Is the Air Filter problem now fixed
This is a discussion on Is the Air Filter problem now fixed within the General RZR Discussion forums, part of the General RZR category; I was just into the Polaris dealer and asked about the air filter on the 2009 Razor and was told that Polaris is on their ...
Old June 24th, 2009, 04:57 PM
Larrymay's Avatar
My RZR: 09 Rzr
Member #8458
View Larrymay's Photo Gallery(0)
I was just into the Polaris dealer and asked about the air filter on the 2009 Razor and was told that Polaris is on their third filter design and the the new one is the larger diameter filter that is 6 to 7 inches in diameter and has no foam cover. Mine is a 4/09 manufacture that has the three clip cover and this larger filter. Evidently the older ones were a smaller diameter. SO are the newer filter working out ok?
Old June 24th, 2009, 05:21 PM
SideBySideSports's Avatar
Member #1404
View SideBySideSports's Photo Gallery(0)
Re: Is the Air Filter problem now fixed
the filter is not the problem. it is where the air box attaches to the throttle body. this detaches and allows unfiltered air and other debris into the throttle body
http://www.SideBySideSports.com
5% off Coupon Code: rzrforums
Old June 24th, 2009, 05:44 PM
cornwelltoolman's Avatar
First Name: Nick
My RZR: 09 red LE
Member #8090
View cornwelltoolman's Photo Gallery(0)
They Fixed the problem of the hose sliping of but I went to the dunes sat
and got a ton of sand in my filter box and a small amount got past the filter
Put on a uni filter with pre filter cover today will see how it works
Old July 16th, 2009, 06:17 PM
Larrymay's Avatar
My RZR: 09 Rzr
Member #8458
Just and update on the filter. I only have 136 miles on my 2009 razor and about half is on dusty roads/trails.
I opened the filter can cover and same amount of dust on the inside of the can, outside of the filter, which I would expect. I pulled the filter and the inside of the filter was clean and the tube/hose going to the carb was very clean. So far it looks good.
Old July 16th, 2009, 07:22 PM
san4rd's Avatar
First Name: Shane
My RZR: 2009 Red RZR
Member #8395
View san4rd's Photo Gallery(0)
Wrench Re: Is the Air Filter problem now fixed
x2... I have 185 miles on mine, no dirt inside the filter. Not even a speck. The link to the TB is much tighter and there is a foam seal on the bottom of the MUCH larger canister type filter.
I even took it out in an plowed field (lots of very fine dust) and rode the hell outta it... .then checked.. dirt in the canister, but nothing past the filter.
--just my two cents... and your actual mileage may vary....
Old July 16th, 2009, 07:31 PM
gone!!!!!!!
Feedback Score: 6 reviews
Member #787
some say yes and some say no....i still have the stock filter well.... housing..i have a uni with outer wear and only 2 times had anything get by....and not alot....BUT alot still have problems
lots of toy's
Old July 16th, 2009, 08:05 PM
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
I was doing okay with the new filter and grumpy air mod, but for piece of mind I changed to the UMP filter, i like the fact that the UMP canister does not fill up with dirt or sand. I feel piece of mind with the UMP and it definately breaths better than the stock filter.
1 Limey in a world of Yanks
  #8
Old July 16th, 2009, 08:15 PM
GIFF-TURBO RZR's Avatar
Feedback Score: 15 reviews
Member #3946
View GIFF-TURBO RZR's Photo Gallery(147)
I put a UMP on my RZR-S at mile 0 and 500 miles later its still clean and tight........I am putting one on the Green Hornet next
bigmike needs a rearview mirror so he knows when I'm about to lap him
  #9
Old July 16th, 2009, 10:05 PM
Larrymay's Avatar
My RZR: 09 Rzr
Member #8458
What is an UMP filter?
  #10
Old July 16th, 2009, 10:07 PM
rjsmith's Avatar
First Name: Ralph
Member #4388
UMP Filter made by Unique Metal products, aluminum canister with a donaldson cyclone type filter inside. Search UMP on the forum for more details, these are one of the best filters you can put on your machine to stop dust intrusion.
  #11
Old July 16th, 2009, 10:36 PM
mattman11's Avatar
mattman11
First Name: Matt
My RZR: 2009 RZRS
Member #7600
View mattman11's Photo Gallery(0)
09 rzrs with a stock canister and aftermarket filter. just turned 1000 miles 2 weeks ago mostly dunes and dusty trails no problems yet!!
  #12
Old July 17th, 2009, 08:24 AM
Larrymay's Avatar
My RZR: 09 Rzr
Member #8458
What brand Air filter is good to use in the stock can for the 09 Razor?
  #13
Old July 17th, 2009, 11:37 AM
polyol's Avatar
My RZR: 09 RZR
Member #6951
View polyol's Photo Gallery(0)
What vendors sell the UMP setup?
  #14
Old July 17th, 2009, 11:49 AM
Member #1404
Larry - try the UNI
Poly - we sell the UMP and have plenty of them in stock and will ship today
  #15
Old July 17th, 2009, 12:32 PM
guy48065's Avatar
Feedback Score: 5 reviews
Member #309
The best filter I found for the stock canister was the AFE dry synthetic filter Item# 81-10034.
Search Results for 81-10034 - aFe Power
It's the one at top right in the photo. This is a much better made filter than the Uni, TrueFlow or either of the Polaris paper filters. Way easy to clean--just tap it gets most of the crud out, wash in plain water to get the rest.
I had to drill a hole in the canister to pass a socket & extension through to tighten the clamp. The filter is too fat to reach around.
(Like some of the post whores here)
Airbox/Intake Fixed - RZR 170 bilinvic RZR 170 Specific Disccusion 10 July 30th, 2010 09:11 AM
will k&n filter oil work with uni foam filter thomphj General RZR Discussion 4 June 8th, 2009 04:48 AM
Is the airbox/intake issue fixed in the '09 RZR? tommy1170 General RZR Discussion 33 December 21st, 2008 12:25 PM
problem with 4wd -help cwbonn General RZR Discussion 9 August 25th, 2008 03:49 PM
Gen 3 air box problems fixed? RickRZR Engine and Drivetrain 32 July 14th, 2008 07:37 PM
