Old February 4th, 2008, 10:11 PM
BlackBart's Avatar
Black Bart
First Name: Bart
My RZR: Fully Loaded RED RZR
Finished 1st Fluid Changes
Just completed changing ALL fluids in my RZR. I decided to do this early after checking the levels and discovering that BOTH the front drive and rear end were EXTREMELY LOW. I'm very lucky in that I have only 19 miles on the unit, however I would sincerely advise anyone to check their fluid levels as soon as you get the unit home, irregardless of whether the dealer says that they have checked it.
NOW FOR A QUESTION? Upon checking the fluid in the rear end, I discovered that it had a MILKY color. What could have caused this and would this be a WARRANTY issue?
Remove advertisements
Sponsored links
Old February 4th, 2008, 11:23 PM
My RZR: Greenie soon to be Black 83
Re: Finished 1st Fluid Changes
Bart, How many fluids are there to change? engine, is it all in one? no separate trans fluid? both axles, is that all? Im not good with all that changing yet!
Old February 4th, 2008, 11:59 PM
bart the simple answer to your question is 1 water 2 no
2006 silverado 2500 hd
2006 additude toy hauler
2008 polaris rzr
2006 suzuki ltr450
2005 kawisaki kfx700
2003 suzuki z400
2003 honda ex250
Old February 5th, 2008, 09:43 AM
BlackBart's Avatar
Black Bart
First Name: Bart
hitman,
engine & filter - engine drain thru skidpan opening
front drive
transmission - drain thru skidpan opening
main gearcase - drain thru skidpan opening
rear drive - drain thru skidpan opening
The owners manual contains the part #'s and approx. quantities to fill each. Unfornately each drain plug is a little different so they all require a different tool. Hope this helps a little.
Old February 5th, 2008, 09:49 AM
BlackBart's Avatar
Black Bart
First Name: Bart
John,
I'm just guessing, but when you said a SIMPLE answer, is the source of water a hard problem to locate/fix and is a BAD problem. Should I be concerned? Thks Bart
Old February 5th, 2008, 02:22 PM
1idrod's Avatar
My RZR: Gen 2 Green
I asked the same question today in another thread and got two different answers. One said same color as oil and other said blueish/grey. Now I'm confused.
Old February 5th, 2008, 04:32 PM
WOW 5 different oils to change yikes! There is a separate trans and main gearcase fluids... my oh my I dont know if im up to all that! At least I checked my diffs from the dealer to make sure they were full!!! Many said they found them low from the dealers.
Old February 5th, 2008, 05:46 PM
Johnny's Avatar
UTVCRAP*****
First Name: Johnny
My RZR: the red one
Dont worry its normal they for some reason all I have done have a milky look to them even rzrs with 1 mile on them...its the fluid
www.utvcrap.com 623-934-3070
623.934.3070
Old February 5th, 2008, 05:54 PM
Johnny's Avatar
UTVCRAP*****
First Name: Johnny
My RZR: the red one
623.934.3070
  #10 (permalink)
Old February 5th, 2008, 08:19 PM
next time you change it save a little and put it in a clear jar let it sit a few days...water will seaparate iif its a small amount its no biggie but larg amounts are not..... and if you spend alot of time in water expect it also if you pressure wash alot it forses water past seals but just keep a eye on it.... and change change it....
2008 polaris rzr
2006 suzuki ltr450
2003 suzuki z400
2003 honda ex250
  #11 (permalink)
Old February 7th, 2008, 07:48 PM
BlackBart's Avatar
Black Bart
First Name: Bart
Thans for the advice. I did happen to save the OLD but have not looked at yet. As to spending time in the H2O or pressure washing, I had done neither when I discovered the discoloration. But you can BET you last dollar that I'm going to check all the fluids/levels much more frequently. Thks again, Bart
Sponsored links
