Manual line lock as a parking brake
This is a discussion on Manual line lock as a parking brake within the General RZR Discussion forums, part of the General RZR category; Has anyone looked into this or used a manual line lock like the one Jamar makes? I think installiation would be a bit more detailed ...
Old July 3rd, 2009, 05:36 AM
Hayden's Avatar
My RZR: 2009 S
Member #8369
View Hayden's Photo Gallery(0)
Has anyone looked into this or used a manual line lock like the one Jamar makes? I think installiation would be a bit more detailed but there would not be a draw on the battery. I'm looking for something I can leave enguaged while trailering or maybe over night. Anyone have any experiance or opinions?
Hayden
Old July 3rd, 2009, 07:53 AM
guy48065's Avatar
Feedback Score: 5 reviews
Member #309
Re: Manual line lock as a parking brake
I'll give you the opinion of someone who's done it both ways. I put a manual one on mine and it does work as expected but it's a big PITA to install. Of course some of that was my own fault for wanting to install it under the console with only the knob coming through. If you don't buy someones kit you have to hunt down the high pressure hose & fittings--or cut, bend & flare hardline to fit.
Then you have to bleed the brakes. In the end you have a manual pressure lock that will hold pressure indefinitely as long as you dont have any leaks in the lines or calipers.
A later post showed how to use a clutch or brake cable to hold the pedal down to keep the brakes applied on all 4 wheels. Way easier to install & cheaper.
I now have both...LOL
The pedal lock will hold pressure on the entire system for hours but mine will not hold overnight. I guess the piston in the master cylinder will bleed off a little pressure over time. The manual lock seems to hold forever--but how long do you really need it anyways?
Old July 4th, 2009, 07:17 PM
speedjunky's Avatar
First Name: Tom
Member #2409
View speedjunky's Photo Gallery(0)
I have insthauled my own line lock type parking brake. Yes it will put a draw on the battery. I did put a larger battery in for my stereo.But I love the way it works. I will say some of the manual line locks that I have seen on this site look nice. Not so much the ones that pull on the brake peddle. If you use any type of Hydraulic type of set up I think you will be happy. My ony quetion is why do you need it over night? Do you park on a hill over night?
Old July 4th, 2009, 07:49 PM
bagman's Avatar
My RZR: Gen 1
Member #649
I do occasionally. Seems to make mine run better.
manual line lock
line lock parking brake
Jamar hydraulic parking brake
manual line lock parking brake
line lock for emergency brake
Parking Brake for the RZR ThrottleOut Projects and How-To 61 July 17th, 2010 06:41 PM
Parking brake?? qdawg1976 General RZR Discussion 6 October 11th, 2009 03:45 PM
In line rear brake lock Larrymay General RZR Discussion 4 July 2nd, 2009 10:13 PM
RZR line lock brake leenanj Projects and How-To 15 March 5th, 2009 04:34 PM
Parking Brake txmd500 Engine and Drivetrain 0 April 23rd, 2008 08:55 PM
