2010 Rzr LE Wheel Size? - Polaris RZR Forum - RZR Forums.net
Forum Help, Questions and Info READ HERE FIRST!
post #1 of 4 Old October 18th, 2010, 09:43 AM Thread Starter
Rdrage's Avatar
Trying to change wheel size on my Rzr and having clearance probs. Bought stock "S" wheels and tires..26x10x12 and 26x12x12. Put a 3" lift on and have no clearance probs with front, but rear will not clear motor mount. Does anyone know what mininum size wheel spacer is needed or if I will have to put 14" offset wheels on rear?
Rdrage is offline
post #2 of 4 Old October 18th, 2010, 02:27 PM
Alfa Baz's Avatar
Re: 2010 Rzr LE Wheel Size?
If you already have the wheels, you will need to buy spacers. One inch may clear, but 2 inch will be safer. I put 14 inch wheels with different offset on my '09 LE, instead of getting the spacers. Any way you look at it, you will be wider. I also took a grinder to the motor mounts and managed another half inch of clearance.
Alfa Baz is offline
post #3 of 4 Old October 18th, 2010, 03:12 PM Thread Starter
Rdrage's Avatar
Thanks...We weremeasuring about 2 1/2" but can't find spacers. The 2" spacers are in stock.
Rdrage is offline
post #4 of 4 Old November 1st, 2010, 05:47 PM
Dooey
Dooey's Avatar
What offset did you go with with the new rear rims to clear the motor mount?
Tks, Dooey
Dooey is offline
Steering Wheel Nut Size???????????????? tre General RZR Discussion 27 July 4th, 2011 11:02 AM
same size wheel all around or not 08 redrzr Wheels and Tires 10 September 13th, 2010 08:37 PM
Wheel Size to Tire Size Chart? user_name Wheels and Tires 4 May 12th, 2010 01:55 PM
Steering wheel size? twvette General RZR Discussion 6 May 4th, 2010 09:32 AM
wheel stud size? Deez Nutz 08 General RZR Discussion 3 June 23rd, 2008 11:25 AM
