How much play/slop should the Tie Rod-->Hub Have?
This is a discussion on How much play/slop should the Tie Rod-->Hub Have? within the General RZR Discussion forums, part of the General RZR category; The wife said the steering felt a little weird last time she drove so I went to checking things out. The rack appears fine and ...
Old May 11th, 2009, 06:03 PM
Brady84's Avatar
My RZR: 2009 Red
Member #6568
View Brady84's Photo Gallery(1)
Question How much play/slop should the Tie Rod-->Hub Have?
The wife said the steering felt a little weird last time she drove so I went to checking things out. The rack appears fine and does not have the displaced spacer like some have mentioned. But I can grab both wheels and torque them with my hands right-->left and (the same forces changing directions on the steering wheel would cause) and I notice a decent amount of slop or free play. This is with the RZR on the ground, not jacked up. Is there supposed to be a amount of free play between the tie rod and the hub? I cannot remember what mine was like new because well I never checked! Too busy ing You can feel it through the steering wheel as well, it feels like a small vague area between neutral and full engagement of the rack/pinon/wheel system, though grabbing the tire with your hands and torqing it is the best method. Can someone please run out to their garage and check for turning play in the front wheels?
Old May 11th, 2009, 06:50 PM
davidj's Avatar
First Name: davidj
My RZR: red 800
Member #6614
View davidj's Photo Gallery(8)
Re: How much play/slop should the Tie Rod-->Hub Have?
I have no play at all on my 09. 18 hrs
09 Red Rzr - Brake Lock - 27" Big Horns -
Back up lites - lots of scratchs
09 500 sportsman XP 08 500 sportsman HO
06 Suzuki Eiger 04 long bed Duramax
20' WW trailer (hauls 4 rzr 's)
Don't take life so seriously, no one gets out alive.
Old May 11th, 2009, 07:07 PM
HivoltageRZR's Avatar
My RZR: Gen 3
Member #2522
i have some play in mine when it was new it didnt have any play. I have been wondering the same thing.
2008 Polaris RZR - 29.5" Outlaws - SS 312 - SSV Works Overhead System - 2" Lift kit - Polaris Sport Roof - Dynatek CDI- Viper 3500 Winch - Custom Snorkels - HL Lift Springs - RZR S Exhaust - Super ATV Axles
Old May 11th, 2009, 07:12 PM
bajarzr's Avatar
First Name: chuck
My RZR: gen two
Member #3074
View bajarzr's Photo Gallery(0)
i had all kinda loose. untill i had my steering rack,all 4 ball joint's,2 outer tie rod's and both hub bearing's replaced, last week ,now i have zero play in all direction's
Old May 11th, 2009, 07:19 PM
King of crash!
Member #787
0 play
Old May 11th, 2009, 07:37 PM
Brady84's Avatar
My RZR: 2009 Red
Member #6568
Thank you all for the quick response! I absolutely love this site, so much information can be learned in such a short time span. I will look into this more tomorrow and post my findings. The slop definitely originates at the joint between the tie rod and the hub on my unit.
Old May 27th, 2009, 08:29 AM
Brady84's Avatar
My RZR: 2009 Red
Member #6568
I got my replacement Tie Rods installed finally and it has completely eliminated the slop in the steering system. You can feel how worn out the ends are by hand after I got them removed. Check you front wheels and if there is slop then you might need new rod ends. Made a huge improvement on mine, just remember that the threads are left handed on both sides of the RZR.
  #8
Old May 27th, 2009, 09:00 AM
swingarm1's Avatar
Feedback Score: 137 reviews
First Name: Tim
My RZR: XP 4/2 APEX UTVINC IRONMAN EDITION
Member #7690
NONE... RZRTECH has replacement tie rods etc. that's where I bought mine... Quality products and fast shipping... Call or email Andy...
  #9
Old May 27th, 2009, 03:11 PM
My RZR: Gen 3
Member #2522
how do you check for tie rods jack up front and move wheels side to side?
  #10
Old May 27th, 2009, 05:18 PM
Brady84's Avatar
My RZR: 2009 Red
Member #6568
You don't have to jack it up the ground. Just go out and grab the front and rear of the tire and torque right to left, if your tie rod ends are worn out you'll fell your tire rotate in them. Just look in behind the tire at the end when you torque the tire.
I really like the look of the RZR tech tie rods but if I'm going to go the heavy duty route then I'm either going to do the RackZilla or the Gear One full rack.
  #11
Old May 27th, 2009, 06:26 PM
Johnpeq's Avatar
Member #1490
View Johnpeq's Photo Gallery(0)
I have the gearone system, quality product,
John
are tie rods supposed to move
are tire rod ends suposed to move
atv tie rods have lots of play
how much play should be in a tie rod
how much play should tie rods have
how much play tie rod
how much should a tie rod move
how to check tie rod play
i got car on jack how much freeplay should the wheel have
my tie rods have an inch of slop when i move my tires
should a tierod have any play
should tie rod ends move
should tie rods have play in them
should tie rods move
tie rod moves in hub
Front wheels have play in them sandaddict General RZR Discussion 26 October 1st, 2008 11:54 AM
Front Differential Noise & Play W_A_Watson_II Engine and Drivetrain 6 August 4th, 2008 08:43 PM
Throttle free play BlackRaptor General RZR Discussion 1 July 30th, 2008 11:07 AM
New WV RZR for play 1bowhunter Members Rides and RZR Of The Month Contest! 3 June 4th, 2008 03:17 PM
