2010 razor will not idle - Polaris RZR Forum - RZR Forums.net
This is a discussion on 2010 razor will not idle within the Engine and Drivetrain forums, part of the Technical category; Need help, this weekend razor just stalled will not start unless gone it gas then as soon as u let off it stalls. What could ...
Old November 25th, 2012, 07:59 PM   #1
malibu05's Avatar
Member #12718
View malibu05's Photo Gallery(0)
Need help, this weekend razor just stalled will not start unless gone it gas then as soon as u let off it stalls. What could this be
malibu05 is offline   Reply With Quote
Old November 25th, 2012, 08:29 PM   #2
Owner-Light it Up Offroad
Feedback Score: 16 reviews
MATT1524's Avatar
First Name: Matt
My RZR: 2016-Turbo 4
Member #13639
View MATT1524's Photo Gallery(0)
Fuel pump. My 2010 did same thing. Check fuel pressure. Common problem.
We Sell: Totron, Viper, Rigid, PRP & MORE!
CALL 479-222-5398
479-434-4161
WWW.GETLITFS.COM
Your one stop shop for all your UTV & Truck needs!
We have a REAL store front!
3201 Wheeler Ave-Fort Smith, Arkansas
MATT1524 is offline   Reply With Quote
Old November 25th, 2012, 08:50 PM   #3
Hunterworks's Avatar
First Name: Todd
My RZR: 2016 XP1000
Member #47437
Re: 2010 razor will not idle
Does it run fine otherwise? Normally and I say normally a weak fuel pump allows it to idle but not come to speed.
I would say a place to start looking is the throttle sensor voltage out of whack or a issue with the idle speed control valve.
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline   Reply With Quote
Old November 25th, 2012, 09:51 PM   #4
RacerSam's Avatar
My RZR: 2009 Nuclear Orange LE, 2012 Walker Evans
Member #7858
View RacerSam's Photo Gallery(0)
our 09 did that one day ,I changes spark plugs, and checked most everything short of actual TPS voltage, as I went to loosen clamp where T.B. goes into intake boot from air cleaner to clean it, the T.B. just feel down, turns out if was lose/slide out of the intake manifold side already. put it back into intake boot on engine side, tightened clamp, then back in intake boot to airbox, ran like new again.
on a sie note ours had been idle-ing low like 950-1050 rPM's after the intake boot fix that was lose, guess got loser/came out finally that day messing up its idle sucking air into engine there. it also fixed the low idle.
'16 Graphite Crystal turboXP
'14 Black Stealth 900XP
'12 Walker Evans 800
'09 Nuclear Orange 800LE SOLD
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline   Reply With Quote
Old November 27th, 2012, 08:01 PM   #5
malibu05's Avatar
Member #12718
Thanks for the help. For the most part as long as u stay in the throttle it runs ok, little on the rough side but will run. As soon as you let off the gas it shuts right off. Does any one know if a fuel pump out of a 2011 S will fit. When i cross reference the polaris part#s they are not the same but is that the case, or is that just a polaris thing.
Thanks again for the help.
Old November 27th, 2012, 08:31 PM   #6
RacerSam's Avatar
Member #7858
think for an 11 or 12 pump to work, you will also need an 11 or 12 fuel tank too
'11 rzr170 SOLD
'05 YFZ450 SOLD
Old November 27th, 2012, 10:37 PM   #7
Feedback Score: 26 reviews
MotoXXX's Avatar
First Name: Jeff
Member #4542
Have you checked the fuel pressure or the TPS voltage yet?
MotoXXX is offline   Reply With Quote
2009 polaris rsr s will not idol
2010 rzr s wont hold idle voltagr
engine rpm low 950 rpm
polaris 900 idle tps voltage reference
polaris razor not idling
polaris razor will not idle
polaris rzr tps sensor cross reference
rzr 800 wont idle and shuts off when i let off the gas
rzr 900 wont idle
rzr not idling
rzr not idling, carb boot fell off
rzr will not idle
rzr wont idle
rzr xp900 ho wont idle
2010 razor S Factoryride250 Polaris RZRs For Sale 11 September 27th, 2012 07:17 PM
2010 rzr s 800 low idle?? jordan07 RZR-S Specific Discussion 1 April 9th, 2012 09:18 PM
2010 rzr s TPS and idle ? BMRZRS RZR-S Specific Discussion 7 March 28th, 2012 09:30 PM
Razor S wont idle Blown Razor RZR-S Specific Discussion 8 February 13th, 2011 06:11 AM
2010 Razor S belt help Goodtimes RZR-S Specific Discussion 4 May 17th, 2010 08:29 PM
