Throttle freeplay adjustment - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old July 29th, 2009, 08:30 PM Thread Starter
DEERHUNTERBOB's Avatar
Member #3898
View DEERHUNTERBOB's Photo Gallery(0)
Guys i looked in the manual at the throttle freeplay adjustment it says lossen the lock nut and turn thr adjuster until you achive the correct freeplay, well which way do you turn the adjuster? I turned it counter clockwise as i was standing on the drivers side, adjusted a little bit no real difference in the freeplay any suggestions
DEERHUNTERBOB is offline
post #2 of 9 Old July 29th, 2009, 08:41 PM
MotoXXX's Avatar
First Name: Jeff
Member #4542
Feedback Score: 26 reviews
Re: Throttle freeplay adjustment
I can't remember without looking at it but I do remember I had to turn mine over 1/4" to get to 1/8" freeplay at the pedal end of the cable so just turn it in the counterclockwise direction but alot farther this time. If it gets more slack in the cable turn it the other way instead. It made quite a difference on my RZR.
MotoXXX is offline
post #3 of 9 Old July 29th, 2009, 09:20 PM
Polaris RzR LE
ctate's Avatar
First Name: Clarendon
My RZR: 2009 LE
Member #6805
View ctate's Photo Gallery(0)
What does adjusting the throttle play do?
ctate is offline
post #4 of 9 Old July 29th, 2009, 09:26 PM
King of crash!
Member #787
well if yours is to tight it will idle high and be hard to shift...if too lose youll never get full throttle
johnnycat8 is offline
post #5 of 9 Old July 30th, 2009, 09:48 AM
johnny crash!!!
ugot8up's Avatar
My RZR: 09 rzr
Member #7331
View ugot8up's Photo Gallery(26)
make shore locking nut is loose. Then turn the ajuster counter clock if you are on driver side. just did mine, so much better!!!
ugot8up is offline
post #6 of 9 Old June 26th, 2010, 07:12 AM
08rzrCT's Avatar
First Name: Zac
My RZR: 08
Member #10695
View 08rzrCT's Photo Gallery(0)
Just did mine. Counterclockwise is more play, clockwise is less. As you turn it clockwise when you get to a certain point you will feel the throttle pick up or just watch your rpm's if your hard at hearing.
One thing I noticed after I adjusted mine.....I've never heard the rev limiter before!!!
Should I leave it like this or back it down a little. I have almost no play now in my throttle ped. Then again 1/16" ain't much.
-Zac
08rzrCT is offline
post #7 of 9 Old June 26th, 2010, 09:06 AM
MotoXXX's Avatar
First Name: Jeff
Member #4542
It is supposed to be 1/16" - 1/8" so you're good, but if you want a little more free play then add a little but don't over do it, you'll not be getting full throttle if you do!
MotoXXX is offline
post #8 of 9 Old July 17th, 2010, 07:29 AM
08rzrCT's Avatar
First Name: Zac
My RZR: 08
Member #10695
This is really tickin me off. I'll set me throttle freeplay to almost nothing and by the time I slide that boot back over and put my seats back in and go to drive it,it's completely back to where I started.....too much play and bouncy as hell. Am I doing something wrong? Should I maybe look into one of those springs?
08rzrCT is offline
post #9 of 9 Old April 25th, 2017, 02:12 PM
Fire214's Avatar
First Name: Dennis
My RZR: XP-4 1000
Member #170585
View Fire214's Photo Gallery(0)
I just got my 2014 xp1000 out of the shop and it was idling high at 1400-1500. I looked at these threads and couldn't find it in my shop manual, so I called back the shop. They said there was no an adjustment and it was electronically controlled at the peddle and you can reset the computer idle by turning the key to ON for 1 minute... then turn it OFF for 3 minutes... then start it up and it should reset. It didn't right away but I took it around the block to warm it up and the idle went back to 1200.
Fire214 is offline
CHECK YOUR THROTTLE PLAY !!!! MAY be only gettin 3/4 throttle LvDirtJunky Engine and Drivetrain 148 August 28th, 2016 06:40 AM
Tie rod adjustment Danny RZR-S Specific Discussion 6 December 23rd, 2008 10:57 AM
Help!! Tie rod adjustment on RZR-S mdebone1 Engine and Drivetrain 6 December 10th, 2008 08:49 AM
rzr toe adjustment tr325 General RZR Discussion 4 September 5th, 2008 09:48 AM
Camber Adjustment wheeler34man Suspension 3 July 1st, 2008 08:11 PM
