antifreeze is blowing out overflow - Polaris RZR Forum - RZR Forums.net
Forced Induction Pushing some boost or have FI related questions? Post about it here!
post #1 of 34 Old November 21st, 2009, 12:15 PM Thread Starter
Bshay169's Avatar
First Name: Brandon
My RZR: xp
Member #6779
View Bshay169's Photo Gallery(0)
just bought a rzr with a turbo and got it home and it keep blowing coolant out overflow. Any help would be great. New to turbo sytems. thanks
Bshay169 is offline
post #2 of 34 Old November 21st, 2009, 12:26 PM
King of crash!
Member #787
Re: antifreeze is blowing out overflow
it could be sevral things.....
start with the basics.....is it full or possably over full....could their be air pockets and it needs bleeding of air......thermostat stuck closed.... blocked radiator ......fan working.....and the last bad one...blown head gaskit
johnnycat8 is offline
post #3 of 34 Old November 21st, 2009, 12:42 PM Thread Starter
Bshay169's Avatar
First Name: Brandon
My RZR: xp
Member #6779
how do you check for air pockets. I hope its not head gasket.my fan seems to run after I shut it off an turn it back on
Bshay169 is offline
post #4 of 34 Old November 21st, 2009, 12:43 PM
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
That sounds like a leak in the head gasket.
Mine did that a couple times, but only when it got really hot. It turns out that my dealer did not torque down the head bolts tight enough.
So the pressure from the cylinder gets passed the head gasket and pressurizes the coolant system, pushing coolant out the overflow bottle.
When you take off the head you should find some white marks on the black head gasket that will tell you where it was leaking.
Tuf-Skin is offline
post #5 of 34 Old November 21st, 2009, 12:46 PM
Tuf-Skin's Avatar
Member #2228
Here is what mine looked like when I took it out:
Tuf-Skin is offline
post #6 of 34 Old November 21st, 2009, 12:47 PM Thread Starter
Bshay169's Avatar
First Name: Brandon
My RZR: xp
Member #6779
I think your right because that's when it does it. For the firsy time the factory gage said hot. I've owned 3 and never had an issue. Needless to say I se them. But I've only driven this around the yard.
Bshay169 is offline
post #7 of 34 Old November 21st, 2009, 12:52 PM
Tuf-Skin's Avatar
Member #2228
Ya I think the metal expands just enough when it gets hot and causes the leak...
When it happened to mine I took the head off and the head bolts were really easy to take out. I am confident that my dealer did not torque them down correctly. After I installed a new gasket and torqued the bolts down right I have not had any problems.
If this is what is wrong and you are putting in a new gasket, consider the high flow gasket from HPD. It is a stock gasket with the flow paths for the coolant enlarged a little for better flow.
Tuf-Skin is offline
post #8 of 34 Old November 21st, 2009, 12:58 PM
Tuf-Skin's Avatar
Member #2228
Stock gasket (with leak marks):
New HPD high flow gasket:
Tuf-Skin is offline
post #9 of 34 Old November 21st, 2009, 01:01 PM Thread Starter
Bshay169's Avatar
First Name: Brandon
My RZR: xp
Member #6779
where is best place to get that one
Bshay169 is offline
post #10 of 34 Old November 21st, 2009, 01:03 PM
Tuf-Skin's Avatar
Member #2228
HPD-INC.com click here: RZR
What brand of turbo kit does it have on it? And where do you ride?
Tuf-Skin is offline
post #11 of 34 Old November 21st, 2009, 01:05 PM Thread Starter
Bshay169's Avatar
First Name: Brandon
My RZR: xp
Member #6779
I think a boondocker. Bought I off ebay. Orange 09
Bshay169 is offline
post #12 of 34 Old November 24th, 2009, 04:29 PM Thread Starter
Bshay169's Avatar
First Name: Brandon
My RZR: xp
Member #6779
what did you torque head bolts down to
Bshay169 is offline
post #13 of 34 Old November 24th, 2009, 04:35 PM
Does my sons 170 count?
dirtysidedown's Avatar
First Name: Steve
Member #4404
View dirtysidedown's Photo Gallery(0)
Silly-but did you test the cap? I just had a Ranger here that the owner swore it needed gaskets, all it needed was a new $7.95 radiator cap.
dirtysidedown is offline
post #14 of 34 Old November 24th, 2009, 04:37 PM
Tuf-Skin's Avatar
Member #2228
Good tip!
Sometimes it is the simplest thing that we over look...
With mine it only happened when the engine was really hot, and at boost. If it happens all the time when hot and not just at boost, then it might not be the head gasket...
Tuf-Skin is offline
post #15 of 34 Old November 24th, 2009, 04:55 PM Thread Starter
Bshay169's Avatar
First Name: Brandon
My RZR: xp
Member #6779
how could the radiator cap cause it to shhot out overflow? It does it even when its not hot just warmed up
Bshay169 is offline
antifreeze smell a little help graveyard General RZR Discussion 9 March 24th, 2010 08:58 PM
what brand antifreeze works best? Fishman RZR-S Specific Discussion 5 November 16th, 2009 04:05 PM
4wd blowing fuses? HELP!!! Britt618 Lighting, Stereo and Electrical 12 October 23rd, 2009 02:43 PM
Antifreeze Penguin Engine and Drivetrain 0 August 1st, 2009 08:18 AM
Anti-Freeze Coming from Overflow Bottle dniss Engine and Drivetrain 7 March 24th, 2009 05:51 PM
