and best place to run the wiring. Thanks!!
Well, first you have to run your positive & negative feed from your battery use at least 10 gauge wiring (some people have used a cheap/small jumper cables) heat shrink, crimp and solder connections. I ran mine with all the wires along the drive shaft area with all the other wires and zip tied every feet or so to keep it out of the way. The small wire already going to block is your "accessory power". I would recommend putting your lights (light bar & rear pods) on a always on and use a relay and if possible a 30 amp switch.
If mounting anything on the roll bar on top, you can access the roll bar by the front bolts and fish your wires up to the first cross member or all the way to the back. Take your time, run the wires right & use a relay and it will look good & you won't have to worry about issues.
Related Threads
3.1M posts
141.7K members
Since 2007
