Just shoot me in the Head!!! - Polaris RZR Forum - RZR Forums.net
post #1 of 25 Old January 14th, 2013, 06:20 AM Thread Starter
NOSaintBuggy's Avatar
Member #24877
View NOSaintBuggy's Photo Gallery(8)
When I took off my clutch exhaust snorkel tube for maintenance, little pieces of a vespal washer came out. I used the you tube homemade clutch removal method (4" 3/4 fine thread bolt & 1/2" x 4" bolt) to remove and repair as to protect my clutch and drove the 1/2" by 4" bolt right into the end of my crank shaft about 3/4 to one inch!! After drilling almost all of that out, I tried to just start a smaller tap in what was left of the bolt hoping to basically grab what was left and remove the debis and that broke inside. It is loose, wiggles, and turns but will not come out. I still have an outside chance of a remedy without a new crankshaft in a perfect motor but maybe not. Anyone trying this should use a 5/8 by 4" bolt NOT A 1/2 x 4"!!
NOSaintBuggy is offline
post #2 of 25 Old January 14th, 2013, 06:32 AM
Empty_Pockets's Avatar
First Name: Darryl
My RZR: 2013 800 SLE Blue Fire/Orange
Member #47829
View Empty_Pockets's Photo Gallery(0)
Re: Just shoot me in the Head!!!
GOOD TO KNOW!
Sorry bout your problems, thanks for passing along the info!
Empty_Pockets is offline
post #3 of 25 Old January 20th, 2013, 02:41 AM Thread Starter
Member #24877
Well I was VERY lucky!!!! When I finally got the remaining piece of that bolt out, I found that the Threads for the clutch bolt were further in the shaft and UNHARMED. The hair is already grayer and the heart damage done but I am good to go. Instead of an unnecessary motor tear down, all I had was time, one broken drill bit, tap, and purchased mini needlenose plyers. I not only dodged a bullet, it was a 50 cal. bullet.
post #4 of 25 Old January 20th, 2013, 06:07 AM
Doolin2's Avatar
Member #31195
View Doolin2's Photo Gallery(0)
Go play the lottery.
Doug
Doolin2 is offline
post #5 of 25 Old January 20th, 2013, 06:42 AM
INrider's Avatar
First Name: Bill
My RZR: 2011 RZR S Carbon Fiber
Member #31170
View INrider's Photo Gallery(0)
Sometimes small details make a huge difference,glad you got it out.
INrider is offline
post #6 of 25 Old January 20th, 2013, 11:37 PM
JayTrain's Avatar
First Name: Jay
My RZR: 2011 RZR XP
Member #44416
View JayTrain's Photo Gallery(0)
OR...you could have went to your local shop and bought a clutch puller for $50 and had the right tool for the job, WITHOUT chancing you damaging a very expensive crank. And you would have the tool for future jobs as well as a loner tool for friends doing the same thing. Sometimes being cheap ISNT worth it.
2011 RZR XP - Factory Polaris OE Power Steering Kit, K&N Air Filter, Pro Armor Doors w/ graphics, Polaris Roof, Pro Armor Trailing Arm Guards, VDP Roof Stereo, Trail Tech Voyager GPS, Viper 5000lb Winch, Pro Armor 3" 5-point Harness', Exhaust & Fuel Programmer Coming Soon (cant decide on brand)
JayTrain is offline
post #7 of 25 Old January 21st, 2013, 05:05 AM Thread Starter
Member #24877
Hey Jay Thanks for your hindsight, if my head were as far up my ass as yours, I would not have known that a puller like that is not at a local store, especially on the weekend, AND this was the first tip from utube that did not save me allot of time and money. Never been cheap in my life, just made a mistake that I do not mind admiting in an effort to help prevent another rider from diaster. What is the point in your remark ass***!!
post #8 of 25 Old January 21st, 2013, 04:06 PM
JayTrain's Avatar
First Name: Jay
My RZR: 2011 RZR XP
Member #44416
if my head was up my ass, i wouldnt be able to read or type. LOL
The whole point was to let people know to not get in a rush and hodge podge bolts together to try and make a puller that costs $50. Instead of risking a thousand plus to replace your crank, wait a couple days to get the right tool for the job.
Its the exact same message your sending out except for one thing. Im telling them the RIGHT way to do the job. Your telling them to continue to try the WRONG way to do things using the right size bolts.
See the difference? So next time you wanna call me names, make sure your not in the wrong.
JayTrain is offline
post #9 of 25 Old January 21st, 2013, 06:19 PM
ridefst's Avatar
My RZR: 2008 Rzr 800
Member #33196
View ridefst's Photo Gallery(0)
I've got another suggested item NOT to use - 3/8ths drive extension, turned with the small end towards the motor!
Tried that one when I was tearing down the motor last month, wedged it in the end of the crank very nicely.
In my case, I was tearing it down to replace the crank anyways, so I didn't bother trying to get it out - all I lost was a cheap 3" extension.
Sure would be pissed if I did that to a good crank though!
ridefst is offline
post #10 of 25 Old January 22nd, 2013, 02:42 AM Thread Starter
Member #24877
Jay you do not read or type worth a sh** and as I said, that was the ONLY tip that did not pan out so it could happen to anybody trying to get a job done and no reason to think that a method which worked for others would not work fine. That is why I put it out there. AGAIN, hindsight! No one on this forum needs told you so's, it is a place to talk and share information. I think most realize the options without your condesending wisdom. There are always more than one way to do something RIGHT, your not helping anyone, your just mouthing off!!
post #11 of 25 Old January 22nd, 2013, 02:59 AM Thread Starter
Member #24877
Hey ridefst, I am glad you were replacing anyway so your project did not go south. I still made a clutch holder and spyder wrench with stuff lying around so keep using your noggen, just be careful. I went ahead and bought the spyder wrench so I could use my torque wrench for assembley but got everything apart, cleaned, and repaired while waiting. "When your brain has been stretched beyond it's original dimensions, it can never go back."
post #12 of 25 Old January 22nd, 2013, 08:21 PM
JayTrain's Avatar
First Name: Jay
My RZR: 2011 RZR XP
Member #44416
You took my comment completely the wrong way. It wasnt meant to be offensive. If you want an apology, I apologize. Sometimes text can be taken the wrong way very quickly. It did in this case. Re-read it a few times. I did not directly call you cheap, I said that the way you described doing the job was cheap. I also informed people that there is a better and safer way to do the job the way it is supposed to be done. And if you are going to own RZRs, having that specific tool is a good option for future jobs and for friends to borrow.
I see you continue to try and bash me by being a typing/grammar nazi. Where in any of my replies was my typing or reading any worse than yours? You keep trying to show how big your "e-peen" is, yet you continue to show how ignorant you really are.
As for me mouthing off, again, it wasn't meant that way. That's how you took it. But I can see how it could be taken that way. The biggest problem I had with this post is that you try to let others know a good thing, in the right size bolts to use, but you don't inform them of the way it should be done. Your trying to help, but your still telling them to try something that puts them at risk for spending a lot of extra money.
So whatever man. It is what it is. Keep trying to make yourself look better than me. I'm done with this thread, as I'm sure future readers will be too.
Good luck in the future.
JayTrain is offline
post #13 of 25 Old January 22nd, 2013, 08:26 PM
King of crash!
Member #787
well i know what happend you watched the video for a 800 ... and almost every polaris dealer has the tool in stock most are only 15 to 30 bucks.. just a fyi.... always make sure the tips are for the correct application and when it comes to tools never short cut.
johnnycat8 is offline
post #14 of 25 Old January 25th, 2013, 03:54 PM
Pirate's Avatar
First Name: Stuart
Member #3677
But to give Jay a boost. You can buy the tool on eBay or from several vendors...I read the forum while I was waiting for my 2009 to show up at the dealer. I read about the tool and that its necessary. So I bought one and carry it with me. I've also made copies of posts/service manual, vendor info...put them in a Ziploc bag with the tool and that way I have the tool and a reminder on how to use it with me...anywhere!!
Good info Jay, sorry you got slammed for trying to provide good info. I agree with you completely!!
Pirate
Pirate is offline
post #15 of 25 Old January 25th, 2013, 05:30 PM
570razor's Avatar
First Name: Jim
My RZR: 2013 Jagged X
Member #50018
View 570razor's Photo Gallery(0)
I'm glad we have have a tool sheriff on the site to call us out. I put new springs on with ratchet strips instead of buying some spring compressors. I guess I'm a cheap ass.
570razor is offline
RZR 170- Photo Shoot-!! JenniferRath RZR 170 Specific Disccusion 2 January 6th, 2011 04:53 PM
Who do i have to shoot to get some **** wheels!! Live Round Wheels and Tires 1 November 22nd, 2010 05:32 PM
cutch shoot out? ditch pickel General RZR Discussion 1 November 16th, 2008 03:12 PM
lcutch shoot out? ditch pickel General RZR Discussion 0 November 16th, 2008 01:31 PM
