Factory UTV XMF Connection
This is a discussion on Factory UTV XMF Connection within the Factory UTV forums, part of the Supporting Vendors category; To celebrate our signing on as an XMF distributor, for a limited time we are offering RZR XMF +6 long travel kits at a price ...
Go Back   Polaris RZR Forum - RZR Forums.net > Supporting Vendors > Factory UTV
Factory UTV Factory UTV - 916-207-8335
Old September 30th, 2008, 02:25 PM
Factory UTV's Avatar
First Name: Bob
My RZR: 08
Member #2027
View Factory UTV's Photo Gallery(4)
To celebrate our signing on as an XMF distributor, for a limited time we are offering RZR XMF +6 long travel kits at a price to low to post here. If you want to go Long Travel on your RZR, now is the time. PM for details...
Bob
Factory UTV
info@factoryutv.net
www.factoryutv.net
Old September 30th, 2008, 04:05 PM
DA INFERNO's Avatar
Member #510
View DA INFERNO's Photo Gallery(0)
Re: Factory UTV XMF Connection
Any pics or specs?
06 CHEVY 2500 HD
07 LE3305 WEEKEND WARRIOR
05 PREDATOR 500 (4 SALE)
05 LTZ-250
01 SCRAMBLER 50 (4 SALE)
08 RZR (GEN 3)
http://www.dieselplace.com/forum/gar...do=view&g=6876
Old September 30th, 2008, 08:59 PM
racerxj17's Avatar
Member #3153
View racerxj17's Photo Gallery(0)
pm sent for a price! a red one pleaseee....
Old September 30th, 2008, 09:08 PM
First Name: Bob
My RZR: 08
Member #2027
Quote: Originally Posted by DA INFERNO View Post
Any pics or specs?
RZR Plus 6 Long Travel Kit
Walker Evan remote reservoir 16 way adjustable Billet aluminum reservoir mounts Axles - XMF 4340 Heat Treated center less ground and powder coated Uses OEM sway bar, includes new links 1/2” Chromalloy FK Teflon coated steering heim joints with billet aluminum steering extenders and zinc plated hardware Arm Construction - 1 ¼” 4130 chromoly tubing X .120 wall thickness TIG welded for strength and appearance Front Arms- Lower- uses spindle adapter and unibal Upper uses a ¾ FK Chromalloy Teflon coated heim joint with a adapter to connect to the stock spindle with out any drilling. The dapter is constructed of Chromalloy steel which is heat treated and black oxide for strength and appearance. Rear Arms – uses tube cups with CNC washer TIG welded for strength to attach hubs to arm which provides a much stronger connection than using tabs. All arms use grease able Delron bushings and crush tubes on the chassis side New brake line for front left side Powder coated finish. Comes with lifetime warranty against manufacture defects.
Bob
Factory UTV
info@factoryutv.net
www.factoryutv.net
Old October 2nd, 2008, 06:16 PM
Generalg's Avatar
Member #2271
View Generalg's Photo Gallery(0)
Is the wheelbase lengthened?
If so how much in the front and rear?
Old October 2nd, 2008, 07:35 PM
acsracing's Avatar
First Name: Sherman
My RZR: Blue Silver Black one
Member #1489
View acsracing's Photo Gallery(0)
I think its a plus 6 that would make your rzr 12" wider. if you ever ride LT you'll never go back to the old wagon on a rock road feel.
Is the front hiem joint or ball joint and does the 4th axle come with it since its not pictured. LOL kidding about the axle.
PM a Price PLEASE
Old October 6th, 2008, 04:34 PM
First Name: Bob
My RZR: 08
Member #2027
Time is running out on this offer! You will not find a better deal on a quality LT kit ANYWHERE...
Bob
Factory UTV
info@factoryutv.net
www.factoryutv.net
Bookmarks
Factory UTV 1 Phat Cat General RZR Discussion 7 December 2nd, 2008 11:49 AM
WTB factory UTV doors. DCRZR Want to Buy 0 September 11th, 2008 08:26 PM
Factory Nets keowee1 General RZR Discussion 6 August 27th, 2008 10:00 AM
Welcome Factory UTV! Brian B Factory UTV 6 May 2nd, 2008 11:28 PM
9 Volt Battery Connection knockerm Lighting, Stereo and Electrical 1 March 27th, 2008 03:35 PM
