Gas Tank Clean Out ?????? - Polaris RZR Forum - RZR Forums.net
post #1 of 11 Old March 27th, 2009, 02:14 PM Thread Starter
oglebuck's Avatar
First Name: Scott
My RZR: 08 RZR
Member #6685
View oglebuck's Photo Gallery(0)
I got water and sand in my gas tank. What is the best way to clean it out? And does the gas tank have a drain?
oglebuck is offline
post #2 of 11 Old March 27th, 2009, 04:58 PM
rzrback fan
aquacure's Avatar
First Name: Aqua
My RZR: 2008 Green
Member #4250
View aquacure's Photo Gallery(0)
Re: Gas Tank Clean Out ??????
Doesnt have a drain. Only way to make sure you get everything is to take it out and rinse it thoroughly with gas. Download the service manual it shows you how to take the tank out. I would suggest not taking the fuel pump assembly out and do everything through the filler. Those little brass fittings the screws go in can be a nightmare.
2008 Black Herculinered
2" rubberdown lift
4000 lb Viper winch (green amsteel cable) Motosport Alloy Black Tork rims : 27" outlaw MST : "S" flares
Trail Armor boot guards : MudATV snorkel
Ipod>Amp>overhead speaker box
Benz silencer (like it quiet) : Gorilla axle
aquacure is offline
post #3 of 11 Old March 27th, 2009, 06:57 PM
Johnpeq's Avatar
Member #1490
View Johnpeq's Photo Gallery(0)
Just a question, how did you get that sh>>t in your tank??
Just for us to learn,
John
Johnpeq is offline
post #4 of 11 Old March 27th, 2009, 08:38 PM
pes1004's Avatar
First Name: kevin
My RZR: 09
Member #5464
View pes1004's Photo Gallery(0)
go trash in mine from going to deep in water without a snorkel the vent hose on the tank will let trash in
know your limit and play right on the edge of it!
pes1004 is offline
post #5 of 11 Old March 28th, 2009, 04:22 AM Thread Starter
oglebuck's Avatar
First Name: Scott
My RZR: 08 RZR
Member #6685
Im not sure if the filler cap leaked or the water ran back through the vent line but it set stuck for about 3 hours in the water. We had 4 other atvs try to pull it out and ended up geting a 4x4 truck to pull it out. If you notice in my other post I need frame parts now due to this mishap. ( truck pulled frame peice off ) .
oglebuck is offline
post #6 of 11 Old March 28th, 2009, 06:14 AM
ride guide extrodanire
rzrwrecker's Avatar
First Name: Skeeter
My RZR: High Lifter Edtion
Member #614
View rzrwrecker's Photo Gallery(0)
this is the easy way take a clear hose and start a shiphon and run it along the bottom of the tank to pick up the debris! but if there is mud in there take it out and wash it
rzrwrecker is offline
post #7 of 11 Old March 28th, 2009, 07:15 AM
Johnpeq's Avatar
Member #1490
Wow, that is one stuck RZR, What loured you to that trap???
John
Johnpeq is offline
post #8 of 11 Old March 28th, 2009, 08:05 AM
bagman's Avatar
My RZR: 2015 1K Havasu Red
Member #649
This won't solve your problem but when everyone starting posting that the fuel filter was in the tank and not servicable I picked up a Mr. Funnel.
You can order or I picked mine up at Harbor Freight for about $20.
Sounds like you should take the tank out to be sure you get the bad stuff out.
bagman is offline
post #9 of 11 Old April 3rd, 2013, 01:25 PM
Birddog4x4's Avatar
First Name: Brian
My RZR: 2011 Polaris rzr s 800 Carbon Fiber LE
Member #22986
View Birddog4x4's Photo Gallery(2)
I know this is an old post, but running into the same issue. Was driving through a creek about three foot deep and coming out she started sputtering and no power. Checked the plugs and they were dry, ECU plug seems dry as well, so water in the fuel is my next thing.
So going to remove my tank and see what I have, flashlight was not cutting it! lol Now if there is what in the tank and I still have some in the hoses / fuel rail, whats the best was to remove it from there, or over time it will remove itself and start running better?
Thanks for the help everyone!
2007 Can Am 800 Outlander
2011 Polaris RZR S 800 Carbon Fiber LE
2004 Bombardier DS650
2002 Honda Rancher 350
Birddog4x4 is offline
post #10 of 11 Old April 7th, 2013, 04:27 PM
Birddog4x4's Avatar
First Name: Brian
Member #22986
Well this weekend I took the fuel tank out and here is what the filter looked like. Alot of dirt in the bottom and now its all cleaned out and running stong....
ID:	71888   Click image for larger version
post #11 of 11 Old April 7th, 2013, 05:22 PM
TEX
TEX's Avatar
My RZR: 12' RZR S
Member #41721
View TEX's Photo Gallery(0)
Wow...
12' RZR S
13' RGR Crew 800 (my favorite)
NRA Life Member
TEX is offline
This is how I get my RZR so clean ;-) cisco kid General RZR Discussion 13 January 27th, 2009 11:14 PM
best way to clean your rzrs? Fishman RZR-S Specific Discussion 12 January 12th, 2009 03:53 PM
Best way to clean my Air filter JaeRazr Engine and Drivetrain 8 August 12th, 2008 05:34 PM
Clean Pics WVU_RZR RZRForums Members' Rides 15 April 15th, 2008 08:42 AM
Got the Red Devil All Clean.. OregonDucks1 RZRForums Members' Rides 5 March 11th, 2008 07:15 PM
