Complete Fluid Change - Polaris RZR Forum - RZR Forums.net
This is a discussion on Complete Fluid Change within the General RZR Discussion forums, part of the General RZR category; I chnaged my motor oil last week gonna change front and rear diffs and tranny fluids.I bought all fluids the other day. So how is ...
Old April 23rd, 2009, 09:51 PM   #1
HivoltageRZR's Avatar
My RZR: Gen 3
Member #2522
I chnaged my motor oil last week gonna change front and rear diffs and tranny fluids.I bought all fluids the other day. So how is changing the tranny fluid it looks like it might be a pain? Also id like to find a measuring bottle with a bendable hose to fill with with you guys think?
2008 Polaris RZR - 29.5" Outlaws - SS 312 - SSV Works Overhead System - 2" Lift kit - Polaris Sport Roof - Dynatek CDI- Viper 3500 Winch - Custom Snorkels - HL Lift Springs - RZR S Exhaust - Super ATV Axles
HivoltageRZR is offline   Reply With Quote
Old April 23rd, 2009, 11:04 PM   #2
Feedback Score: 18 reviews
GIFF-TURBO's Avatar
First Name: Gary
Member #3946
Re: Complete Fluid Change
I went to the marine store and picked up a funnel that has a rubber hose on the end.......works perfect $8
GIFF-TURBO is offline   Reply With Quote
Old April 24th, 2009, 12:33 PM   #3
canaan canam's Avatar
Member #6499
View canaan canam's Photo Gallery(0)
i got tired of fighting it and bouht 3 good pump oil cans 1 for lt 1 for diff and 1 for chaincase works for me
canaan canam is offline   Reply With Quote
Old April 24th, 2009, 12:41 PM   #4
hunter257's Avatar
My RZR: 08 RED
Member #3923
View hunter257's Photo Gallery(0)
autozone has a great measuring funnel with a hose. I think I paid like 4 bucks for it.
hunter257 is offline   Reply With Quote
Old April 24th, 2009, 12:44 PM   #5
KC
KCCOMPUTERS's Avatar
First Name: Kevin
My RZR: 08 Red RZR
Member #5370
View KCCOMPUTERS's Photo Gallery(52)
Im a part time manager at Autozone, I use the pump, works way better, Plus I drop the skid plate, makes it alot easier too. KC.
KCCOMPUTERS is offline   Reply With Quote
Old April 24th, 2009, 12:49 PM   #6
hunter257's Avatar
My RZR: 08 RED
Member #3923
which pump kc?
Old April 24th, 2009, 12:58 PM   #7
KC
First Name: Kevin
My RZR: 08 Red RZR
Member #5370
Hand Pump.
AMSOIL - AMSOIL Hand Pump For Bottles
I tried to find one at autozone.com but couldnt. Autozone does carry them and they are like 8 or 10 bucks. and they fit quart or gallon bottles. Good Luck.. KC.
Old April 24th, 2009, 01:38 PM   #8
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Does that pump work good for putting oil in through the dipstick tube for an oil change?
It took me a long time to get two quarts down the dipstick tube because it is so close to horizontal and the oil kept backing up the funnel. I was thinking of lifting the front of the RZR next time to increase the angle. Any tips?
:rzrs:
Old April 24th, 2009, 01:43 PM   #9
KC
First Name: Kevin
My RZR: 08 Red RZR
Member #5370
Yeah, you could do that with it. I didnt, I pumped it through the fill hole but I know that the little cone end on the hose will fit in the dipstick tube if you want to do that. KC.
Old April 24th, 2009, 02:07 PM   #10
Tuf-Skin's Avatar
Member #2228
Fill hole? Where is that? The service manual says to fill it through the dipstick tube...
Thanks!
:rzrs:
Old April 24th, 2009, 02:10 PM   #11
KC
First Name: Kevin
My RZR: 08 Red RZR
Member #5370
Wrench Re: Complete Fluid Change
Thanks!
:rzrs:
Only Engine Oil. Not trans or transfer or diffs. Or you can fill the engine through the breather hose on the valve cover. KC.
Old April 24th, 2009, 05:52 PM   #12
Brady84's Avatar
My RZR: 2009 Red, 2015 XP 4 1000
Member #6568
View Brady84's Photo Gallery(1)
Changing all of them is not bad at all as long as you have a tube on the end of your funnel. I just have a regular funnel and some clear tubing from Home Depot. The plugs that have the most hassle are the gearcase plugs through the skid plate but a 3/8" extender bar 6" or 10" makes it fairly reasonable. Just fill till the fluid pours out of the respective hole.
Both my Gearcase chambers and my front diff were below recommend spec from the factory, only my rear diff had enough fluid.
Brady84 is offline   Reply With Quote
2008 polaris rzr fluid capacity
2011 polaris rzr 4 complete oil change
change fluids in 2009 rzr s
changing rzr fluids
complete lubricant change on 2014 polaris rzr
completen fluid change on 08 polaris rzr
fluid change
fluid change 2009 rzr s specs
fluid changes
how often should i change my front and rear differential fluids in my polaris ranger
polaris rzr fluid change kit
rzr fluid change
rzr s complete oil change
videos on how to change fluids on a 2008 polaris razr
youtube vidio on changing fluids on a polaris razor
Trans fluid speedjunky Engine and Drivetrain 31 February 3rd, 2017 10:26 AM
Brake fluid MujZeptu General RZR Discussion 3 March 17th, 2009 05:38 PM
How often to change fluid in heavy water/mud ridding? Brady84 General RZR Discussion 4 March 9th, 2009 07:18 PM
Finished 1st Fluid Changes BlackBart General RZR Discussion 16 February 23rd, 2009 12:49 PM
Has Anyone Had To Add Fluid To A There New Rzr?? r6realtor General RZR Discussion 7 September 5th, 2008 03:44 PM
