Bent crank?
This is a discussion on Bent crank? within the Forced Induction forums, part of the Technical category; Quote: Originally Posted by sandjunkie Quote: Originally Posted by GIFF-TURBO RZR A symptom of a bent crank is the engine wants to die at idle ...
Go Back   Polaris RZR Forum - RZR Forums.net > Technical > Forced Induction
Forced Induction Pushing some boost or have FI related questions? Post about it here!
  #16
Old January 22nd, 2010, 08:50 PM
GIFF-TURBO RZR's Avatar
Feedback Score: 15 reviews
First Name: Gary
Member #3946
View GIFF-TURBO RZR's Photo Gallery(147)
Re: Bent crank?
Quote: Originally Posted by sandjunkie View Post
Quote: Originally Posted by GIFF-TURBO RZR View Post
A symptom of a bent crank is the engine wants to die at idle dose yours idle OK? you should be around 1100rpm at idle
yes idles fine
OK this is a long shot but if the bolts that hold the engine to the transmission were for some crazy reason loose it could allow the engine to move around and a little.......again this is a long shot but I thought its worth a look.......
  #17
Old January 22nd, 2010, 09:05 PM
sandjunkie's Avatar
First Name: phil
My RZR: 09 rzr s mcxturbo
Member #9682
View sandjunkie's Photo Gallery(0)
Re: Bent crank?
yes idles fine
I've checked that plus the motor mounts.I'am going to check the run out on my crank in the morning.I really don't wan't to do a rebuild this time of year,to much riding to do.
  #18
Old January 22nd, 2010, 09:23 PM
First Name: Gary
Member #3946
Re: Bent crank?
Let me know what you find
  #19
milosusa's Avatar
Feedback Score: 6 reviews
My RZR: 2008 Red
Member #1361
View milosusa's Photo Gallery(27)
Re: Bent crank?
Gary is absolutely right, when I bent mine I can run car over 2500 RPM but under that, die quickly. Thanks good at least for that I can load RZR to trailer. It is not in your case, you still run on idle. Just wondering, if just end of the crank where primary is slip on could bent and you see wobbling, but really can't see how this will happened. IMHO
milos
2008 Attitude TH
06 raptor 734
09 Raptor 700
08 RZR 860 MCX Turbo
  #20
Old January 23rd, 2010, 12:19 AM
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
Re: Bent crank?
maybe bad bearing rather than bent crank, that would cause wobble.
1 Limey in a world of Yanks
  #21
Old January 23rd, 2010, 01:48 AM
bigmike58's Avatar
Member #1218
View bigmike58's Photo Gallery(0)
Re: Bent crank?
Don't run the motor without the clutch untill you find out if that's ok to do.....it's not with the weber....something to do with dampning/balance.....
do a runout test while cranking..dont start it...
  #22
Old January 23rd, 2010, 06:00 AM
sandjunkie's Avatar
First Name: phil
Member #9682
Re: Bent crank?
Thanks guys will let you know what i find later on today.AGAIN THANKS
  #23
Old January 23rd, 2010, 05:51 PM
sandjunkie's Avatar
First Name: phil
Member #9682
Re: Bent crank?
Well the crank checked out OK. it was with in spec.Put it all back together gave it a couple of hard runs up&down the sandwash runs great, no grinding in any gear.
THANKS FOR ALL THE INPUT
  #24
Old January 23rd, 2010, 05:57 PM
back from the sand & dirt
Member #787
Re: Bent crank?
then id run it till it stops.....if it was alittle bit it might of been the casting of the primary off a hair....but if it goes drive it.
lots of toy's
  #25
Old January 23rd, 2010, 06:05 PM
sandjunkie's Avatar
First Name: phil
Member #9682
Re: Bent crank?
Thats just what iam going to do.
  #26
Old January 23rd, 2010, 06:15 PM
MCX-USA Turbos's Avatar
UTV Turbos
Member #6516
View MCX-USA Turbos's Photo Gallery(0)
Re: Bent crank?
So what was it Bruce?
Chris
  #27
Old January 23rd, 2010, 06:20 PM
sandjunkie's Avatar
First Name: phil
Member #9682
Re: Bent crank?
Chris
whos bruce?
  #28
Old January 23rd, 2010, 06:23 PM
bigmike58's Avatar
Member #1218
Re: Bent crank?
thats great news phil......musta had bad belt alighnment...
  #29
Old January 23rd, 2010, 06:27 PM
UTV Turbos
Member #6516
Re: Bent crank?
LOL...I've been talking to one of our other customers with the same symptoms, so I thought it was him...lol.
Chris
  #30
Old January 23rd, 2010, 09:09 PM
First Name: Gary
Member #3946
Re: Bent crank?
Glad to hear it worked out good!
Bent Frame or A-Arm - Help Me Please! tommy1170 General RZR Discussion 9 October 11th, 2009 04:53 PM
About to order Crank from Crank works. Whats the deal with the Spacer? pioneer6869 Forced Induction 2 September 20th, 2009 06:21 AM
Bent Frame sporlan General RZR Discussion 0 September 9th, 2009 06:32 PM
Bent Tie rod end????????? sandaddict General RZR Discussion 15 October 28th, 2008 08:17 PM
Checkout the following websites in the UTV Forums Network:
UTV Blog - Yamaha Rhino Forum - Polaris RZR Forum - Kawasaki Teryx Forum - RedLine UTV Forum - Arctic Cat Prowler Forum - Honda Big Red Forum - Can-Am Commander Forum
