Stock HP -vs- Turbo HP - Polaris RZR Forum - RZR Forums.net
This is a discussion on Stock HP -vs- Turbo HP within the Forced Induction forums, part of the Technical category; What is the stock HP of a 08 RZR 800? Does anyone know what the HP would be if it was turbocharged running 4 to ...
Go Back   Polaris RZR Forum - RZR Forums.net > Technical > Forced Induction
Forced Induction Pushing some boost or have FI related questions? Post about it here!
Old February 20th, 2010, 07:17 AM   #1
bngcustoms's Avatar
Member #971
View bngcustoms's Photo Gallery(0)
What is the stock HP of a 08 RZR 800? Does anyone know what the HP would be if it was turbocharged running 4 to 6 lbs boost, 10.5:1 comp, 110 race gas? Or evn if I shimmed the head with a 1.5mm shim to drop the comp ratio and increased boost to 10lbs, what kind of HP do think it will make?
bngcustoms is offline   Reply With Quote
Old February 20th, 2010, 12:12 PM   #2
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Re: Stock HP -vs- Turbo HP
Well stock is about 50 HP at the crank and 35 at rear wheels.
The MCX kit doubles the RWHP or more with 11psi and a shim.
Aerocharger gets about the same power with no shim and less boost but you have to run race fuel.
I would guess you should have around 80 HP at the crank with the numbers you asked about. The race fuel won't create HP, but it will help prevent detonation.
Old February 20th, 2010, 12:25 PM   #3
bagman's Avatar
My RZR: 2015 1K Havasu Red
Member #649
Speaking of race fuel, there's a thread on GlamisDunes.com saying good ol'e California is going to ban race fuel for anything but true race cars. Wonderful!!!
bagman is offline   Reply With Quote
Old February 20th, 2010, 01:23 PM   #4
Tuf-Skin's Avatar
Member #2228
That figures!
I bet Torco sales would go up!
Old February 20th, 2010, 04:54 PM   #5
Feedback Score: 18 reviews
GIFF-TURBO's Avatar
First Name: Gary
Member #3946
The air ports will see an increase in AV fuel sales
GIFF-TURBO is offline   Reply With Quote
Old February 24th, 2010, 10:51 AM   #6
tylera189's Avatar
First Name: Tyler
Member #10827
View tylera189's Photo Gallery(0)
Quote: Originally Posted by Tuf-Skin View Post
That figures!
TORCO! haha where have you been. Evan Knoll went belly up two years ago or so. I imagine within 2 more years he will be in prison, for tax evasion, among other things. He really shafted the drag racing community, which I am a large part of. I do believe someone bought the rights to the torco name. But last I heard that was a flop as well.
tylera189 is offline   Reply With Quote
Old February 24th, 2010, 01:41 PM   #7
WFC
WFC's Avatar
First Name: Kelly
My RZR: RZR-S Boondocker turbo
Member #7019
View WFC's Photo Gallery(0)
That figures!
Are you saying Torco is no more??? I had 2 shipments of there fuel accelerator to me last summer, it seems to be a good product and so far has worked for the turbo app.
2009 RZR-S Built Popo motor crank to head, BD Turbo w/EBC, MPI ECU, STM Clutches. etc.....
2009 Ranger 700xp BMP stage 1 turbo
2009 Arctic Cat CF8 Sno Pro - mine
2007 Arctic Cat CF8 136" - wifes
2009 Arctic Cat sno pro 120(kids)
1985 Honda CR 500
WFC is offline   Reply With Quote
Old February 26th, 2010, 05:21 PM   #8
heath@mpi's Avatar
Member #5385
View heath@mpi's Photo Gallery(0)
MPI supercharger kit makes 35 hp stock and 75 hp on 7-8 psi on pump gas
Torco is still in buiness and have been for years.
heath@mpi is offline   Reply With Quote
Old February 27th, 2010, 06:09 AM   #9
bngcustoms's Avatar
Member #971
In my understanding is that you can only acheive a maximum of 70% (if perfectly matched system) of the stock hp. 35hp + 24.5hp(70%) = 59.5hp.....do I have false information? Can a turbo acheive more than 70%? If the system isn't perfectly matched than there is a decrease in %.
Old February 28th, 2010, 06:46 PM   #10
hdd-max's Avatar
Member #13351
View hdd-max's Photo Gallery(0)
A turbo can and will most definately achieve more than 70%. Think of it this way, and this is not perfect but close. For every extra atmosphere you create with the turbo, your power output will double. So if you have a turbo on your car and it is fueled and timed correct you should almost double the HP with every 14 lbs of boost. Turbos have compressor maps that tell you what there sweet spots are at certain pressure ratios. You could run 100 psi boost if your motor would hold it and the turbo, and fuel injectors were sized properly.
That would be over 6 times the NA hp number.
2011 XP900 LE
hdd-max is offline   Reply With Quote
Old February 28th, 2010, 08:16 PM   #11
4Nines's Avatar
My RZR: 09 RZR S
Member #5322
View 4Nines's Photo Gallery(1029)
My bone stock RZR-S did 43rwhp on the dyno.
With the MCX Turbo Stage 1 and a ported head on pump gas it did 103rwhp and 86rwtq.
4Nines is offline   Reply With Quote
Old March 2nd, 2010, 04:03 PM   #12
saqer's Avatar
First Name: dubai turbo
My RZR: xp
Member #5960
View saqer's Photo Gallery(0)
i am doing the same thing now stage one with ported head with bigger valves,
this after my pistons blow up and i am rebuilding the engine. dont ask me how that happed , was loseing alot oil from the breather and then engine died.
so now i am doing it with ported head, big oil cooler with fan, and intercooler with fan.
lets hope it holds up.
btw what psi did you use to get 103rwhp. i got 63hp on 10.5 psiwithout the ported head.
saqer is offline   Reply With Quote
Old March 2nd, 2010, 04:16 PM   #13
4Nines's Avatar
My RZR: 09 RZR S
Member #5322
Are you running the MCX display? It sounds your AFR's were off when you were dynoing.
I did the 103rwhp at about 12 psi. My tuning was dead on about 11.5:1 and I have never had a motor issue, but I keep my AFR's pretty low.
The only other thing I can think of is that I did have a dynatek ignition installed as well. This might have been good for about 5 to 10 rwhp.
Old March 2nd, 2010, 04:33 PM   #14
saqer's Avatar
My RZR: xp
Member #5960
i am useing the 63hp as a bass to see how mush hp i will gain.
i will do same fine tueing to rfr when i get it dynoed agine, but frist i need to break in the new pistons.
and up the boost to 11. hope to get 15-20 hp fingers crossed.
2008 polaris rzr 800 horsepower
2008 rzr 800 hp
2011 rzr 800 turbo hp
how much horsepower can a rzr turbo 1000
how much horsepower increase for a mcx turbo
polaris rzr 800 hp
polaris rzr 800 turbo horsepower
polaris rzr turbo how much boost stock
rzr 800 horsepower
rzr 800 hp
rzr 800 stock hp
rzr 800 turbo hp
rzr hp
rzr turbo hp
stock rzr 800 hp
Weber turbo vs MCX turbo videos bigmike58 RZR and UTV Video's 61 September 28th, 2010 12:13 AM
bikeman performance turbo kit vs boondock turbo kit Dman Forced Induction 32 March 2nd, 2010 10:33 PM
turbo paddles vs turbo bighorns = a draw Tuf-Skin Wheels and Tires 29 May 25th, 2009 04:41 PM
Relocating the turbo on a TSI Turbo kit (Pics) zrated Engine and Drivetrain 12 August 25th, 2008 11:52 AM
